Old 06-24-2010, 11:55 PM   #1
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
Any issues with Subaru engine?
Just curious if there are any issues that should be resolved by aftermarket reenforcements with the subaru engines?
Like are there leaky valves that tend to fail?
CyberFormula is offline   Reply With Quote
Old 06-25-2010, 11:48 AM   #2
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Haven't heard bout leaky valves... but I heard here and there, but burns the oil. For me, I need to put bout 1/3~1/2 quart every 1.5k miles or so.
Old 06-25-2010, 12:06 PM   #3
bigbcraig
Drives: 2013 BRZ / 2015 WRX
There have been some problems with the strength of the pistons in high-powered EJ25's - including some stock STI's - that can be completley solved by getting forged pistons.
No catastrophic failure happens, but they will lose compression and thus make less power than they should. Often, the owner won't notice anythign until the enigne gets a compression test or rebuild.
They don't come stock because it's harder for Subaru to get cold-start emissions with forged pistons.
The early 265hp WRXs (09 model year) had some problems with owners blowing the engine (main bearing failure) even before the break-in was over. This was a manufacturing defect and has been resolved.
Otherwise... newer EJ's are "interference" engines - if you go way past the timing belt change interval and it fails, you need a new engine.
Mainly if you keep up with preventitive maintenance and have good synthetic oil, even a modified EJ should be running strong for a solid 200k.
@Ichitaka - really? I burn very, very little oil - even having the turbo - I don't think I've ever had to add oil inbetween intervals. Granted my car is pretty new... but I've never heard anything about latent oil loss like you describe. Time for piston rings / maybe a small leak?
bigbcraig is offline   Reply With Quote
Old 06-25-2010, 01:11 PM   #4
ichitaka05
Site Moderator
ichitaka05's Avatar
Sorry, I should of been more specific on that oil burn.
No, I've overhaul my engine last yr (including piston rings) and there's no leak (after overhaul, I let the pro check for any leak). You're forgetting that your engine is DOHC with better technology than mine (SOHC). technically, my engine is 80's technology vs yours 20th century technology. If I don't race my car often, then I actually don't need to put any oil in my car (winter time, no adding oil at all)... so pretty much cause by racing.
Old 06-25-2010, 03:15 PM   #5
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
no major issues on new engines. they used to have head gasket leaking issues, but i haven't heard about anything like that on vehicles newer than '01. i've heard some stories about bearing problems, but i don't think it's a common occurance.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 06-25-2010, 03:42 PM   #6
ichitaka05
Site Moderator
ichitaka05's Avatar
which bearing? Wheel hup bearing or crankshaft bearing? Either way, you're right. New vehicles engine been taken care of. Oh and it's not newer than '01, but '04 or new ones. '02~'03 wrx head gasket & crankshaft bearing were one of the problem they had (iirc).
Old 06-25-2010, 08:16 PM   #7
CyberFormula
so you're saying if I buy a car with a subaru wrx engine in it...
it would be a good thing to change my pistons to Forged Pistons as a first modification?
Old 06-26-2010, 12:58 AM   #8
ichitaka05
Site Moderator
ichitaka05's Avatar
It's for you to judge & decide... but if I was you, if I need to change out the pistons to forged pistons, I'll do full blown internal work while at it (crank, valves, cams, port, bore, & etc). It'll be waste of money just only to get forged pistons in. Anyways, you gonna take out the engine out, mind as well.
Old 06-26-2010, 02:05 PM   #9
djohnson
Drives: 1996 RAV4
Another thing if you happen to pull the engine, check your plugs while you are at it. I dont have any personal experience with boxer motors, but from what I hear, they are a real pain to get at.
djohnson is offline   Reply With Quote
Old 06-26-2010, 02:13 PM   #10
ichitaka05
Site Moderator
ichitaka05's Avatar
plugs? Like spark plugs? Spark plug isn't hard to get to. Driver side is lil bit pain, but still 200x better than '00 Montero Sport (got to take out effin' intake manifold to get to the damn spark plugs).
Old 06-26-2010, 05:02 PM   #11
bigbcraig
Plug aren't that bad - yes, they're a pain especially if you're used to an easy-to-reach inline 4 - but very doable.
I wouldn't do forged pistons as a first modification, especially on a (non-STI) WRX. But be prudent with compression tests when modifying a '25.
With the explanation, ichitaka, I gotcha.
Lexus LFA breaks cover before Tokyo unveiling MR2fan Other Vehicles & General Automotive Discussions 403 05-21-2021 03:49 PM
engine swap thread aspera Engine Swaps 231 03-15-2011 05:10 PM
Subie rear-engine student-rendering Axel Other Vehicles & General Automotive Discussions 5 12-31-2009 09:12 AM
Accurate Engine Impressions S2KtoFT86 Other Vehicles & General Automotive Discussions 1 12-16-2009 12:05 PM
No Subaru FT-86 for Australia! And currently no Subaru AWD version production plans. Edi BRZ First-Gen (2012+) — General Topics 103 10-27-2009 02:27 PM
