Old 03-11-2014, 01:41 PM   #617
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Whyyyyy!
I have a house to pay for.... geuss its more ot for me this year.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 03-15-2014, 07:02 PM   #618
onzippy
Drives: 2014 FRS
Hello All, First post and super glad I found this place.
I'm most of the way though installing the AVO kit in my frs a/t but the turbo discharge hose to the IC and the hose by the washer fluid seem 3-4 inches to long.
I was wondering if trimming these to length is normal for installing this kit. My knuckles are pretty beat up already so I gave up trying to fight with it and called it quits for today.
oh.. and anyone know if there's a way to connect the brake booster back up to a vacuum source by reusing the parts or do I need to shop for new hose?
Thanks so much..
matt
onzippy is offline   Reply With Quote
Old 03-15-2014, 07:22 PM   #619
Skorov
Skorov's Avatar
Drives: 86 GTS White
Thanks so much..
matt
Hello and welcome!
First off... The hoses... There is no harm trimming them. I personally just inserted the metal pipes further into the silicone hoses. This was a massive effort. But it's up to you how you want to proceed.
As for the brake booster line... The guide suggests buying OEM parts. Forget this. There just isn't enough room in there to use the OEM parts as needed. You should have some spare tubes left after the install. Feel free to use them, or just go buy some. You can never have enough tubing.
IIRC, you're supposed to connect the brake booster to the back of the intake manifold (there is a spare barb there on autos). And tee off that line to the BOV.
Hope that helps. Feel free to ask more questions if necessary.
Skorov is offline   Reply With Quote
Old 03-15-2014, 07:26 PM   #620
Bigmaxy
Drives: Pegasus GTS86
Hi. I had to cut the intercooler hoses on both sides to make them fit. With the brake booster I had to buy a new t piece. Something tells me it was 10-6-10mm
Sent from my GT-I9505 using Tapatalk
Bigmaxy is offline   Reply With Quote
Old 03-15-2014, 08:47 PM   #621
onzippy
Drives: 2014 FRS
Thanks so much. Sounds like I'm on the right track at least.
Might give them a little trim and save some frustration.
Few more hours tomorrow should do the trick.
Thanks.
Old 03-15-2014, 08:52 PM   #622
Bigmaxy
I mentioned earlier in the thread how much I needed to take off. Actually to clarify. The reason I had to trim was due to have headlamp washers. I didn't think the fr-s had them so wouldn't have expected you to need to trim. Sorry, didn't think of that earlier when I replied.
Old 03-15-2014, 08:54 PM   #623
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I had no issues with my pipes being too long. The rubber ones fit pretty far over the metal ones, so make sure you slide them all the way down
Sent from my HTC One using Tapatalk
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 03-15-2014, 08:59 PM   #624
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
My pipes fitted perfect too.
Old 03-15-2014, 09:13 PM   #625
onzippy
Drives: 2014 FRS
Did you guys lube the inside of the hose with anything before putting it on? The fight I had with it earlier was a tough one.
Old 03-15-2014, 09:34 PM   #626
protpibe
protpibe's Avatar
Use hairspray. It will lube then seal
Old 03-16-2014, 10:05 PM   #627
onzippy
Drives: 2014 FRS
Originally Posted by Bigmaxy View Post
.....Something tells me it was 10-6-10mm
That was the right size. I used that size 't' and put it between the two leftover hose sections that went from the booster to the vacuum pump and routed it to the intake manifold instead.
Didn't have hair spray so ended up using a little bit of pam spray. Made it a lot easier to get things together.
Installation complete. Waiting for my map then time to go for a ride.
Old 03-18-2014, 07:59 PM   #628
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Anyone know a part number of a heater hose adapter that can replace the block fitting of the AVO Breather Tank?
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 03-20-2014, 10:14 AM   #629
ZionsWrath
Thanks
ZionsWrath's Avatar
Is the AVO oil cooler compatible with this kit out yet?
Old 03-20-2014, 10:40 AM   #630
Sportsguy83
Drives: Limited BRZ
What size is the block, do you have a pic, and what are you trying to accomplish?
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
