| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
Drives: Scion FR-S 2013 Raven
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise.
I will suggest grease instead of WD40.
Lithium grease stay forever compare to WD40 who can run out...
o= FR-S =o |
| The Following User Says Thank You to Mikepage For This Useful Post: | mister.bond (10-19-2015) |
#30 |
Drives: Scion FR-S
I agree that grease is preferable, but used WD40 since I already had it on hand. Creaks are gone for last 6 months. I suspect that just "cracking" the welds may make noise go away on its own.
| The Following User Says Thank You to kodyo For This Useful Post: | Mikepage (03-16-2014) |
#31 |
Yes you have probably reason, only cracking spot welds will fix the problem.
o= FR-S =o |
#32 | |
Drives: Scion FR-S
#33 |
Something to consider...
I've put this on the "other" rear deck noise thread...
I've been having the same type of noise and it ended up being a trunk latch mechanism that was adjusted and then the noise when away. Before the dealership figured this out, I would have bet money that the noise was coming from the rear deck. So... if you're experiencing the "noise," it might be worth having the latch checked out before tearing apart your rear deck and doing all the gyrations mentioned.
2013 Asphalt / MT
Olympia, Washington |
#34 | |
PROUD OF BOXER
Drives: Raven FR-S
#35 |
Drives: Scion FR-S
This is a great guide. Wonderful pictures of where the places to crack are.
Just as a note from my experience when I put dampening all over the rear deck, the spot that made the biggest difference was actually inside the break light housing on the deck. I popped it open and laid out some thin dampening (although any kind of spacing material would work) in order to get rid of that wiggle room. The plastic housing just isn't that well made on its own. |
| The Following User Says Thank You to snidd111 For This Useful Post: | Mikepage (06-10-2014) |
#36 | |
Thanks men! I have maybe forget some places to crack but anyway, just crack each spots you can find... ![]() No more sound a year later...
o= FR-S =o |
#37 |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
OK
let's hope that does it, was a PITA getting this all apart let's hope it resolves the issue |
#38 | |
Any update?
o= FR-S =o |
#39 |
#40 |
Drives: 2014 Scion FR-S
Can someone explain the sound it makes? Would this help with rattle from bass? I already put weather strip between thirds brake light and window...
Sent from my SM-N900T using Tapatalk |
#41 | |
Drives: Scion FR-S
Photos, red areas are taped: http://imgur.com/DXVOgXW http://imgur.com/khb60pU I don't think any rattle is coming from brake light and window. There are clicks from the rear deck, but that can be fixed by using a lubricant and "cracking" the welded panel joints from the trunk. You're only applying about a hands weight to the panel, just enough to here the crackling noise. Not yield material or breaking welds. Last edited by kodyo; 07-12-2014 at 01:23 PM. |
#42 | |
| Rear Deck "popping/clicking/tapping/ticking" noise. | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 637 | 04-28-2020 04:55 AM |
| Subaru TSB 12-140-12 for Rear Deck Popping | sparks | Issues | Warranty | Recalls / TSB | 31 | 07-17-2013 11:11 AM |
| GTS rear left popping/clicking sound and fix. | sigmaoctantis | AUSTRALIA | 11 | 05-19-2013 06:58 AM |
| Ticking/Clicking Noise front - passenger side | PoRco | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 05-06-2013 05:55 PM |
| Rear deck popping/clicking | DriftEightSix | AUSTRALIA | 6 | 02-01-2013 01:59 AM |
