Old 03-11-2014, 07:02 PM   #85
Slow_86
Cpt. Slow
Drives: 2015 series.Blue
Not trying to thread jack, have been looking for a but so i figure this is the best place to ask.
I'm looking at lowering the car, but after reading this, im trying to figure out how low before axle geometry is skewed and putting excess stress on the axles? I see PSM has the diff risers.
Slow_86 is offline   Reply With Quote
Old 03-11-2014, 09:37 PM   #86
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
If you raise or lower the suspension, you run the risk of causing excess strain on the cv joints on the axles. Diff risers may help, but I don't know. After I swapped axles with another used FR-s axle all seems fine.
Please read all posts that have listed why their axles have failed (including mine). Then take into consideration that you run the risk of breaking axles if you decide to lower, so save some extra dough for axles or a lot of dough for DriveShaftShop axles, and lower away!
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 03-11-2014, 09:56 PM   #87
Slow_86
Cpt. Slow
Yeah i've been reading through here and seeing what/when/how peoples axles are breaking.
By chance @markmatley, How much lower are you? Stock wheels/tires?
Old 03-12-2014, 09:24 PM   #88
markmatley
markmatley's Avatar
At the time of breakage, I was actually about an inch higher than stock. Stock height (from Toyota headquarters) is about 7" I believe from the center of the rear subframe bolt that connects to the lower control arm to the ground. Mine at the time was ~8". This was done just for looks, low in the front, and only a tad bit higher than stock in the rear. Also at that time, I had stock wheels and tires.
As of replacing my axle, I am dropped down to .5" lower than stock in the rear, with a wheel and tire set that matches the height of the stock wheel and tire set. I am only 10mm's wider than stock. No noise or grinding, just tire rub when I hit these horrendous potholes on Oahu.
Hope that helps.
~Matt
The Following User Says Thank You to markmatley For This Useful Post:
Slow_86 (03-13-2014)
Old 03-13-2014, 10:31 AM   #89
steveoexige
Drives: UK GT86 in White with alcantara
I seem to get a loud clicking noise from inside the car down toward the rear of the transmission tunnel (altho cant be sure), whatever though the noise is definitely toward the rear of the car. I only seem to get this clicking sound after I've been driving 5 mins, it's never there straight away. It's definitely not trim related like a rattle or anything and seems to get gradually louder during "spirited" driving and then seems to disappear if I switch off and come back to the car an hour later. Sound like a CV joint?
steveoexige is offline   Reply With Quote
Old 03-30-2014, 11:16 PM   #90
batboygotoj
Drives: Toyota Camry
Just went under the car today. Inner cv boot on the passenger side torn. Now will I need to change out the whole axle or just the boot? My car is lowered rear finger gap. Thanks in advance.
batboygotoj is offline   Reply With Quote
Old 03-31-2014, 02:17 PM   #91
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
I plan on dropping my FR-S in the future, and I'm definitely interested in this topic. On my previous car (Altima Coupe), I had axle problems as well once it got low enough on coils. After going through a few sets of axles... I gave my axles to this guy http://www.gatorracingaxles.com and they held up really good, and all he did was upgrade the boots and grease.
Cockatoo is offline   Reply With Quote
Old 03-31-2014, 04:11 PM   #92
batboygotoj
My friend said frs/brz are really weak once lowered. So I might get upgraded axle just to be safe. Taking mine to the dealer tomorrow to get the ripped boot a check. So hopefully something gets replaced under warranty.
http://www.driveshaftshop.com/import...-in-rear-axles
Old 03-31-2014, 04:18 PM   #93
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
All of my issues have been passenger side.
I'm pretty low though and drift the car. MAX risers getting installed soon. Upgraded axles alone aren't enough. They're still going to be at an extreme angle and get premature wear. Risers are the better option as they'll help eliminate the issue. If you never want to worry again, do both.
Doing just the DSS axle upgrade won't be enough though if you're lowered a good few inches. We have a couple pages about this topic in the drifting thread under the track section.
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post:
DAEMANO (01-02-2016), kevaughan (06-17-2020)
Old 03-31-2014, 04:18 PM   #94
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
You'd rather break the ring/pinion?
Old 04-01-2014, 12:44 AM   #95
markmatley
markmatley's Avatar
This is what I was getting. Eventually it will settle down on an rpm range. Mine was ticking at 1k to 2.5k and would go away at higher rpm's. Eventually this will lead to a break at the CV joint at the diff.
Funny you mention this...my friend just told me about them for his FWD. I emailed them to see if they work with RWD axles.
Hahaha! I don't think he wants that. And I don't quite follow your post? Would he break the ring/pinion if he drove it a bit to the dealership to get the CV boot checked out?
~Matt
Old 04-21-2014, 12:37 PM   #96
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
I am starting to wonder if it is honestly just a hit/miss on whether you will end up with a broken axle once you start dropping the car and/or adding more power. One of the forum members has been tracking his lowered car, with additional power and has not had any issues: http://www.ft86club.com/forums/showt...03#post1686903
Hope I did not jinx him :\
Eurasianman is offline   Reply With Quote
Old 04-21-2014, 12:45 PM   #97
Wepeel
Drives: '13 BRZ Ltd
Anyone got a part number for the axle? Definitely am going to pick one up and include it in the autoX kit. Seems like a "not if, but when" issue.
Wepeel is offline   Reply With Quote
Old 04-21-2014, 01:44 PM   #98
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
ebay...about $125..left and rights are the same
Bill
Scooby South is offline   Reply With Quote
The Following 2 Users Say Thank You to Scooby South For This Useful Post:
more money than brains, stance bro
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
