Old 03-15-2014, 06:48 PM   #519
Pete156
I like to eat!
Originally Posted by PNW FRS View Post
So, took FRS in for 15K service... asked them to check out the "rattle" noise from trunk area -- especially bad when rear seat back is down... going over speed bumps or bumpy roads. Thought this was somehow related to all the posts about the rear deck metal.
They found the noise to be in the rear hatch latch. They made some adjustments... and voila... the noise is gone.
Your FRS is a hatch back?
Pete156 is offline   Reply With Quote
Old 03-15-2014, 06:54 PM   #520
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Originally Posted by extrashaky View Post
This JUST STARTED in my car yesterday, and I hadn't even thought to look for a thread on it before I just happened to see it here today. I love this board.
Did you check my DIY to fix your problem?
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 03-15-2014, 07:19 PM   #521
extrashaky
Drives: 2014 BRZ Limited
Yep. It's already on my to-do-it-myself list. Just need to pick up some lithium grease.
Old 03-15-2014, 07:38 PM   #522
Mikepage
Mikepage's Avatar
Good!
o= FR-S =o
Old 03-21-2014, 05:13 PM   #523
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Damn I have this issue too I think .. is it like a small ticking noise at every little bump?
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 03-21-2014, 06:14 PM   #524
kodyo
Drives: Scion FR-S
Yeah, comes from the rear. Easy fix and can be done in 10 minutes without removing anything.
kodyo is offline   Reply With Quote
Old 03-21-2014, 06:21 PM   #525
Young_makaveli
Drives: 2013 frs
Really ? Mind pointing me in the right direction?
I've seen the one mike posted about "cracking" the welds and spraying lube
I would like to try something else before going to that fix
Old 03-21-2014, 06:27 PM   #526
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
You should first try "Quick and Easy Fix" that's explained in the first post. It should take only a minute to do. Mine didn't make that noise for 1 1/2 year now since then.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
Young_makaveli (03-21-2014)
Old 03-21-2014, 07:30 PM   #527
kodyo
Drives: Scion FR-S
http://www.ft86club.com/forums/showp...&postcount=459
http://www.ft86club.com/forums/showp...&postcount=487
Just look where any two pieces of metal come together and then do what I stated above. Do it just hard enough hear the "click/pop/crack". It should not scratch paint or cause any permanent deformation.
The Following User Says Thank You to kodyo For This Useful Post:
Old 03-21-2014, 07:47 PM   #528
Young_makaveli
Drives: 2013 frs
Thanks guy I will try this as soon as the weather permits it
Old 03-22-2014, 01:05 AM   #529
Mikepage
Mikepage's Avatar
Rear Deck "popping/clicking/tapping/ticking" noise.
And if the solution below did not fix your noise... try mine
o= FR-S =o
The Following User Says Thank You to Mikepage For This Useful Post:
Young_makaveli (03-22-2014)
Old 03-22-2014, 02:36 AM   #530
Young_makaveli
Drives: 2013 frs
And of the solution below did not fix your noise... try mine
Merci Mon ami
The Following User Says Thank You to Young_makaveli For This Useful Post:
Mikepage (03-22-2014)
Old 03-28-2014, 02:43 AM   #531
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Have any idea what they did? Mine annoy the hell outta me.
husker741 is offline   Reply With Quote
Old 03-28-2014, 02:46 AM   #532
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Theres a TSB for it...
Fett4Real is offline   Reply With Quote
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 02:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
