Old 03-11-2014, 02:17 PM   #1
BRZranger
Tom's tail light gap
Just received my Tom's tail lamp from @RavSpec, they look great! Except the right passenger trail light seems to have a gap from manufacturer. Doesn't seem to be a way to push the tab in :-(
I'll contact @RavSpec and figure this out in meantime. Anyone else have this?
BRZranger is offline   Reply With Quote
Old 03-11-2014, 02:18 PM   #2
BRZranger
Old 03-11-2014, 03:27 PM   #3
BRZranger
Old 03-11-2014, 03:57 PM   #4
Scoobybrz
Scoobybrz's Avatar
I have the same gap on the same side. It doesn't really bother me anymore. But I've seen others with perfect fitment.
Scoobybrz is offline   Reply With Quote
Old 03-11-2014, 04:00 PM   #5
phloozy
phloozy's Avatar
Drives: Scion FR-S
U need to push it all the way into place before tightening. Thats what I did at least
phloozy is offline   Reply With Quote
Old 03-11-2014, 04:25 PM   #6
BRZranger
Were you able to flex the whole tail light to push that in?! I'll give that a try.
I'm definitely OCD, can't have the gap!
Old 03-11-2014, 05:28 PM   #7
phloozy
phloozy's Avatar
Drives: Scion FR-S
I pushed it flush with my car while my wife tightened the bolts, may need 2 ppl.
Old 03-11-2014, 05:40 PM   #8
mfbmike
Drives: 2013 FRS, 2008 R32
There is a long protruding "stick" on the back of the taillights that needs to go into a hole to make it sit flush. Make sure that's in correctly. Make sure you didn't break it either trying to jam the tail light in there.
mfbmike is offline   Reply With Quote
Old 03-11-2014, 05:52 PM   #9
Burrcold
Drives: Subaru BRZ Limited
Definitely have someone else push the tail in place while you tighten the bolts. Much easier to do and will ensure a tight fit. After having my wife help out, mine sit perfectly flush now as well.
Old 03-11-2014, 08:03 PM   #10
BRZranger
It's actually not the taillight against the body. That part is fine.
There is a tab on the side marker that is not seated. I would have to open the tail light and push it snapped closed.
Old 03-11-2014, 08:06 PM   #11
RavSpec
Drives: Rx7
Got it .. let me work on this now !
RavSpec is offline   Reply With Quote
The Following User Says Thank You to RavSpec For This Useful Post:
BRZranger (03-11-2014)
Old 03-11-2014, 08:31 PM   #12
BRZranger
Thanks @RavSpec! Looking forward to doing more business with you!
Old 03-12-2014, 12:13 AM   #13
IgnitionGundam
IgnitionGundam's Avatar
Drives: Silver Ignition Gundam
I had these shreds of plastic in my clear tom's. It wasn't a big deal, but man it looked like it was scratched from the inside and very annoying to look at. Will@486power took care of it right away and I got it replaced within a week. Great customer service going on over there.
IgnitionGundam is offline   Reply With Quote
The Following User Says Thank You to IgnitionGundam For This Useful Post:
BRZranger (03-12-2014)
Old 03-12-2014, 12:25 AM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
Do you only date virgins?
Valenti tail light signal light issue djdnz Cosmetic Modification (Interior/Exterior/Lighting) 70 12-03-2017 12:49 AM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
FS - Light tinted tail light overlays seven Exterior Parts (Aero, Lighting, Etc.) 0 01-26-2013 10:05 PM
experiencing tail light + fog light condensation? whyreeto AUSTRALIA 20 01-14-2013 11:15 PM
tail light Sketch575 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 07-11-2012 02:32 AM
