Old 03-13-2014, 02:02 PM   #3921
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by moto-mike View Post
Spinning the wheels top of 2nd with 255's on pump gas
You just made me go from so sad, to so happy, all in a matter of hours
Thanks for putting in the time to figure out the issue.
Also thank you for increasing the money in my pocket as I can now sell another map sensor
xxscaxx is offline   Reply With Quote
Old 03-13-2014, 02:15 PM   #3922
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
My nethers just twitched. Thanks for the good news!!
Dustin is offline   Reply With Quote
Old 03-13-2014, 02:27 PM   #3923
sw20kosh
Drives: 2013 Black FR-S
We had 5 different tuners/their customers we've been in touch with recently who were all having the same issue and tried the same things. I looked back and the only customers we had that didn't have the issues had stock map sensors. Since the CARB tune used a stock MAP sensor, that is why they were not having the issue.
It is for a few reasons, some of which I don't have the time to get into. But basically because of how the SC flows, the cam phasing is critical, and unlike turbos and the centrifugals; it creates a different flow pattern right at the runner and is the reason for the wobbly MAP signal.
In double checking and making a few phone calls we know that not the omni, the OEM honda, nor the denso IAT based map sensors will work. I think any >1.3 bar sensor will have the same issue when intercooled.
How can a wobbly MAP sensor reading cause such a huge decrease in power >5k rpms. Not questioning you just asking what things are changing in the ECU when the MAP reading gets wobbly? How could this cause misfires?
Old 03-13-2014, 04:10 PM   #3924
swift996
swift996's Avatar
FWIW I noticed post-intercooler install with the 72.5mm pulley my MAP Sensor reading had a lot more deviation in it's reading: (running 3-bar Omni)
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-13-2014, 04:16 PM   #3925
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by xxscaxx View Post
I also plan on going to the 210+. But I wouldn't expect that out for at least a few months.
4-6 weeks in the UK is what I've been told.
My tuner also advised to use the OEM MAP sensor. Looking through the maps, if you're using a MAF based setup then there's no reason to need a higher pressure sensor. The only thing you miss out on is seeing the correct pressure through the OBD port.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-13-2014, 05:25 PM   #3926
Calum
That Guy
Drives: 2013 asphalt FRS MT
Thanks for posting all of this Mike.
Does the stock sensor have a slower reaction time causing it to average out pulsations from the compressor? I wonder if simply adding an inductor inline with the other sensors would clean thing up?
Old 03-13-2014, 06:06 PM   #3927
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Not really, it just loses all resolution above 5 psi where we have the issues. We will be working on ways to get around this issue so we can have proper boost measurement.
Xero-Limit is offline   Reply With Quote
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
Calum (03-13-2014), Drift-Office (03-14-2014), stockysnail (03-13-2014)
Old 03-13-2014, 06:10 PM   #3928
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Finally got the car on the road for the first time - thanks to everyone that helped me with the stupid install problem over the weekend - just got back from the first run - car feels so much better than before! Some small things came up - hoping to get some answers to that here soon. Glad to be a part of the club!
mikalem is offline   Reply With Quote
Old 03-14-2014, 10:26 AM   #3929
swift996
swift996's Avatar
Dumb question but it's been a while, should I disconnect the battery when changing the MAP sensor?
Old 03-14-2014, 10:27 AM   #3930
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I didn't the couple times I changed mine.
Old 03-14-2014, 12:16 PM   #3931
Dustin
Twin Screw You
Dustin's Avatar
I thought our cars ran off a MAF sensor stock?
Old 03-14-2014, 12:21 PM   #3932
sw20kosh
It has both a MAF and a MAP sensor. It primarily relies on the MAF for fueling in stock form.
The Following User Says Thank You to sw20kosh For This Useful Post:
Dustin (03-14-2014)
Old 03-14-2014, 12:23 PM   #3933
Dustin
Twin Screw You
Dustin's Avatar
Cool. Did not know that. Thank you.
Old 03-14-2014, 12:42 PM   #3934
swift996
swift996's Avatar
Swapped back to the OEM MAP sensor, things feel good and smooth now. Hoping to get back up to the dyno next week if I can find the time.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
