Old 03-24-2014, 08:01 PM   #6763
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I removed the absolutely fugly BRZ fuel door sticker and found scratches underneath. I hope they buff out.
Bobblehead is offline   Reply With Quote
Old 03-24-2014, 08:02 PM   #6764
JS + BRZ
Drives: 2010 MS3
Originally Posted by Sanka86 View Post
added the best mod so far to my car the Toms taillights.
Got bored and painted the manifold cover.
hey that cover looks really good actually.
how did you do it? any close-up pics?
Old 03-24-2014, 08:24 PM   #6765
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
duplicolor perfect match off the clearance rack at advance auto. i think it was chrysler sand drift. i painted the lettering red with a small brush because i had just got done doing that to the 86 fender vents i swapped for.
BoxRZ_86 is offline   Reply With Quote
The Following User Says Thank You to BoxRZ_86 For This Useful Post:
JS + BRZ (03-24-2014)
Old 03-24-2014, 08:33 PM   #6766
JS + BRZ
Drives: 2010 MS3
Thank you. Looks really good. Not ricey at all. haha
The Following User Says Thank You to JS + BRZ For This Useful Post:
BoxRZ_86 (03-24-2014)
Old 03-24-2014, 09:46 PM   #6767
nocturne1
nocturne1's Avatar
Drives: 2013 BRZ Limited WRB
Tapturn! +5HP
nocturne1 is offline   Reply With Quote
Old 03-24-2014, 09:46 PM   #6768
sshole
I have been wanted to do this exact mod. thank you for making it something I want to do even more now.
also post a night shot if you can. thanks.
Brightest setting
Dimmest setting
Originally Posted by The Natural View Post
How much does doing something like this cost?
If you know how to solder: not much. If you don't know how to solder: just a little more than not much. It just takes some time. Total cost in LEDs is probably <$10, and that's if you get really nice LEDs. Mine were from a batch I ordered off a Chinese vendor on ebay a couple years ago to do another project. I only needed 3 for speedo, 3 for tach, and 1 each for gas and coolant temp, so 8 PLCC2 3528 LEDs total.
sshole is offline   Reply With Quote
The Following 2 Users Say Thank You to sshole For This Useful Post:
BoxRZ_86 (03-24-2014), wtrxprs007 (03-25-2014)
Old 03-24-2014, 09:58 PM   #6769
BoxRZ_86
BoxRZ_86's Avatar
Originally Posted by sshole View Post
Brightest setting
Dimmest setting
Perfect
Old 03-24-2014, 11:07 PM   #6770
missbrz
missbrz's Avatar
Drives: brz limited
so i got the chance to install a few things over the weekend
added some more color under the hood, beatsonic sharkfin, grimmspeed master cylinder brace, perrin strut tower, lamin-x yellow covers
missbrz is offline   Reply With Quote
The Following 4 Users Say Thank You to missbrz For This Useful Post:
dbrandt01 (03-24-2014), Marchy (03-25-2014), Turkish (03-24-2014), wtrxprs007 (03-25-2014)
Old 03-25-2014, 05:54 AM   #6771
Hachiroku14
Drives: 2014 BRZ World Rally Blue
STi-R clear lens upgrade.
Hachiroku14 is offline   Reply With Quote
Old 03-25-2014, 07:14 AM   #6772
deliroast
Drives: 2014 SSM BRZ
@Hachiroku how hard was it to do? Been eyeballing the same setup since I miss the sharp cutoff my old cars retrofit had.
M3 > BRZ
deliroast is offline   Reply With Quote
Old 03-25-2014, 08:04 AM   #6773
sshole
Shouldn't be any more difficult than a retrofit. Open headlights, disassemble front half of projector from reflector bowl, remove and replace lens (and do any color modding here), reassemble, close headlights. For someone who has done a retrofit before, it shouldn't take more than a couple hours to do this.
The Following User Says Thank You to sshole For This Useful Post:
deliroast (03-25-2014)
Old 03-25-2014, 09:44 AM   #6774
deliroast
Awesome. Can't remember if you can bake the brz housings but would love to switch to these and a phillips bulb from trs but saw we use a different type than normal
M3 > BRZ
Old 03-25-2014, 09:46 AM   #6775
sshole
You can most definitely bake the BRZ headlights. They use the soft sealant.
The BRZ uses D4S bulbs and ballasts, so switching bulbs isn't as easy (D4S isn't nearly as common in the aftermarket) as with, say, the STI, which uses D2S bulbs and ballasts.
Old 03-25-2014, 10:03 AM   #6776
deliroast
Awesome. Thanks for the info. Definitely don't want to switch to aftermarket ballasts to run d2s but I'll definitely be doing the lens. The Fxr were awesome on the m3
M3 > BRZ
