#505 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
#506 |
Drives: Toyota GT86
#507 | |
Drives: FT86
The Ecuflash software allows you to read your car ECU ROM via the tactrix adapter and save it, edit it then reflash it to the car If you have the definition files for the ROM (table structure) then you can use ECUflash software to modify fueling ignition timing and many other tables to increase the performance and drivability of your stock car. Do not expect huge gains on a stock N/A car maybe 10hp If you have other mods headers intakes ect you can change tables/parameters to suit these mods and possibly pick up maybe 20hp over an untuned car retune for e85 maybe 30hp Any re-tuning even on a non turbo/supercharged car (ie N/A) requires much knowledge and skill , time and patience and the ability to interpret engine parameter logs. The ecuflash software will not "tune" your car for you. 99% of people will require a source of pre tuned ROM's, and at best may be able to fiddle with the odd table to tidy something up. note I am in the 99% I have a tactrix as a backup to my Open flash tablet Tectrix/openflash is working at present for read/write/edit but logging still a work in progress as I understand it. It works but limited access to rAM addresses for parameter logging, depending on your rom type. Last edited by steve99; 03-17-2014 at 11:01 PM. |
#508 |
Drives: Pavement MT GR86
What is left as far as logging goes? Specifically a and b series usdm mt roms....
Hoping for a rough estimate for when I can get my car tuned.
GR86 MT premium
#509 | |
Drives: FT86
Just install a SD mini card in tactrix adapter and have a suitable logcfg file in the root directory and your good to go. If your on C or G series rom their are a couple of logcfg files posted a couple of pages back. You only need to have the same ROM series ie C or G , revisions loke A01 BO1 700 are compatable just the last letter is significant. Unfortunatly for other ROM types i dont have memory addresses. The logcfg file is just text. |
#510 |
Meaning flkc, iam, afr targets, Load, fueling, pulse widths ect????
Are they still in beta or alpha stage?
GR86 MT premium
#511 | |
Drives: FT86
anything with a ; at start of line is comment or commented out It will create a csv file on the sd card , new one each time logging starts Starts when rpm not 0 and stops when rpm goes to 0. Mate don't know about alpha beta, its open source. no guarantees its use at your own risk stuff. If you want something more user friendly with safeguards to stop writing wrong ROM,s and with support and backup I would suggest you look at OFT, Ecutek or a tuner. not being nasty it just the way it is.If you want more parameters you will have to beg/borrow/ask on here and or Romraider/ecuflash forums. only the guru's dissassembling code can dig these out. I personally have OFT and use tactrix as a backup device and for faster logging/flashing but if it all goes pear shaped I have the oft as a fallback or comparision device. *************************************** type = obd protocolid = 6 ; ISO15765 mode23txaddrwidth = 4 ; mode23 req format info mode23txlenwidth = 1 ; mode23 req format info mode23rxaddrwidth = 0 ; mode23 req format info mode23uds = 1 ; lets OBD channels know you are using mode23 UDS sortpids = 1 ; sort these PIDs by value to potentially make for fewer requests (=faster) calcsampinterval = 1000 ; timing parameter - leave as is - will make default for release version ; here are some known RAM addresses for ROM ZA1JA00C ; addresses are likely different for other ROMs ; you can comment out ones you don't need, but keep in mind that with ; the block read nature of UDS, reading extra parameters that have ; adjacent addresses comes at very little bandwidth (=sample rate) cost paramname = RPM paramid = 0xFFF8DB80 isfloat = 1 paramname = accel_pedal_angle paramid = 0xFFF8922C isfloat = 1 paramname = throttleplate_angle paramid = 0xFFF89030 isfloat = 1 ;Colby paramname = MAF_default paramid = 0xFFF8DB90 isfloat = 1 ;TD-d paramname = MAF_Tdd paramid = 0xFFF89114 isfloat = 1 paramname = load paramid = 0xFFF8DB6C isfloat = 1 paramname = IAT paramid = 0xFFF8DB8C isfloat = 1 paramname = advance paramid = 0xFFF8DB88 isfloat = 1 paramname = KC_learned_value paramid = 0xFFF8B0AC