Old 03-12-2014, 05:32 PM   #29
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
UEL's, 100% catless, N1 catback and I rarely go out of 4th...I'm going to hell when I die aren't I?
Sent from my hlte using Tapatalk
ProTekk is offline   Reply With Quote
Old 03-12-2014, 05:46 PM   #30
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
No, but you are making Saudi princes that much richer
^GT5 Replay Photo Mode^
Old 03-12-2014, 06:11 PM   #31
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Originally Posted by cjsporl1996 View Post
People are being too conservative with this car. It's a true SPORTS car. I redline it all day long. My mpg is about 21-22 combined.
I have a ton of fun in my car, but I don't drive like a tool around the city and through neighborhoods. I have a combined 29.2mpg right now.
Sports car doesn't mean you have to redline it all the time. You can keep it in the mid range a lot too and still have fun hitting corners aggressively. Pushing the car to the limits all the time on the streets is just asking for trouble in more ways than one. From the sounds of it you are likely really young and will learn.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 03-12-2014, 06:23 PM   #32
STV3
Seρor Member
STV3's Avatar
Had a friend with a wrx that was anti 5th gear on highways for some reason, motor ended up blowing cruising on the highway one day. Car only had about 50k miles on it. Not saying the high rpm was the direct cause of the failure but I'm sure it didn't help either.
STV3 is offline   Reply With Quote
Old 03-12-2014, 06:33 PM   #33
504
504's Avatar
Drives: 2014 86 GTS
Id rather NOT know what his oil temps reach after a short cruise.
504 is offline   Reply With Quote
Old 03-12-2014, 06:42 PM   #34
Akari
Drives: 2013 DGM BRZ
+1 to what everyone else has already said.
In a NA car you want to be in the highest gear possible without lugging the engine for the lowest wear and highest fuel efficiency.
In turbo vehicles this isn't always the case as turbo efficiency can change your overall efficiency. My STi loves 5th vs. 6th at low highway speeds.
Akari is offline   Reply With Quote
Old 03-12-2014, 06:54 PM   #35
SirBrass
SirBrass's Avatar
The kid isn't even out of HS yet. He's lucky he has such a nice car.
When I was his age I was allowed to drive A car. That car wasn't mine, it was my parents', and it was a 1987 Honda Accord with over 100k on the ODO. It was a POS, in short. Well-cared for, OLD (only younger than me by 3 years), POS. And I enjoyed the freedom such access gave me.
Don't abuse your first car, kid (not speaking to @woode here) even if it's a beater, let ALONE if it's a brand new car that's actually yours.
Old 03-12-2014, 07:00 PM   #36
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Originally Posted by Pegasus View Post
As soon as I get to 35mph I throw it in 6th and floor it. Don't need to shift again until I'm under 35. Ideal for mpg and longevity.
this just seems fucking lazy
Old 03-12-2014, 07:16 PM   #37
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
No joke, anytime above 35mph im in 6th. Idk if it's bad or not, I don't know how it could be. But it does make me wish there was a 7th overdrive gear. Turning about 1,500ish at 60mph.
To me, the lower the rpm, the less the friction, the better the fuel economy and less wear & tear. That's just how I think of it, I could be wrong but it makes sense in my head.
It can be bad for the engine to be spinning extremely slowly with a very high throttle setting (in other words, if you're climbing a hill doing 1300 in 6th while floored), but as long as you aren't flooring it all the time at low RPM in high gear, you should be fine.
chrisl is offline   Reply With Quote
Old 03-12-2014, 07:17 PM   #38
woode
Boosted Member
woode's Avatar
You are.
Old 03-12-2014, 09:19 PM   #39
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Originally Posted by chrisl View Post
I don't think I would trust you for advice on what's OK to do with this car...
http://www.ft86club.com/forums/showthread.php?t=57094
For what it's worth, I always drive stick shift cars in the highest gear where I'm not lugging the engine, unless I am actively passing someone, or driving in a sporty fashion over a mountain pass, or on a track or something like that. Cruising around at 45+ is pretty much always in top gear in pretty much every car (though I do sometimes have to use 4th instead of 5th at 65-70mph in my Outback when in the mountains, since it needs the extra power to climb some of the hills).
Ummm it turned out that nothing was wrong with my engine. In fact I'm boosting my engine this weekend😊
cjsporl1996 is offline   Reply With Quote
Old 03-12-2014, 09:28 PM   #40
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Actually that Accord wasn't bad at all if you ask me (imo it was the first good one, car of the year in Japan when it came out in 1985). It had really cool flip up headlights, double wishbone at all 4 corners, low driving position and the steering felt really good once it stiffened up at high speeds / corners. You were a lucky kid!
krayzie is offline   Reply With Quote
Old 03-12-2014, 09:34 PM   #41
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
You need more driving experience (instead of asking questions prematurely).
Originally Posted by Spartacus View Post
Hi Everyone,
My friends and I are having a bit of a debate regarding proper manual driving technique and I thought I'd pose it to the experts. The crux of their argument is that on the highway, under normal driving conditions (some traffic, not bumper-to-bumper, but not wide open either) I should be in 6th gear and only downshift as needed to pass and maneuver aggressively. I tend to use 4th as my workhorse gear and only shift up when things are wide open and straight. I think we all agree that it's more fun to keep the revs in the happy 5000 - 7000 zone, but am I unnecessarily damaging the engine by making it work harder than it needs to?
This is first manual car and I've driven it this way since after the break-in period. I haven't had any passengers question my shifting tendencies until the past few days -- though admittedly most of my friends don't drive stick. So who's right? Should the car (1) only be downshifted as needed or (2) only be upshifted as needed from cruising speed?
Thanks!
BRZfan is offline   Reply With Quote
Old 03-12-2014, 09:50 PM   #42
Mrpolarbear
Drives: 2013 DGM BRZ - MT
less lazy.
more shifting.
Mrpolarbear is offline   Reply With Quote
Best cruising speed for highest MPG. BrandonFYIA Scion FR-S / Toyota 86 GT86 General Forum 95 03-29-2015 10:53 PM
High rpm cruising in 6th abutterman Issues | Warranty | Recalls / TSB 12 03-22-2013 07:38 AM
What your favorite cruising song? speedy racer Scion FR-S / Toyota 86 GT86 General Forum 102 11-23-2012 02:07 AM
Fr-S w/ Evo X cruising in SoCal NGabriel89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 09-12-2012 06:19 PM
Cruising Range? skoodge Scion FR-S / Toyota 86 GT86 General Forum 4 05-25-2012 02:31 AM
