Old 03-17-2014, 08:58 PM   #3851
Captain Insano
I'm not smoking anything. The dip is still there. Just smaller and moved left. Just like I said in that post. Was my post too long for you to have good reading comprehension or were you smoking something?
Captain Insano is offline   Reply With Quote
Old 03-17-2014, 09:19 PM   #3852
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
I'm totally smoking.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
The Following 2 Users Say Thank You to FrsDuke For This Useful Post:
Pistol (03-18-2014), Sonolin (03-18-2014)
Old 03-17-2014, 10:14 PM   #3853
Deathreaper
Drives: 2013 Scion FRS
with regards to the tune
"We will have a tune available in the next 2-3 weeks hopefully, but it will be in the form of an ECUtek tune that is locked to the car, but hopefully we are able to have it be open for modification at the end user level in case you want to have a tuner tweak any settings."
Deathreaper is offline   Reply With Quote
Old 03-17-2014, 10:29 PM   #3854
regal
Drives: Scion FR-S/Toyota Yaris
So basemap from the manufacturer but unlocked for a local dyno fine tuning. Call me old fashioned but this is the right way to do things, expensive but right.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
The Following User Says Thank You to regal For This Useful Post:
mad_sb (03-18-2014)
Old 03-17-2014, 11:57 PM   #3855
14BRZ
14BRZ's Avatar
Drives: 2014 BRZ, 08 CBR600RR
Did anybody have any fitment issues? I noticed with mine that the header isn't completely flat on the block side. When torquing it down, the 2 sides would fight each other until it bent and flattened out. I ended up using a small impact to get the flanges to touch and then torqued it to specs since originally it was leaking.
Also @Ryan@Nameless, I have your header and over/front pipe and the overpipe section is extremely close to the block like less than 1/8 inch away. I've adjusted the bolt on the tranny mount to its lowest setting and it rattles under heavy load.
Just letting you know in case your jig is a little off before you start your next batch..
14BRZ is offline   Reply With Quote
Old 03-18-2014, 12:05 AM   #3856
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
I have the header and 2.5dp and I have much more than 1/8 inch, didn't have issues with the flange either.
Just a very tight fit between the crank pulley and fan
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 03-18-2014, 07:51 AM   #3857
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by slava View Post
Replaced the 3" midpipe with the stock one. Still not perfect, but sounds a million times better. I think the right muffler would make it way better too. There's also an exhaust leak between the downpipe and midpipe that I need to fix.
Getting it tuned on Friday. No baseline info though.
I think if you stack a few more sets of wheels an tires in the garage the last bit of rasp will go away lol...
Seriously though, it doesn't sound bad at all. If you can bring the other midpipe with you and swap it over for a pull after the tune is done... I'm sure the community would be greatful and it would provide a very useful data point.
The Following User Says Thank You to mad_sb For This Useful Post:
Sportsguy83 (03-18-2014)
Old 03-18-2014, 07:58 AM   #3858
mad_sb
Originally Posted by StormTrooper View Post
I was pretty sure the stock tune was still on the rich side, although not as rich as some would think. Like 11.5 to 12 flat. And that 12.5 seems to be the NA sweet spot.
The tune they released was with stock afr aka 12 and under and said they did that to prove the header made power not just afr.
Back when my car was stock, it would run 13.2:1 through the midrange on the stock tune with IAM set to 1.0 and fuel trims zeroed out. Saw this many times. It did not start trending rich until after 6k.
Old 03-18-2014, 01:15 PM   #3859
StormTrooper
So how would leaning out the car with an intake make more power? I thought the car would start pulling timing North of 13:1 under high load.
Was the 6k rpm enrichment drastic?
GR86 MT premium
Old 03-18-2014, 03:29 PM   #3860
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
@14BRZ I just installed the header with the 3" OP/FP and don't have any rattle.
Dustin is offline   Reply With Quote
Old 03-18-2014, 04:07 PM   #3861
sato
sato's Avatar
Drives: Dodge Patitas
Video please
Sent from my C6906 using Tapatalk
sato is offline   Reply With Quote
Old 03-18-2014, 04:22 PM   #3862
w00t692
Drives: 2008 Civic Si
If the dip was shifted it would be of similar rpm range. Header's do not really shift power. That's usually something an intake manifold would do as you tune the resonance and harmonic benefits of it.
As far as if a tune is rich or lean, most stock tunes run, generally, on the rich side. Some cars might run differently than others, but there's a variety of reasons for it, usually engine longevity and catalytic converter life.
They might run relatively leaner in the midrange and richen up the last 1000 to 1500 rpms. Safe afr's for all motor (not a true rule of thumb but this motor, but moreover a rule of thumb for engines in general) are between 12.5 and 13.2 at WOT. Some engines lean towards the 12.5 side to make power, while others make more and more as you lean them out past 12.8:1.
Still waiting to see some dyno's from someone in here
w00t692 is offline   Reply With Quote
Old 03-18-2014, 04:24 PM   #3863
Captain Insano
So you dont think headers can shifter the peaks or valleys of power in the rpm range? Interesting theory.
The Following 2 Users Say Thank You to Captain Insano For This Useful Post:
raven1231 (03-18-2014), wparsons (03-18-2014)
Old 03-18-2014, 04:28 PM   #3864
raven1231
OLD FASHIONED!!!!
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