isfloat = 1 paramname = fine_knock_correct paramid = 0xFFF8B14C isfloat = 1 paramname = feedback_knock_correction paramid = 0xFFF8B0B0 isfloat = 1 paramname = AFR paramid = 0xFFF8932C isfloat = 1 scalingrpn = x,14.7,* paramname = STFT paramid = 0xFFF8DB74 isfloat = 1 paramname = LTFT paramid = 0xFFF8DB78 isfloat = 1 paramname = MAP paramid = 0xFFF8DB7C isfloat = 1 paramname = IAM paramid = 0xFFF816F4 isfloat = 1 paramname = speed_KMH paramid = 0xFFF8DB84 isfloat = 1 paramname = cool_temp paramid = 0xFFF8DB70 isfloat = 1 paramname = fuel_press paramid = 0xFFF8DBA0 isfloat = 1 paramname = lambda paramid = 0xFFF8DBA4 isfloat = 1 paramname = O2_volt paramid = 0xFFF8DBA8 isfloat = 1 paramname = O2_curr paramid = 0xFFF8DBB8 isfloat = 1 paramname = cat_temp paramid = 0xFFF8DBBC isfloat = 1 ;paramname = ECU_volt ;paramid = 0xFFF8DBC0 ;isfloat = 1 paramname = abs_load paramid = 0xFFF8DBC4 isfloat = 1 paramname = requested_torque paramid = 0xFFF8B490 isfloat = 1 paramname = engine_load paramid = 0xFFF89148 isfloat = 1 paramname = ignition_total_timing paramid = 0xFFF8ADF8 isfloat = 1 paramname = requested_torque paramid = 0xFFF8B490 isfloat = 1 paramname = gear paramid = 0xFFF895D9 databits = 8 ; experimental parameters below this line ;E_AF_Learning_1_A_StoredExt_E44 FFF815C4 paramname = AF_Learning_1_A paramid = 0xFFF815C4 isfloat = 1 scalingrpn = x,100,* ;E_AF_Learning_1_B_StoredExt_E45 FFF815CC paramname = AF_Learning_1_B paramid = 0xFFF815CC isfloat = 1 scalingrpn = x,100,* ;E_AF_Learning_1_C_StoredExt_E46 FFF815D4 paramname = AF_Learning_1_C paramid = 0xFFF815D4 isfloat = 1 scalingrpn = x,100,* ;E_AF_Learning_1_D_StoredExt_E47 FFF815DC paramname = AF_Learning_1_D paramid = 0xFFF815DC isfloat = 1 scalingrpn = x,100,* ;E_AF_Learning_Airflow_Range_CurrentExt_E61 FFF8A788 paramname = AF_Learning_Range_Current paramid = 0xFFF8A788 databits = 8 scalingrpn = x,100,* ;paramname = evap ;paramid = 0xFFF8DBAC ;isfloat = 1 ;broken ;paramname = fuel_level ;paramid = 0xFFF8DBB0 ;isfloat = 1 ;broken ;paramname = amb_press ;paramid = 0xFFF8DBB4 ;isfloat = 1 ;-------------triggers--------------- conditionrpn = RPM,0,> action = start conditionrpn = RPM,0,== action = stop |
#512 |
I have the OFT, the reason why I am asking is because I want to use a tuner and not pay for another solution like EcuTek.
I've used RR and ecuflash with my wrx and while it wasn't too difficult I am still not comfortable self tuning nor disassembling code. I want to go to my tuner and say, yes ecuflash /RR is ready to use to tune my car. Not, well half the parameters are missing and there is only 3-4 errors each time we flash.
GR86 MT premium
#513 | |
Drives: FT86
Why won't tuner use OFT ?? with the enhanced logging now available It seems a bit confusing. Using OFT or Tacrix will still be editing with Romraider. Both flash same ROM. I don't thing you ever going to get a guarantee from anyone on parameters unfortunately, although you could use oft to check them. |
#514 |
I haven't played with the advanced logging on the OFT yet.
Can you get a wideband o2 output on the OFT? Honestly I don't think he's used oft before, most tuners outside of this and BMW don't know what it is. I went looking for someone experienced with ecuflash and RR because they worked with what I have already. I have two options within driving distance and neither have tuned an 86 yet, one tunes almost daily the other less often but has a BRZ so should be comfortable with it soon.
GR86 MT premium
#515 | |
Drives: FT86
#516 |
No I just want to verify the stock sensor..... Keep hearing things about it being up to a full point off.
Nameless headers and downpipe (op/fp) And probably GS intake. I live at 4500ft so canned tunes don't work well
GR86 MT premium
#517 |
Drives: FT86
#518 |
Shiv said he was getting a wideband sensor so he could make a kit, much cheaper as all it needs is a sensor and the OFT takes care of turning raw values into equivalent AFR values.
| Close | iJason | Member's Car Journals | 1 | 08-04-2013 08:26 PM |
| Close | pche | Engine, Exhaust, Bolt-Ons | 3 | 08-04-2013 02:04 AM |
| Sorry. please close. | finch1750 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-31-2013 01:00 AM |
| please close | abutterman | Wheels and Tires | 0 | 07-05-2013 09:40 AM |
