Old 03-19-2014, 02:35 AM   #1
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Bumpstop Question
So I recently just got a set of used Eibach sportline springs and it didn't come with the bumpstops. Can I just re-use the old/oem bumpstops or is the replacement ones are needed?
Bach415 is offline   Reply With Quote
Old 03-19-2014, 08:50 AM   #2
sklimo
When I put in my H&R super sport springs trimmed stock bump stop.
Bach415 (03-19-2014)
Old 03-19-2014, 10:27 AM   #3
Bach415
Bach415's Avatar
How much did you trim it and how much lower for the springs? I think I may have to trim more due to the amount of drop it gives. If so then I may just contact the seller and see if he has the bump stops
Sent from my SM-N9005 using Tapatalk
Old 03-19-2014, 10:42 AM   #4
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
I followed Hotchkis's install instructions with my RS-R's
https://www.hotchkis.net/_uploaded_f...ns5218file.pdf
^^^PDF warning
Page 10 shows where to cut
supramkivtt2jz is offline   Reply With Quote
The Following User Says Thank You to supramkivtt2jz For This Useful Post:
Old 03-19-2014, 10:55 AM   #5
sklimo
.75" from bottom
Old 03-19-2014, 12:29 PM   #6
Bach415
Bach415's Avatar
Thanks for the info. I think I'll try contacting the seller first, then Eibach to see if I can get the bumpstops before deciding to cut the oem ones.
Old 03-19-2014, 12:53 PM   #7
sklimo
From what I read when bought new they come with new bumptops. You might need to get a set
Old 03-19-2014, 01:01 PM   #8
Bach415
Bach415's Avatar
Yeah they do come with bumpstops new. Gonna see if the previous owner still have it first. I don't want to go through all the trouble of getting new bumpstops if the previous owner still has them.
The Following User Says Thank You to Bach415 For This Useful Post:
sklimo (03-19-2014)
Old 03-19-2014, 05:00 PM   #9
DAEMANO
Time Traveller
Just so you know, replacement bumpstops for this kit costs $30 ea. that's $120 total, so you should try to get them from the original owner as part of the spring purchase if you can. You can get others from Koni, but I'm not certain if they'll match the exact dimensions and durometer of the original Eibach bumpstops.
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 03-19-2014, 05:45 PM   #10
Gunman
Drives: 2019 Mazda Miata RF
Slight thread jack... to those that have cut the bump stops, how did you do it? my bandsaw is in storage, so can this be done with a hacksaw? my sawz-all?
Old 03-19-2014, 05:53 PM   #11
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I cut mine with a box cutter. Exacto would work. I wouldn't recommend using a saw as you'll end up with ragged chewed up cut. Exacto or surgical blade, I'd recommend using.
The Following User Says Thank You to solidONE For This Useful Post:
Gunman (03-19-2014)
Old 03-19-2014, 06:25 PM   #12
Bach415
Bach415's Avatar
REALLY?!?! Thank you for the heads up. That's a lot just for bumpstops. Original owner said he may have it, just gotta look for it so I'm hoping he still has them.
Old 03-19-2014, 06:44 PM   #13
DAEMANO
Time Traveller
No probs and best of luck. If you have to end up ordering from Eibach, I can provide the part numbers. PM me.
Old 03-19-2014, 06:45 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I just trimmed an inch off mine when I had sportlines, I forgot to install the new ones I think. Gave the springs away with the bumpstops long ago though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
Ebiach Sportline lower spring bumpstop questions benlaz88 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-16-2014 03:28 AM
STX question JerryMichaels7 Tracking / Autocross / HPDE / Drifting 6 01-22-2014 11:52 AM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
Almost there.....but question VENOM~ CANADA 25 08-22-2012 05:39 PM
