Old 03-20-2014, 01:34 AM   #3893
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Won't be able to dyno on Friday, their header and overpipe isn't fitting quite right and it's causing the overpipe to to press against the head.
Here's a link to my post with a pic. Anybody else run into this?
http://www.ft86club.com/forums/showt...99#post1612799
RiskyTrousers is offline   Reply With Quote
Old 03-20-2014, 01:48 AM   #3894
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
@Deathreaper I would recommend taking off most of the heatshield and loosening the op before taking off the stock headers.
Also remove and attach the fan clip before installing the nameless.
The rest looks good. As for torque, Go until snug. 22ft lbs will not be enough.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 03-20-2014, 02:53 AM   #3895
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by Sargy View Post
Any more coated pics from anybody?
Didn't realize how big these headers were until I saw them in person.
Only downside of it being coated is I can't see the detailed craftsmanship of this beauty.
Carlitoz3 is offline   Reply With Quote
Old 03-20-2014, 04:38 AM   #3896
StormTrooper
Also looks good in Chrome.....
GR86 MT premium
Old 03-20-2014, 08:59 AM   #3897
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Originally Posted by Deathreaper View Post
-Completely remove O2 sensors from OEM header (disconnect the entire wires)
-Remove OEM header
-Clean up area and contact points + install new gaskets (Look here for part # http://www.villagescionparts.com/sho...sembly=1103630)
-Install O2 sensors back into Nameless header (Should spacers be added or is there no point?)
-Lift engine 1-2 inches via oil pan (unbolt passenger side mount)
-Bolt Nameless header onto engine block (Anyone have the torque specs? Has anyone been able to use a torque wrench for those or is space too limited?)
-Use the 2 provided nut and bolts to attach header to front pipe
-Relocate fan connector with provided ziptie
Also - I usually grease most bolts and nuts I remove on a car before putting them back. I know it's not the same situation as an exhaust gets extremely hot, but would you guys apply a graphite grease or something similar to these various bolts and nuts?
My way in order:
-Disconnect O2 sensor plugs from where they are plugged in and detach them from the timing chain covers
-Remove OEM header
-Relocate fan connector (personal opinion is to route it up along the top see photo)
-Swap in over/front pipe in not already installed
-Install O2 sensors back into Nameless header ( cel spacer is a personal choice for the secondary o2 sensor)
-Wipe off with clean cloth when complete
-Before lowering back down and installing the skid plate check to make sure the exhaust is leak free
2superblus is offline   Reply With Quote
Old 03-20-2014, 12:35 PM   #3898
verts
verts's Avatar
Drives: '13 6MT Raven FRS
Header arrived and looks great! Too bad its snowing like a mofo here today (yay Canadian spring!) with temps going back down to the negative double digits. May have to put the install off a few days
verts is offline   Reply With Quote
Old 03-20-2014, 02:57 PM   #3899
Sargy
Long Distance Driver
Sargy's Avatar
Mine will arrive tomorrow.
interesting some people are saying the motor needs to be lifted 1-2 inches and some people are not lifting the motor at all.
Sargy is offline   Reply With Quote
Old 03-20-2014, 03:19 PM   #3900
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
unbolted one engine mount on the passenger side and lift the engine up about 1.5 - two inches for the over/front pipe install and it also allows easy passage and clearance for the header to be put in place.
Old 03-20-2014, 03:46 PM   #3901
w00t692
Drives: 2008 Civic Si
Originally Posted by wparsons View Post
I'm failing to see a difference in the two, except in how you're describing them.
Tuning runner length/diameter on an intake manifold to shift power does the exact same thing as tuning primary/secondary length/diameter on a header.
You optimize them so the harmonics work in your favour at the RPM range you want.
When you do this with a header the torque completely changes in very specific spots. When you do this with an intake manifold it changes EVERYWHERE.
w00t692 is offline   Reply With Quote
Old 03-20-2014, 04:09 PM   #3902
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
I didn't do it and should have. It would have been easier without a doubt. Before you install be sure to reroute the fan plug that is on the passenger side. Move it up or down(as I did.) when reinstalling be sure to get the header bolted to the engine before you tighten anything else on the exhaust. Work front to rear after that.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 03-20-2014, 06:04 PM   #3903
14BRZ
14BRZ's Avatar
Drives: 2014 BRZ, 08 CBR600RR
Mine is very close and rattles under load. And the header was not completely flat. Takes more like 35 ft lbs to get the flanges flush with the block. I feel like the outlet of the header is up too high. I have perrin motor mounts which don't raise or lower the engine at all
I put some grimmspeed thick header gaskets on with the header and I still feel like theres a small leak
14BRZ is offline   Reply With Quote
Old 03-20-2014, 06:10 PM   #3904
StormTrooper
There's another person who is having that issue, @RiskyTrousers
The only noise I have is the vvt resonance in the muffler aka cheap Honda exhaust sound.
GR86 MT premium
Old 03-20-2014, 08:25 PM   #3905
slava
slava's Avatar
Drives: brZed
Should have dyno numbers for you nerds tomorrow.
slava is offline   Reply With Quote
Old 03-21-2014, 12:56 PM   #3906
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
We're 13 hours into March 21st 2014, please don't torture us.
raul is offline   Reply With Quote
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
