Old 03-11-2014, 11:58 PM   #15
radroach
Drives: car
Just enjoy the stock tires while they last, they perform great up to a limit, and the limit is pretty high.
I've taken mine on road trips and DD on them and they're still in good shape: http://www.ft86club.com/forums/showp...&postcount=231
The Following User Says Thank You to radroach For This Useful Post:
Chattanooga FR-S (03-12-2014)
Old 03-12-2014, 12:53 AM   #16
torqdork
torqdork's Avatar
Drives: RV-7
My local Americas Tire Co. gave me $400 credit for OEM takeoffs and there was another Bridgestone spiff in play then for another $100 for a total $500 credit toward a set of RE-11A's that I since sold and replaced with Michelin Pilot Super Sports that had another $75 spiff going, both sets 225/45-17 on stock rims. The math worked out so that it's only cost about $200 to play with two sets of max performance tires during the past year, well worth the experience and dramatic improvement they made to the car in both road and track conditions. Highly recommended, the stock tires are merely adequate in the dry, incompetent in the wet. Do it!
torqdork is offline   Reply With Quote
Old 03-12-2014, 01:39 AM   #17
DAEMANO
Time Traveller
Reason for downgrading the sticky from RE-11A to Pilot Super Sports?
Old 03-12-2014, 01:45 AM   #18
Originally Posted by Chattanooga FR-S View Post
It's looking like this is exactly what I will end up doing. The dealer said it should arrive "late this week", so this coming weekend might be a great one!
Good plan. I feel the OEM tires are just fine for average driving. Not so much on cold roads or in the snow.
Old 03-12-2014, 02:07 AM   #19
torqdork
torqdork's Avatar
Drives: RV-7
Wet grip, ride quality and weight savings.
The RE-11A's have phenomenal dry grip when temps are +50°F, otherwise it's on tiptoes as the VSC gets active in Sport mode. And their stiff sidewalls and tread transmit every road imperfection into annoying jolts and shocks felt through the steering and seats.
The PSS's are 4 lbs. per corner lighter so turn-in is noticeably improved, acceleration seems quicker and ride quality is relatively plush. Wet grip is in another league, very confidence inspiring. I only have 150 miles on them and need to test pressures, the rear is definitely loose compared to the RE-11A's. I've read that grip improves after 150 miles so we'll see. I think 28-30 psi might keep things planted better than 32 psi now, much how the RE-11A's responded.
So I wouldn't call it a downgrade but I've yet to track the PSS's. I'll know better soon but for now call it a change for the better with the bonus of a 30,000 mile warranty.
Check the reviews and ratings on both at tirerack.com and it's a coin toss unless you live where it rains.
The Following User Says Thank You to torqdork For This Useful Post:
DAEMANO (03-12-2014)
Old 03-12-2014, 08:53 AM   #20
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
When I bought my Monogram, I talked the dealer into swapping out the OEM Michelin Primacys for a set of Michelin Pilot Super Sports. All I had to do was pay a $65 labor charge for dismounting the old tires, and mounting and balancing the new tires.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
The Following User Says Thank You to CruiseZen For This Useful Post:
AznBRZer (03-12-2014)
Old 03-12-2014, 10:51 AM   #21
AznBRZer
Drives: 16 CBS WRX Limited
This is what I should've done, but didn't think of it. I guess there's always next time.
AznBRZer is offline   Reply With Quote
Old 03-12-2014, 11:23 AM   #22
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
I used the stock tires for 8000 miles and then upgraded to PSS's at a Discount/America Tire. They still gave me I think a little over $100 for the tires even with mileage on them. Learning the car on the stock tires was interesting, but it feels so much better on the PSS's. Of course, if you start off on sticky rubber, you wouldn't know the limits of the car before the swap.
malave7567 is offline   Reply With Quote
Old 03-12-2014, 12:26 PM   #23
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
My originals are stacked in the garage used as "wets" when rain threatens to ruin the weekend.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires stockysnail Northwest 36 12-19-2013 01:12 PM
Building your Credit? Drifty86 Off-Topic Lounge [WARNING: NO POLITICS] 55 08-06-2013 11:20 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
Sonicelectronix.com credit abutterman Miscellaneous 2 03-23-2013 05:28 PM
to those of you with good credit... pr086 Scion FR-S / Toyota 86 GT86 General Forum 100 12-12-2012 01:01 AM
