#15 | |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
And I'm sorry I didn't go into enough detail for you on my phone. But this week? None. Entire life? Likely more. It's okay to be butthurt...
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#16 |
BAMF
Probably broke a shift fork. Its not the first to happen. Accelerated performance did the same thing, slightly different situation.
#17 |
I think Full Blown blew a 4th gear at around 600 or 700 whp on the dyno.
That cutout of the BRZ tranny, the gears look pretty stout to me! |
#18 | |
Drives: 2013 GBS BRZ Limited
Those dogteeth will break first. And if the shift fork breaks you will lose two gears because each shift fork moves one slider to engage one of two gears. In fact if the shift fork broke, you could conceivably be stuck in one gear unable to move the slider out. |
#19 |
One could zing the teeth off one of the 4th gear gears and lose only 4th and still have the rest of the gears function though, correct?
#20 | |
Here is a pic that shows the various parts I am talking about: ![]() You can see that the drive teeth are much larger than the dogteeth. As you shift into gear the dogteeth are what make the grinding sound as the shift fork moves the slider from one gear to the next. The slider has the matching set of dogteeth inside where you can barely see them in this pic. The dogteeth are more delicate than the gear teeth. For the trannys I work on, I have never heard of a drive gear breaking but I have plenty of ruined dogteeth gears and sliders. |
| The Following User Says Thank You to stugray For This Useful Post: | Strife26 (11-07-2015) |
#22 | |
Ahhh, I see. Before the gear teeth go, all the dog teeth would go, which would then not engage, leaving that gear not working?
I once had a trans where the shift fork got bent and would shift into 3rd, but not 4th, or was it 1st and not 2nd, well, you get the idea. Quote:
#23 | ||
If you are in the middle of a hard pull and you have violent "non-linear catastrophic structural exasperation" (D. Adams), then it is pretty obvious what happened. If OTOH the tranny just refused to engage and never made any nasty sounds then that is something else. If the tranny refuses to let you even TRY to go through the gates, then it is likely to be the detent system that keeps you from engaging more than one gear at a time. |
| The Following User Says Thank You to stugray For This Useful Post: | Floggin Tires (06-18-2015) |
#24 |
Dog teeth are still there, but none of the teeth on the gear are lol The Frozen North
#25 | |
The Frozen North
#26 |
That guy
Drives: Ultramarine mt FR-S
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#27 |
That is awesome! But that is the kind failure that you would definitely notice.
It looks like it was all the way in gear so the dog teeth are fully engaged. The way the teeth are broken it suggests that the main shaft bearing failed first and allowed the two gears to slip apart. Which gear was that? |
#28 | |
The 2006 Evo MR was shearing the teeth off 4th from even slightly modified power levels after being heat soaked from 20 minute track sessions. They didn't have problems at the strip because 1st, 2nd, and 3rd were more stout, and there's not enough time to strain the tranny and heat soak it. It was the heat soak and higher torque levels under constant load that would cause the failure. It's sad, the 6sp gear spacing was great and felt spectacular, but unfortunately the notchy and clunky 5sp was much stronger. It was because the 6sp 4th gear was only 14mm wide, and frequently used at nearly any track. If the gears were larger diameter, 14mm wouldn't be a concern, but the small diameter meant higher tooth face pressure. Tnhe solution was supposed to be a oil cooler, but I had since sold the car and haven't looked back into it. The 86 transmission is pretty light, so I'm curious about the gear widths and diameters. I haven't heard of too many tranny failures but those that have, I'm wondering if there's any trending. |
| Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode | SteveH | Other Vehicles & General Automotive Discussions | 7 | 02-13-2013 12:08 AM |
| Reverse Gear not going into gear? MT | joergasm | Issues | Warranty | Recalls / TSB | 22 | 11-29-2012 12:08 AM |
| No more 1st gear thump or 2nd gear notchiness | kc4mne | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-06-2012 08:39 PM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 07:44 PM |
| Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 01-29-2012 01:21 PM |
