Old 11-13-2013, 12:06 PM   #99
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
Thank you DSS for making such an awesome mod for our car. I installed the CF shaft for my AT this past weekend. My butt dyno said the car feels more peppy and was a good compliment to the Perrin Crank Pulley. The most noticeable difference for me was in 6th gear on the interstate going up a slight hill as normally i would either have to down shift to comfortably keep the same speed or step on the accelerator that much harder in 6th. I no longer really need to down shift and now i can go lighter on the accelerator in 6th. I have nothing but great things to say about the CF shaft and fitment even with a 3" exhaust setup.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
The Following User Says Thank You to ShadowSeraph For This Useful Post:
neutron256 (11-13-2013)
Old 12-21-2013, 07:23 AM   #100
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Just installed mine. So far everything is perfect, no increase in noise and or vibrations (although also installed Nameless FP/DP combo together with the DS which added loudness). The only concern, which mechanics pointed my attention to, is the lack of the protective cup on the carbon driveshaft. I allows dirt, liquid and chemicals from the road to contact the connection point of the DS with the gearbox, which is not good at all. They even recommended to cut the protective cup from the OEM driveshaft and weld it to the DriveshaftShop one. I declined for the time being but now thinking about protective measures for the DS... Let's see how it survives winter.
Efferalgan is offline   Reply With Quote
Old 01-18-2014, 10:16 PM   #101
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Long term comments
Guys
Any long term reviews on the AT CF driveshaft? Any problems, noise or vibration increases?
F1fletch is offline   Reply With Quote
Old 01-19-2014, 07:12 AM   #102
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Who is "they"?? Some shop that installed for you was saying they wanted to cut stock protective cup off???
Old 01-19-2014, 01:06 PM   #103
Efferalgan
Yep, the mechanics - they said they can do it if I'm not planning to return to the stock DF. They said that without this cup the carbon DF connection will survive 2 winter seasons maximum.
Old 01-20-2014, 01:45 PM   #104
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I've had zero issues so far. Come spring I'll be pulling the shaft to inspect it and see how it's held up to winter driving conditions.
Old 01-20-2014, 02:52 PM   #105
utekineir
blowhard
Drives: frs, project forester
Last time I looked my cup was still there
utekineir is offline   Reply With Quote
Old 01-20-2014, 04:52 PM   #106
OICU812
Just a dude
OICU812's Avatar
Its part of the stock shaft though... the DDS and others do not have this front cup to keep contaminates out..
Old 01-20-2014, 06:48 PM   #107
utekineir
blowhard
I'll look at what's on the shelf in the garage when I get a chance
Edit
You guys are right. I'm dumb
2 halfs
Old 03-05-2014, 10:20 AM   #108
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Anyone received one, or two carbon dss that vibrated/noisy and were not able to run it?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 03-23-2014, 12:55 PM   #109
subaruindo
Drives: subaru brz satin white
mine is aluminium, and vibrate above 160kmh, going to take it off and put the original back
subaruindo is offline   Reply With Quote
The Following User Says Thank You to subaruindo For This Useful Post:
kiichiro (03-23-2014)
Old 03-23-2014, 01:18 PM   #110
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Ok so alum is off
Carbon or bust
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 03-23-2014, 07:34 PM   #111
Malt
Drives: 2015 WRX
Just unbolt the rear of the driveshaft and rotate it 90 degrees and try again. This is common and occurs with the stock driveshaft if its not installed in the same position as it was stock.
Originally Posted by kiichiro View Post
Ok so alum is off
Carbon or bust
I wouldn't write it off just yet, a simple rotation of the shaft should correct his issue.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
Wonderbar (03-23-2014)
Old 03-23-2014, 07:42 PM   #112
tonystewart
I wish it was that easy
Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! F-T Exterior Parts - The Rest 285 08-24-2015 05:42 PM
Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) master345 Cosmetic Modification (Interior/Exterior/Lighting) 56 05-04-2014 12:10 PM
The Driveshaft Shop Custom Axles and Shafts Sportsguy83 Engine, Exhaust, Transmission 26 01-11-2013 05:55 PM
Automatic Carbon Fiber Driveshaft? Yes! RallySport Direct Engine, Exhaust, Transmission 13 12-15-2012 01:40 AM
