Old 03-18-2014, 09:54 PM   #29
ericvanderwoodsen
ericvanderwoodsen's Avatar
Drives: 2013 SWP Subaru BRZ Premium
Originally Posted by djdnz View Post
Why do I have to be so electrically incompetent!?! This sounds like something I'd like to do, but something I'd hate to have to do myself.
Dude, I feel the same way.
Looks like I'll have to pay someone to do this for me, any takers??
ericvanderwoodsen is offline   Reply With Quote
The Following User Says Thank You to ericvanderwoodsen For This Useful Post:
KelvinBRZ (03-19-2014)
Old 03-18-2014, 11:18 PM   #30
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Do you have to have the whole thing done in a day?
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 03-19-2014, 05:44 PM   #31
ericvanderwoodsen
Not really ,
Old 03-19-2014, 07:22 PM   #32
Acree
Acree's Avatar
I didn't know you were here local to DFW. I can have the boomerangs back to you same day. Shoot me a PM if you're interested.
Old 03-28-2014, 05:20 PM   #33
SPCorBUST
SPCorBUST's Avatar
bump for pics fully mounted on the car next to a stock brz. hopefully day and night shots...
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 03-28-2014, 05:34 PM   #34
Vis101
Vis101's Avatar
Drives: 2013 Limited BRZ
Bump on @Acree request
Sent from my HTCONE using Tapatalk
Vis101 is offline   Reply With Quote
Old 03-28-2014, 10:48 PM   #35
booyaka
Drives: 2013 Subaru BRZ
@Acree would you be willing to do it for folks out of state?
booyaka is offline   Reply With Quote
Old 03-29-2014, 03:12 AM   #36
RacerX
Drives: Subaru BRZ
I didn't know the boomerang LEDs were so underpowered.
I am so doing this. I do stuff like this all the time. I think I have some Arctic silver lying around too.
Why did you choose that regulator? They seem to have others that are cheaper, smaller, non-dimming, and more efficient. You don't need such a wide output voltage range. Like this one, so long as you don't mind soldering wires to a SMD.
http://www.luxeonstar.com/700mA-Non-...21-d-n-700.htm
Whats the Vf for the LEDs at 700mA BTW? Did you measure it?
RacerX is offline   Reply With Quote
Old 03-30-2014, 03:28 PM   #37
Acree
Acree's Avatar
Yep. But the same rule applies: you have to be able to have the headlights apart for a few days.
Old 03-30-2014, 03:31 PM   #38
Acree
Acree's Avatar
It is true there are other choices for this application. I personally chose the unit I did because it's a "potted" unit. In an automotive application, vibrations are the archenemy of solder joints. Since the wires are integrated into the housing, all of the mechanical stress is handled by the wire insulation and not the solder joint between the wire and the board. It's a few bucks more, but I believe it will be much more reliable in the long run. It eliminates one more potential point of failure. Call it insurance.
Old 03-30-2014, 07:43 PM   #39
RacerX
Drives: Subaru BRZ
Very good point! Nicely done!
Old 04-05-2014, 02:41 PM   #40
sirisvirus
Drives:
Red Boomerangs = One P!$$ed off BRZ Can it be done?
Sent from my Subaru BRZ Limited using plastic cup 2.0
sirisvirus is offline   Reply With Quote
Old 04-05-2014, 02:54 PM   #41
Acree
Acree's Avatar
Yep. Pretty straight forward.
Old 04-05-2014, 08:31 PM   #42
sirisvirus
Drives:
So what kind of led would you get to replace the factory ones? I kinda want mine to be either yellow, blue, or red.
Sent from my BRZ limited using plastic cup 2.0
brighter fog light bulb for BRZ? chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 17 01-11-2016 02:57 AM
Interior LED Dome Light Diffuser | DIY | 6X Brighter Dezoris Cosmetic Modification (Interior/Exterior/Lighting) 8 04-21-2013 09:59 PM
Brighter "Boomerangs" Jaylyons1 Mid-Atlantic 3 02-05-2013 08:53 PM
