#995 | |
Pilot SS are a good street tire that's fun for auto-x and track. There are stickier tires but the Michelin's do everything pretty well. For an 8 inch wheel, 235 or 245 would be a good width. - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | psyclone07 (03-16-2014) |
#996 | |
Drives: WRB BRZ
Thank you! Going to look into some rpf1's right now. Trying to find a good balance. |
| The Following User Says Thank You to psyclone07 For This Useful Post: | Racecomp Engineering (03-16-2014) |
#997 |
Drives: 2013 BRZ, 1979 Scirocco 16v
Read every post… such a good thread :respect:
I recently threw my nearly stock BRZ with Tein Street-Flex coilovers, 3/4 tank of gas and some ballast to mimic me in the driver's seat up on some scales. At a nearly stock ride height (maybe 10/20mm lower), 26 inches from the edge of the fenders down to the ground, it came in around LF:753 RF:780 LR:633 RR:591 with no ballast and weighed in at 2757lbs. After messing around with the coilovers, we were able to even the fronts out for the most part, but still had a hard time getting the RR to get even close. I can't remember the end results because I was enjoying a few too many adult beverages but, the LR was about 680 and the RR was 630. Long story short, I can use these scales whenever, I'm obviously going to try and get it even better (Cross weight was 50.2%) (Front weight 55.3%) and Left to right was nearly dead on. I was shocked to see just how well this car was balanced… To bring up that RR weight I'm guessing I gotta lower the ride height minimally on the RF and LR? Thats what I tried and it seemed to work, but we ran outta time and packed it all up. (I have some pretty basic suspension knowledge, please shed some light!)
#998 | |
Drives: MT WRB BRZ Limited, 2007 911s
And a hat tip to @Racecomp Engineering. Installed RCE yellows with the setup and the difference is night and day. |
#999 | |
Drives: WRB BRZ
Funny because I'm looking at the gunmetal ones for my WRB brz. Heh your in CT as well! Out of curiosity what size did you go with. I'm wondering if 17x9.5 is overkill or would 17x8 be more appropriate. Or even 18's x ???? for a little aesthetic reasoning. What offset did you go with? |
#1000 | |
http://www.ft86club.com/forums/showp...9&postcount=34 Edit: and I assure you the gunmetal looks much better in person than it does in pictures. They're stunning in person. |
#1001 | |
Drives: 2013 Premium White, 2006 TL
Is an increase in size of the sway bar enough to so call "stiffen" one end of the car? Sent from my iPhone using Tapatalk |
#1002 | |
Swaybar changes are usually pretty noticeable. ![]() - Andy |
#1003 |
Coffee Snob
Drives: '14 SWP BRZ Limited
OEM - BRZ
Front: 2.7kg/mm Rear: 3.5kg/mm Swift Sport - BRZ Front: 3.8kg/mm Rear: 4.5kg/mm This is more of an alignment question, and I'm trying to understand what sort of settings would be ideal for a 1" drop. I have SPC LCAs and front camber bolts. What would be the recommended setting for an alignment (camber, etc) for someone looking to squeeze out some additional handling?
#1004 |
Camber should be set based on tire wear and temperatures (requires testing), and will be dependent on driving conditions and tire choice.
Stiffer tires, or less sticky tires will need less camber than a sticky or softer tire, and stiffer springs can increase the need for more static camber (less suspension travel in a corner means less camber gain). That said, there are some pretty safe starting points. Are you planning on mostly street driving, or more track? What tires?
#1005 |
Drives: FR-S 10 #103 AT
This may be addressed already, in which case just point me to the post.
I would like to lower the car about one inch. Based on what I've read so far, if you could do this with no other changes, it would still improve handling overall. I would also like to not lose any ride comfort (improving it would be nice). There is a company selling coilovers that are designed mostly to improve the ride comfort but they also will facilitate lowering quite nicely. The question I have is based on their springs. What would putting identical soft springs on all four corners do to the handling of a twin? What I have read so far says to me that this is a really bad idea and I should look at a different set of coilovers if I don't want to cause a noticeable deterioration in the handling.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#1006 | |
Drives: FR-S Whiteout
| The Following User Says Thank You to solidONE For This Useful Post: | leicaboss (03-17-2014) |
#1007 | |
#1008 |
i'm sorry, what?
Drives: Canada
i think the word more is what is misleading, stiffer springs increase the rate at which load occurs, so the stiffer side reacts quicker, reaching its limit before the other end... so its more on that relative end, but the total is unchanged
and please understand that springs to not resist weight transfer, they absorb it, with stiffer springs absorbing the same as softwprings, with the only difference being how it LOOKS like from the outside (softer spring compresison more) and the speed at which it happens.
| The Following User Says Thank You to 7thgear For This Useful Post: | RJasonKlein (09-27-2015) |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
