#3949 | |
Drives: 2013 SWP BRZ
Have you had issues with the intercooler prior? Not sure why you would go to such extremes as quitting and giving up lol. I do hear you though, I was pretty pissed the other day with the misfiring thing until I found out it was just the map sensor. |
#3950 | |
Drives: 86
Thanks! |
#3951 |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
I'm not sure.
#3952 |
That Guy
Drives: 2013 asphalt FRS MT
| The Following User Says Thank You to Calum For This Useful Post: | DeliciousTuning (03-15-2014) |
#3953 | |
Drives: Raven FR-S
How do I open a ticket?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#3954 | |
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#3955 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
If it is just a trickle then it is unlikely to do any engine damage, but still it should be fixed. Hopefully something simple. |
#3956 | |
Did you check and make sure the pump is working correctly? I know that when i had a leak, I originally missed it. I know you say its not the fittings, but i'd check again. Smell every spot if you can, check with a rag, etc. |
#3957 | |
Drives: 86
Is Innovate hearing us? Are they working on solutions to these problems? I've heard they fixed their fitting issues, but what about the intercooler leaking issues? If only we could get Vortech's support, with the Innovate/Sprintex kit. |
#3958 |
Drives: t
anyone got spare brass fittings ? I'll take the other two from you..
#3959 |
That Guy
#3960 | |
Drives: 2013 Asphalt FR-S
Yeah, this all confirms what my buddy saw with his sprintex kit months ago, swapped back to stock maps sensor and it cleared up. I assume it is only any issue at "full" boost when the pressure wave starts pulsing, since the oem sensor only reads .3 bar so it caps out and does not oscilate with the manifold pressure.
~Namaste~ |
#3961 | |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Suggest you attend to it ASAP as if you are leaking into the manifold, the coolant goes direct into the ports and dries around the valves. Only way take kit off and have your cooler pressure tested, I had a leak from the oring on the inside the core. If you have a dyno nearby, put your car on and do a power run as the car under pressure will cause the boost into the coolant bottle forcing coolant out the bottle cap. The other possibility could be a cracked core, leaking into manifold. I accidentally deleted my videos in error, could have given you idea what to look for. Don't delay, before something serious happens. |
#3962 |
Just the tip
The numbers aren't impressive but not horrible. I've hit the wall on this kit and the only thing I can do running 92oct gas is to get a different kit, run meth injection, or run e85 (or both). I'd prefer to stay on the normal gas for convenience.
The kit can only run on the stock MAP sensor as any other sensor like the 3bar with freak out the ECU at the top end for an unknown reason. There's no post blower temp reading. I'd say this kit is great for someone that wants about what you see in HP/TQ and doesn't want to bother getting supporting mods like exhaust, intake, a clutch, injectors, or fuel pump, and an OEM look, or just that nice supercharger whine. The two lines are 75mm stock pulley, not intercooled, 92oct gas on BRZedit tune @Drift-Office Bob correct me if I'm wrong). The second is 70mm pulley, intercooled, 92oct gas on EcuTek. Big props to Bob at Drift Office @Drift-Office and Mike at Moto East @moto-mike for figuring out the difficulties with this kit and making my car shine with what it has. You've earned a loyal customer with your superb customer service and quality work.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| The Following 4 Users Say Thank You to stockysnail For This Useful Post: | DarrenDriven (03-16-2014), Drift-Office (03-17-2014), Toyota86.ir (02-26-2016), Xero-Limit (03-16-2014) |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
