#99 |
So, I learned tonight that in this firmware version you need to stop logging before turning the ignition off. What happened was I logged for probably 40minutes, shut the car off then went to hit stop logging. Within about 3 seconds, but before I could hit the STOP button I got an "Operation Failed" error or something to that effect. I figured the data would still be saved but it wasn't. The data was from my previous logging session. I'm pretty annoyed by that.
| The Following User Says Thank You to R2 For This Useful Post: | steve99 (03-11-2014) |
#100 | |
Drives: 2013 FRS
It's only then that it saves data to csv file as stated in the on-sceen message.
#101 | |
Drives: 2013 FRS
Also with regards to datalogging, can you try to de-select all the channels (in configuration menu) and then enable only engine speed. And then confirm that that works. If it does, then is going to be an issue of one of the datalog channels not be compatible with your ROM ID. It would be good to know which one that is and de-select it. |
#102 | |
Drives: FT86
Cheaper too I reckon we pay about US $2 a litre for premuim fuel ($7 a US gallon ?) |
#103 | ||
Drives: 86
i updated to 1.07 last week and used the latest template 1.23 (freshly downloaded today). maybe i need to re download + install 1.07 tomorrow. |
#105 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
I tried to pull a log last night. I removed IAM and KC Learned I believe. I added in Intake temp and vehicle speed and OFM would freeze when trying to pull the log.
#106 | |
I actually got a log to pull off mine last night, not sure what exactly fixed it but here's what I did. Reflash car back to original bin Redownload and install OFM 1.07 Update OFT Upgrade template Reupload the dev file to the OFT Reupload each bin file (1.42 stage 1 and 1.56b stage 1) Flash car with 1.56b Configure data channels, leave original 12 selected Log a few minutes Read from OFM. Since then I changed back to the channels that first gave me issues, will try to pull if off once I find a USB cable at work (forgot mine at home). If this fails I'll try a channel at a time tonight to see what the culprit is.
#107 |
Drives: 2013 FRS
Did you go to the Configure Channel sceen first? This needs to be done one time (after firmware update) to initialize the channels you want to view/log in the realtime data screen. If you don't do this, you will see that communication error.
#108 |
Tried pulling the log from this morning off just now, same symptoms as before. Looks like it's back to square one
![]() I'll go through channel by channel to see which one(s) causes the issue.
#109 | |
Drives: 86
i just re-installed OFM and will try again later today. Thanks. |
#110 |
Slack Bum
Drives: FT86
Just connected to my OFT and now firmware is updated to 1.24
#112 | |
Drives: FT86
The first screen shot shows the changes I applied ie -0.35 to about 12 cells. The "zero's" are no change. This was at screen shot of table comparison between modified table and standard table from 1.56 stage 1 tune The Second screen shot shows the resulting values in the Knock advance table. see here http://www.ft86club.com/forums/showp...0&postcount=64 This has been working quite well for me. |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| FS: Openflash tablet | nguyen_er | Engine, Exhaust, Bolt-Ons | 6 | 12-30-2013 12:31 PM |
| new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 09:05 AM |
| OpenFlash Tablet Firmware 1.19 Now Available: Stores up to 5 ROM on the OFT | Shiv@Openflash | Software Tuning | 33 | 12-20-2013 09:38 AM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 12:10 AM |
