Old 03-15-2014, 06:48 PM   #841
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
[ame="https://www.youtube.com/watch?v=DLCZl5qXP64"]Subaru BRZ at Atlanta Motorsports Park with Hooked on Driving 3/14/14 - YouTube[/ame]
Longer solo session in group X earlier in the morning with cooler temperatures and no P0351.
Got into a short tussle with a Cayman R and then a 400hp Golf R34 before they black flagged everyone.
Was able to push the car pretty hard and have some good fun!
Old 03-16-2014, 09:09 PM   #842
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
I remember you asking about this; here's my writeup from the caliper rebuild. Fun and easy job:
http://www.ft86club.com/forums/showthread.php?t=60896
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 03-17-2014, 12:46 PM   #843
ATL BRZ
ATL BRZ's Avatar
Upon removal of your existing caliper seals, did you notice any signs of heat related damage or wear?
Old 03-17-2014, 04:13 PM   #844
smbstyle
smbstyle's Avatar
Nope, none. And the inner caliper seal is THICK and very tough; not as soft as I thought it would be, so I don't think you have to worry about dirt and debris damaging it if your dust boots shred as much.
2013 SWP BRZ
Old 03-17-2014, 05:37 PM   #845
ATL BRZ
ATL BRZ's Avatar
Cool, that's good to know. My dust boots still look pretty good but I've been curious about the inner seals. I may rebuild mine at the end of the year if I don't decide to pull the trigger on a BBK by then.
Old 03-20-2014, 10:18 AM   #846
ATL BRZ
ATL BRZ's Avatar
New revised part # OEM coil arrived.
Old 03-20-2014, 11:43 AM   #847
gramicci101
Off Topic
Is it just the one bolt that holds it in? Still thinking about putting a small heat shield around it?
Old 03-20-2014, 12:04 PM   #848
ATL BRZ
ATL BRZ's Avatar
Yes but I went ahead and replaced it. I thought about getting some gold heat tape and putting some on the top part of the coil that is exposed but I don't have any and it would take a few days to order and ship, and I wanted to fix the P0351 as soon as possible.
Only one 10mm bolt holding it in. I just replaced it myself rather easily in about 20 minutes. Removed the three 10mm bolts holding in the ECU on the black fuel rail cover carefully after stuffing some shop towels below to catch any dropped bolts. Zip tied the box out of the way on the strut brace so it doesn't slide into anything. Then I grabbed the coil and pulled it straight out and then up to get the whole thing out. Pressed the connector down and pulled it off and the new one went back in just as easily. Just need patience and dexterity and it's pretty painless. The drivers side coils wouldn't be as easy, though, since there's more stuff in the way.
I'll go for a drive later and report back.
Old 03-20-2014, 01:38 PM   #849
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Make sure you place the ECU back before you drive it. It actually grounds itself with the three 10mm bolts, so don't leave it zip tied out of the way.
Old 03-20-2014, 01:51 PM   #850
ATL BRZ
ATL BRZ's Avatar
Yep I put everything back the way it was and secured all the bolts before running it again.
Just went for a drive and got everything nice and hot before doing a couple WOT pulls to redline and all is well. No more CEL.
Old 03-20-2014, 09:59 PM   #851
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
Glad to hear it wasn't too bad to fix!
GTHachiRoku is offline   Reply With Quote
Old 03-20-2014, 11:16 PM   #852
Sirsimon
Sirsimon's Avatar
Drives: 2021 GR Supra A91 Edition
Nice driving in that video with the Cayman R. Your car looks gorgeous and is a perfect blend of form and very practical mods (function). It is a great template for those of us looking for a fun track day car that we can also drive to work.
Well done! :-)
Sirsimon is offline   Reply With Quote
Old 03-21-2014, 08:50 AM   #853
ATL BRZ
ATL BRZ's Avatar
Well done! :-)
Thanks bro!
Old 03-21-2014, 09:05 AM   #854
smbstyle
smbstyle's Avatar
What was the issue you were having with the old coil? What CEL code were you getting?
2013 SWP BRZ
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
