Old 03-21-2014, 09:44 AM   #1
aagun
Drives: 86
good oil for my 86
hi all
i use my car like a track , i drive it every day 300 km with 140 -180 km/h so it rev highly to 4.5 - 5 k . so that is extremely condition for 4 cly car . the weather is hot in my country . it is min 5c im winter and to 50c at summer .
0w20 is recommended oil for D4s boxer engine . hard to find it .
so there is 3 kind of oil in my mind
0w30 , 5w30 and 5w40.
what is the good one of my condition. i use 5w30
thx
aagun is offline   Reply With Quote
Old 03-21-2014, 01:49 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
You should be fine with 5W30. Invest in a simple oil cooler (Forester XT DIY or Cusco) to prolong health of engine in hot temps.
-alex
Old 03-21-2014, 01:56 PM   #3
wheelhaus
wheelhaus's Avatar
Ading to what mav said, any major brand full synthetic should be fine, I also recommend an oil cooler.
Old 03-24-2014, 08:56 AM   #4
aagun
Drives: 86
-alex
i test my 86 under 3700 RPM load (intake and air temps is 31) @ 140km cursed , the oil temp is 103c and water temp is 87- 90c .
under 4500-5000 RPM load ,same intake and air temps @180 - 200km < the oil temps goes up to 109c .
in the summer will be more then 115c under 4500rpm loads .
so do i have use external oil cooler?
Old 03-24-2014, 02:35 PM   #5
CSG David
CSG David's Avatar
Not absolutely necessary if you do not plan to track your car. It is recommended to have one if you do intend to do performance driving.
I always recommend high quality oil for tracking as it will effectively continue to lubricate your engine properly at elevated temperatures. Motul 300V 0W20 for tracking and DD. Motul 8100 0W20 for spirited driving and DD.
The Following User Says Thank You to CSG David For This Useful Post:
OICU812 (03-24-2014)
Old 03-24-2014, 05:16 PM   #6
Nasty Sausage
Nasty Sausage's Avatar
Drives: '13 Asphalt FRS 6MT, '04 IS 5MT/LSD
I use Amsoil 0W20 with great results in this Florida heat.
Nasty Sausage is offline   Reply With Quote
Old 03-24-2014, 06:16 PM   #7
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
I'm a fan of Eneos Sustina 0w20.
XanRules is offline   Reply With Quote
Old 03-24-2014, 08:47 PM   #8
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
for me i prefer the oil that lubes the crank case
driftartist is offline   Reply With Quote
Old 03-27-2014, 05:37 AM   #9
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
How you check the above data? you have the interface cable?
gzpermadi is offline   Reply With Quote
Old 03-27-2014, 01:41 PM   #10
aagun
Drives: 86
i use android APP called torque with BT OBD2 scaner . also i have tech-steam program.
Old 03-29-2014, 11:11 AM   #11
Simply_the_best
Tom's Racing ADDICT
Simply_the_best's Avatar
Drives: 2013 Toyota 86, 1999 Toyota Corolla
I run Eneos 0w-20. I like this stuff
Check out my car journal!
"Straights are for fast cars. Corners are for fast drivers."
Instagram: @simply_the_best
Simply_the_best is offline   Reply With Quote
Old 03-31-2014, 04:03 AM   #12
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I've been reading factory oem subaru/toyota oil is pretty good.
fooddude is offline   Reply With Quote
Old 03-31-2014, 04:25 AM   #13
ZionsWrath
Thanks
ZionsWrath's Avatar
I've been running eneos sustina, going to use Motul 300V 0W20 when i start tracking next month ¯\_(ツ)_/¯
Just a good vid *sail* Realm Off-Topic Lounge [WARNING: NO POLITICS] 4 06-28-2013 11:55 PM
Would the FR-S be a good first car? alexb99 Scion FR-S / Toyota 86 GT86 General Forum 98 02-20-2013 11:00 AM
It was a good run Celica00 Scion FR-S / Toyota 86 GT86 General Forum 49 02-11-2013 11:33 AM
HEY WAS GOOD scion1 Southwest 2 12-17-2011 10:26 PM
This looks good... iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 15 11-24-2010 03:59 PM
