Old 03-20-2012, 04:33 PM   #15
dsgerbc
Drives: BRZ(sold), STI
Subaru OEM eccentric bolt has tick marks on the lip. I see none on that pic. To be fair - that pic above is the first semi-legible pic of the proper side of the bolt and all previous claims of 'no camber adjustment' weren't backed by anything other than words.
Old 03-20-2012, 04:34 PM   #16
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
Umm, you'll have to take my word for it...but the upper bolt is not eccentric for the BRZ. It usually is on subarus, but not this time. Maybe it'll change for the production cars, but it is not adjustable for the BRZ. Trust me.
- Andrew
Be careful, Andrew, you don't want to give away too much information too soon.
IIRC MotoIQ confirmed eccentric bolts were not used on the preproduction FR-S either a few months ago.
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 03-20-2012, 04:36 PM   #17
Originally Posted by oneday View Post
Interesting...so how is the camber adjustment going to happen for stock classers?
Hopefully they throw the usual adjustable bolt in for the production car. I'm with you...I'm really surprised it wasn't in there already since they've used an eccentric on every car I've seen up to now. It would be a pretty weak area to save on costs for a performance car and I'd think they know better, so I'm hopeful but it's speculation right now.
- Andrew
Old 03-20-2012, 04:41 PM   #18
dsgerbc
Yes, w/o a supporting picture.
Old 03-20-2012, 04:42 PM   #19
oneday
Opinionated
oneday's Avatar
Drives: Something Red
Ah, good to know...don't think I've ever seen the top of one of the eccentric bolts from Subaru before.
Yup...and I even posted the original story here when it came out...
Originally Posted by MotoIQ
The only adjustment in the front alignment is the toe which is typical. No provision for camber or caster adjustment is present on the stock car, at least this stock prototype!
Bizarre indeed. I hope they do the right thing too! Thanks for the insight.
Most of the cars I drive have nets for windows.
oneday is offline   Reply With Quote
Old 03-20-2012, 09:13 PM   #20
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Originally Posted by ZDan View Post
Don't see how 2mm swing would amount to 1 degree camber change, unless the top of the strut is fixed only 4.6" above the eccentric bolt?
It's not the distance from the bolt to the tophat that matters, it's the distance between the bolts. Think about it.
old greg is offline   Reply With Quote
Old 03-20-2012, 10:39 PM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
Ah , of course...
Heres hoping these cars get some front camber adjustability.
Old 03-21-2012, 01:30 PM   #22
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
or they could do it the toyota way
You can see a Scion Tc factory service manual at scionlife.com - it specifies an array of bolt sizes you can use in various combinations to achieve camber adjustment.
Perhaps to ease assembly/save costs, the cars will come without subaru style cammed bolts and all adjustments will be made with toyota/scion style 'crash' bolts.
I'm eagerly waiting for a look at the FSM's!
jdrxb9 is offline   Reply With Quote
Old 03-21-2012, 05:20 PM   #23
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
There are no multiple sized bolts like on most Toyota applications.
Most Toyotas have slotted struts and the smaller bolts are only for when you reach the max adjustability of the original bolts. Subaru uses cam-shaped bolts normally.
Looking at the parts diagrams for the FR-S, the upper bolt is definitely different than the lower, but it is hard to tell from the diagram whether it is a cam shape or not.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 03-21-2012, 05:44 PM   #24
jdrxb9
jdrxb9's Avatar
Jeff
Looking at the diagram posted in the other thread: http://www.ft86club.com/forums/showp...11&postcount=7
it does look pictorially like the bolts are a bit different but the PNC numbers for the top and bottom bolts are the same.
What are the part numbers called for by PNCs 43211K(RH) and 43212D(LH)?
Any chance that additional part numbers will be added for a particular PNC with a later release/update of the EPC?
Old 03-22-2012, 02:07 PM   #25
neveronlinefrs
Drives: 2011 Honda Fit
Good info! I figured they would use something allowing for a reasonable amount of adjustability, but have not seen anything concrete thansk for the info!
- John
neveronlinefrs is offline   Reply With Quote
Old 03-22-2012, 02:46 PM   #26
Jeff Lange
Jeff Lange's Avatar
PNC's are the same, but you can see that they have "No.1" and "No.2" listed as well, which typically means they are different, in some cases they may share the same PNC but they could be listed as "LOWER" and "UPPER" once you get the actual translation as well. In this case, they are different:
No.1 (RH and LH Upper) are part number SU003-02805.
No.2 (RH and LH Lower) are part number SU003-02818.
Jeff
Old 04-05-2012, 03:58 PM   #27
jdrxb9
jdrxb9's Avatar
See Jeff's update over in this thread - link.
