#715 |
Drives: '13 BRZ Ltd
#716 |
Drives: 2014 BRZ
Thanks guys. Hard to do a comparison because I only drove the car at Toledo on concrete on nearly new Rivals, with the car setup for Hankooks. This caused it to have quite a lot of understeer which we never quite got out. I would say that Danny's current setup on asphalt is better than that particular weekend, but that's not a fair comparison. What I do know is that the car feels fantastic and easy to drive. I'm finally starting to get used to the idea that I have grip going through corners and that I don't really need to slow down so much.
| The Following User Says Thank You to piknockout For This Useful Post: | Scooby South (03-20-2014) |
#717 | |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
#718 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Dixie doesn't lend itself well to RS3s I found. I drove on RS3 and Z2s this weekend and my RS3s, even when hot, were awful
#719 |
Conedancer
Drives: 2013 Subaru BRZ SWP
yeah.. learned that RS3's aren't very Asphalt Friendly. Dunlap's do a better job on Asphalt IMO..
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
| The Following User Says Thank You to Scooby South For This Useful Post: | EN2_Squirrel (03-20-2014) |
#720 |
For those who change their tires when they get to the venue how do you load your car? The trunk is full of tools.
#721 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
So I pulled the trigger on konis and RCE tarmacs, my follow up question is regarding LCA's. Am I correct in assuming that if I were to use the Whiteline LCA's that have multiple mounts for the rear sway bar bushings, I would only be legal in STX if the bushings were mounted in the same location as on the oem LCA? I attached a picture of the Whiteline LCA from FT86SF.
#722 |
Stand one up behind the Passenger seat, stack two behind the driver seat and one on the truck upside down. Tool bag and extras go in the one in the trunk, jack on the side. push passenger seat back to keep tires from sliding around.
#723 |
Dodging cones
All 4 fit in the back seat area, at least with 7" wheels. Lay 2 down behind driver, stand other two behind passenger. Trunk is completely open at that point.
#724 |
Yeah, 9" with 255's you can get 3 to stand up but thats about it.
#725 | |
Drives: 2021 Supra / 2022 Tundra
TomR
#726 | |
Drives: BMW 135i, soon to BRZ
| The Following User Says Thank You to mrazny For This Useful Post: | Turkish (03-21-2014) |
#727 |
I think his question was referring to the option the Whiteline arms give with having 3 mounting points to modify motion ratio as well as 3 options of where to mount the swaybar link. Of those 3 options for both connections one of them is the stock geometry.
You can not change motion ratio, of course, so if you are using the stock mounting hole for the strut I would see no benefit in using anything other than the stock location swaybar hole. You would be moving the endlink off center from the swaybar rather than adjusting the arm length or anything. Also, the bushing rule for anti-roll bars is different than suspension arms. Bushing material, method of attachment and locating points are unrestricted as long as you don't cut holes to route bars or links, or modify suspension locators that would effect suspension and steering geometry.
| The Following User Says Thank You to SubiePig For This Useful Post: | Turkish (03-21-2014) |
#728 | |
Serial Cone Killer
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
