Old 03-20-2012, 02:02 PM   #15
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
To be honest it could go both ways. Toyota is pretty reliable, and even though Subaru did a lot of the engineering, you'd think that Toyota would still have to sign off on it.
Though like someone already said, this is a brand new car, with brand new systems on a platform that really hasn't been done by both companies for a long time, if at all. So a lot of things could go wrong.
I'm not too worried about ringland failure, but there may be some problems with the engine like the direct injection and all that.
But I think overall that it should be fine. IF I buy this year the car will be under warranty so....
86'd is offline   Reply With Quote
Old 03-20-2012, 02:02 PM   #16
GED68
Drives: VW
Yes, you will experience rapid tire ware and burn more gas than normal ... within the first few months of ownership ;-)
GED68 is offline   Reply With Quote
Old 03-20-2012, 02:17 PM   #17
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
This car has been in development for 5 years and it's all based off existing hardware. Plus, if there's a Toyota (Scion) or a Subaru badge on it, I have no concerns.
GT86: "This car has two steering wheels: one is circular, the other is operated with the right foot."
no_name is offline   Reply With Quote
Old 03-20-2012, 02:19 PM   #18
(K)
They call me..."Ken"...
Drives: '04 Accord V6 MT
"I don't know what happened. It was fine for the first 1,000 miles. Now they're bald at 1,015. It just makes no sense."
From my limited experience with new cars, the first things that I notice aren't typically mechanical. They're usually cosmetic; a squeaky dash, some bad panel fitment, or maybe an LED bulb out somewhere. Rarely have I ever come across something major, the closest I've ever had was an AC pump giving out at 30,000 miles. Even then it was replaced under warranty. Will this car be problem-free? Highly doubt it. The only thing to do is track Toyota and Subaru's recall and TSB history on new cars just to get an idea of what to expect in terms of down time. Will it be something to worry about? Not much more than your average is what I would think.
(K) is offline   Reply With Quote
Old 03-20-2012, 02:25 PM   #19
bambbrose
Wiring Nerd
bambbrose's Avatar
Drives: 1994 Supra
Outside of the engine, the other major components are tried and true.
Transmission is the S2000 unit with modern updates, should be bulletproof for most use.
Rear end is NA MK4 Supra/ IS with the standard IS LSD (I had that same LSD in my Supra and love it).
Drivetrain should be set, so long as the motor works.
I think the biggest risk is the D4S. People may get intermittent misfire, fouled injectors, etc if the tuning isn't ideal.
bambbrose is offline   Reply With Quote
Old 03-20-2012, 02:38 PM   #20
bFreed
bFreed's Avatar
Drives: FRS, X83, W108
^ This
bFreed is offline   Reply With Quote
Old 03-20-2012, 02:54 PM   #21
LSxJunkie
LSxJunkie's Avatar
Drives: Car
Yup. No first year is perfect. Will they be miniscule? Hopefully.
LSxJunkie is offline   Reply With Quote
Old 03-20-2012, 03:20 PM   #22
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
The big ones haven't really been strictly first year issues - they usually involve a 3rd party part which affects entire ranges. Ie, Porsche IMS, Audi/VW coils, Fords snapping sparkplugs and crappy manumatic, Chrysler grenading automatics, etc.
I think the bigger issue will be all the 2nd year tweaks/improvements they tend to do after having the cars in the wild for a year. Power increase, MPG increase - it doesn't take much to make the previous year resale take a bath.
Khyron686 is offline   Reply With Quote
Old 03-20-2012, 03:38 PM   #23
86fanatic
Drives: auto
Originally Posted by 86fanatic View Post
New platform, new engine, mish mash of parts between two manufacturers. Throw in direct injection which is very hard to get right in the best of times (ask Audi). Subaru's reliability with sporty cars hasn't exactly been stellar lately either (ringland issues, piston issues, wonky tuning).
Yes, there will be problems.
Although I called out some potential issues above, I'm not exactly predicting armageddon here. It should be in line with any other brand new sports car production. I would be shocked if it was any worse then say, the 2008 STI launch which had it's share of minor problems.
Considering the companies involved - Toyota and Subaru - the reliability reputation is on the better then average side. Although I wouldn't use Toyota's name on this project as a sign of reliability. All cars will be manufactured and assembled in a Subaru plant, with a Subaru engine. Subaru is decidedly more middle of the pack in terms of quality/reliability reputation then Toyota, but still quite good.
86fanatic is offline   Reply With Quote
Old 03-20-2012, 04:15 PM   #24
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I remember the GC had small issues and one big issue. The manual tranny. But if you bought a automatic GC it was bulletproof on big problems.
SUB-FT86 is offline   Reply With Quote
Old 03-20-2012, 04:23 PM   #25
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
First car is always a scary... tbh, I'm not worrying too much about it. Base engine (FB20), I haven't heard much problem (so far) so hopefully FA20 will run strong too
Old 03-20-2012, 04:26 PM   #26
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Its hardly the middle from Subaru's perspective.
chulooz is offline   Reply With Quote
Old 03-20-2012, 04:29 PM   #27
86fanatic
Drives: auto
JD Power paints a different picture.
Also the higher performance models are worse still. Sports cars manufactured by Toyota (MR2, Supra, Celica) I would say on a whole have a far better reliability and quality reputation then sports cars manufactured by Subaru (WRX, STI).
Old 03-20-2012, 04:30 PM   #28
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
of course its going to have some few small issues...its a brand new model!!! thats how every new model are...
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
What can we do? (RE: dealership problems) D4ng3r Off-Topic Lounge [WARNING: NO POLITICS] 2 02-03-2012 10:36 AM
Investigation into Toyota pedal problems widens nisarnadaf Other Vehicles & General Automotive Discussions 0 02-04-2010 01:57 AM
