Old 03-09-2014, 06:41 PM   #127
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Originally Posted by *LongFella View Post
Initial impression:
Very smooth power and just keeps pulling harder the higher the RPM's. The engine temp was where it should be pull after pull with the added JR Engine Oil Cooler Kit. I almost didn't get it, but I'm glad I did. Now I don't have to worry about the many hard pulls and over-heating...
The revs are quick from the Raceseng Pulley kit and Aluminum Driveshaft. I noticed some shaky mirror vibrations at high speed, but that's likely from the aluminum shaft. I'll rotate it 90 degrees when I install the short shifter next weekend...
The install was easy. I had some "dumb" moments, but it was expected as I'm no car mechanic...
well, you've basically sold me on the jackson sc.
86-tundra is offline   Reply With Quote
The Following User Says Thank You to 86-tundra For This Useful Post:
*LongFella (03-09-2014)
Old 03-13-2014, 11:45 PM   #128
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Mo parts Mo parts!
Picked up the frameless rear view mirror and TRD Quick Shifter
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 03-14-2014, 12:12 AM   #129
DANG, *LongFella ...... I'm ah feared we are going to have to do an intervention and send you off to mod rehab .....
The Following 3 Users Say Thank You to humfrz For This Useful Post:
*LongFella (03-14-2014), 86-tundra (03-15-2014), Chattanooga FR-S (03-23-2014)
Old 03-14-2014, 12:21 AM   #130
*LongFella
*LongFella's Avatar
I do need to slow down a bit
Old 03-14-2014, 10:10 AM   #131
*LongFella
*LongFella's Avatar
NEEEVVVEEERRRRR!!!!!! Hahahaha!!!!
Old 03-15-2014, 04:40 PM   #132
*LongFella
*LongFella's Avatar
Installed the TRD Quick Shifter
Huge difference in shortening re throws and stiffing everything up. Needs to break in a bit as the effort to move the stick is a little more than stock.
It replaces the shift bushing setup and really makes a difference.
The Following User Says Thank You to *LongFella For This Useful Post:
Venator (03-17-2014)
Old 03-22-2014, 12:26 AM   #133
*LongFella
*LongFella's Avatar
I need more parts and power. Any suggestions?!?!?!!!!????
Old 03-22-2014, 07:47 PM   #134
86-tundra
Troll Hunter
86-tundra's Avatar
the hunger... got a header? maybe a uel?
Old 03-22-2014, 08:06 PM   #135
jblmr2
jblmr2's Avatar
Drive it for awhile. Decide how you're going to be using it. Read the technical forums. By then you'll know what parts and power to add. By the way welcome.
jblmr2 is offline   Reply With Quote
The Following User Says Thank You to jblmr2 For This Useful Post:
*LongFella (03-22-2014)
Old 03-22-2014, 08:21 PM   #136
*LongFella
*LongFella's Avatar
Been thinking about the FT86 Speed Factory catted UEL
Venator (03-23-2014)
Old 03-22-2014, 10:04 PM   #137
86-tundra
Troll Hunter
86-tundra's Avatar
You should look at how it works with a SC. I remember originally reading that it may have trouble working with any kind of FI, in the first few pages. I haven't looked since though
Old 03-23-2014, 11:21 AM   #138
*LongFella
*LongFella's Avatar
I'll definitely need a new tune...
I might do it when I decide to go E85. I'll add injectors and a fuel pump too...
Old 03-23-2014, 11:29 AM   #139
Venator
Venator's Avatar
Drives: Asphalt FR-S
If you get the speed factory uel catted post a review with you sc please! That is part of my plan as we'll 😄
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
The Following User Says Thank You to Venator For This Useful Post:
*LongFella (03-23-2014)
Old 03-31-2014, 08:09 PM   #140
*LongFella
*LongFella's Avatar
Mo parts! Mo parts!
Picked up some new front turn signals. I liked the switch backs, but these look a lot cleaner IMO.
Size:  228.1 KBName:  ImageUploadedByTapatalk1396310986.286014.jpg
