Old 03-10-2014, 05:09 PM   #351
JS + BRZ
Drives: 2010 MS3
Woot woot.
The Following 2 Users Say Thank You to JS + BRZ For This Useful Post:
fooddude (03-10-2014), yomny (03-10-2014)
Old 03-11-2014, 12:44 AM   #352
JS + BRZ
Drives: 2010 MS3
So if I get two camber bolts, can I add in some negative camber? I have 245 40 rs3 on my +35 rpf1s.
Thank you!
Sent from my SCH-I605
Old 03-11-2014, 05:22 AM   #353
Squishy86
Squishy86's Avatar
Drives: Your Car
Camber bolts will give you about a degree to a degree and a half. I did that and almost maxed out my camber plates for 2.5 degrees.
Squishy86 is offline   Reply With Quote
The Following User Says Thank You to Squishy86 For This Useful Post:
JS + BRZ (03-11-2014)
Old 03-11-2014, 12:14 PM   #354
JS + BRZ
Drives: 2010 MS3
Is there a difference in camber I can get with 14mm and 16mm bolt?
Old 03-11-2014, 01:24 PM   #355
Squishy86
Squishy86's Avatar
Drives: Your Car
Have looked at your struts before? You know the part where the two bolts that connect the knuckle to the strut? The bottom bolt is 14mm and the top bolt is 16mm. When you install your "camber bolt" its the same thing as the bottom 14mm bolt but now you place it through the top. So now you have 14mm bolts on both the top and bottom. The difference is while the bottom hole is fitted for a 14mm bolt the top one is not which gives you some play room to move the hub. Place the new bolt in, push the hub in for max cambers, and tighten that shit to 119 ft*lbs. Its not going anywhere.
I don't recommend however adjusting camber like this. Its best just to max it out and if you want more or less use top camber plates. A degree will be plenty for daily.
Old 03-11-2014, 01:29 PM   #356
JS + BRZ
Drives: 2010 MS3
I have not actually. haha Thanks for the information.
Just found a local bud who is selling his brand new 14mm whiteline bolts. I'll use that and get the alignment done.
Thanks again!
Old 03-11-2014, 01:38 PM   #357
VuDism
NASIOC: AzNSTiImpreza
VuDism's Avatar
Originally Posted by fooddude View Post
Just wanted to know: who has these available in gunmetal?
www.oakos.com
VuDism is offline   Reply With Quote
Old 03-13-2014, 09:12 PM   #358
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Finally put my wheels on today.
17x9 +35 RPF1 wrapped in 235/40/17 Kumho KU31. Nuts are Muteki Closed End.
The front is a bit monster truck mode at the moment but that'll be fixed on tuesday when the camber bolts and Eibach Pro Kit springs go on.
Wise is offline   Reply With Quote
Old 03-16-2014, 07:46 PM   #359
VuDism
VuDism's Avatar
snowing
Rain. Sun. Snow. Daily Driver.
17x9 +35 : 245/40/17 Hankook Ventus S1 Noble 2
RS*R Super down Springs
Whiteline camber bolt. ~ -1.6 front camber
Old 03-17-2014, 12:37 AM   #360
ikarus
Drives: SWP BRZ 6MT
Just got 17x9 Enkei RPF1s in matte bronze, wrapped in Bridgestone Potenza Pole Position S-04 in 245/40/17. Loving it!
ikarus is offline   Reply With Quote
The Following 3 Users Say Thank You to ikarus For This Useful Post:
akahenry (05-29-2015), fatoni (03-17-2014), fooddude (03-19-2014)
Old 03-17-2014, 10:30 AM   #361
Scottemad123
Drives: 2014 SWP BRZ Limited
Thank you!
Curious for side shots as I would have to run stock suspension for a while as well. Looks good so far!
Scottemad123 is offline   Reply With Quote
Old 03-17-2014, 10:59 AM   #362
JS + BRZ
Drives: 2010 MS3
Here you go!
The Following User Says Thank You to JS + BRZ For This Useful Post:
Scottemad123 (03-17-2014)
Old 03-17-2014, 01:06 PM   #363
VuDism
VuDism's Avatar
Old 03-17-2014, 01:10 PM   #364
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Originally Posted by VuDism View Post
Nice, I'm interested in seeing more white twins on the gunmetal RPF1's...
leicaboss is offline   Reply With Quote
The Following User Says Thank You to leicaboss For This Useful Post:
VuDism (03-17-2014)
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
