Old 03-19-2012, 11:17 AM   #99
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so how many autocross or time-attack first places have you had in that 600 hp supra?
Old 03-19-2012, 11:21 AM   #100
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Must....remain....silent....
Interesting. I'm going to assume that you guys were part of that little session.
Originally Posted by Gadflyii View Post
it is too expensive base, the compression ratio is too high, the internals are too weak, it is N/A, and pretty small.
The same can be said for the Elise, and yet they've acquitted themselves as quite capable track cars.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 03-19-2012, 11:25 AM   #101
Future
Future's Avatar
Drives: BRZ!
hmmm....
well this is all and good.... calling this a "tuner car" is reaching... a lot in fact.
Sure you can bolt on a fart can exhaust, header, intake, MAYBE tune it a bit, and pick up 10-15 horse power, perhaps even 20, but a stock Gen coupe (either of them) r-spec will still walk all over you, both around a track and in a straight line.
Now if you drop 25k+ and build the motor, go FI, and do all the supporting mods you will make 400-500hp and kick ass, but honestly it still is nothing to write home about.
Well, maybe you are not the target audience for this car? I could not care less that this car makes 200 or 400hp... I'm all about handling, having fun around the track with my friends and beating my personal lap times while fine tuning the suspension, braking system, etc...
The fact that the only things you did not mention in your "tuning list" are the suspension and the brakes tells me a lot on the type of customer/driver you are. In every single events I went in my life, I would be faster than the other guys only because of my suspension and braking setup. (talking about an IS300 vs Gen3.8, GTI, some Porsche and the funniest one, a Viper).
That could be the reason I'm heading toward the BRZ too, seems like a more mature audience.
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
Old 03-19-2012, 12:50 PM   #102
Gadflyii
Drives: Cleaned out the garage!
Send a message via AIM to Gadflyii
HAHA... you have no idea what kind of driver or customer I am... to assume so is obtuse.
As to what you said.. the suspension appears to be well tuned already, and the balance appears to already be there. Granted if you change the un-sprung weight and put sticker tires on the car you may need to adjust it slightly to maintain that balance.. but at this point... not really sure what is to be gained from changing the suspension components.
Brakes, sure, you will need better brakes in order to track the FR-S/BRZ, but from what I can tell a set of xp8/10's will take care of the fade.
No doubt you CAN tune the FR-S, my only point is calling it a tuners delight is a bit of a reach.
Originally Posted by Scion FR-S View Post
Hey, this is ft86club! Bitchiness, snide putdowns, and one-upmanship come with the territory!
Gadflyii is offline   Reply With Quote
Old 03-19-2012, 01:08 PM   #103
Gadflyii
I am hardly a Lotus nut, but I am pretty sure the Elise is 800-1000lbs lighter than the F-RS, and has a 220hp Supercharged Toyota engine?
Old 03-19-2012, 01:17 PM   #104
We've dropped a few hints on our facebook page, but we reeeeally need to stay quiet for a few more days. It's actually really difficult to do. But we were not a part of this session (and that is okay).
Myles is pulling me away from the computer now. See you guys in a few days!
- drew
Old 03-19-2012, 01:23 PM   #105
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
hmmm....
saying this car isn't worthy of being called a tuner car on a forum dedicated to this car is troll bait, if you ask me. just because it's small and n/a means it can't be a tuner car? 25k base is too expensive for a tuner car? where does this guy get this crap?
cyde01 is offline   Reply With Quote
Old 03-19-2012, 01:30 PM   #106
Gadflyii
Not trolling, and I didn't say it can't be a tuner car, just said saying it is a tuner's delight is a reach.
My point with the 25k base is not that it was too much money, it was that from a tuner standpoint, it is a lot money for what you get. Since it is N/A the cost to tune the car will be greater. So you pay more to get into the platform, get little to work with, then will have to pay a lot more to really tune it. ... Nothing more.
Old 03-19-2012, 01:37 PM   #107
bestwheelbase
Drives: 1985 P-Type
Drew,
We're waiting patiently until the day you don't.
Old 03-19-2012, 01:43 PM   #108
bneale
bneale's Avatar
Drives: Scion FR-S
You may want to go re-read your post again. You pretty much said its not a tuner car.
hmmm....
bneale
bneale is offline   Reply With Quote
Old 03-19-2012, 01:47 PM   #109
Gadflyii
I can play that game too...
I think I have clarified that point several times now.
Old 03-19-2012, 01:49 PM   #110
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
it seems that the definition for "tuning" is what's really up for discussion here.
the FRS really is a tuners delight because:
1. wheel wells/arches are designed to accommodate more than just a standard wheel and the fender edges are already flat and sealed (no quaterpanel rust)
2. front swaybar designed in a way to allow a wide range of steering arm adjustment, so you can end up turning 90* and with no interference
3. accessory belt independent of timing chain, you're free to add/remove modify pullies and whatever without ever touching timing.
4. apperantly (and hopefully this is true), there are no airbags in the seats, this means you can swap seats to your heart's content without worrying about breaking the airbag circuitry or worrying about malfunctions.
5. if the engine bay is anything like my impreza, it's rather easy to work on.
6. suspension is easy to work on, straight out of an impreza, you don't have to unbolt half the car to get at something.
these are just some of the things i get just from looking at pictures
a "tuners delight" does not mean "able to jam 2 bar boost down it's throat and live to tell about it"
Old 03-19-2012, 01:51 PM   #111
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Sure but flip-flopping doesn't help you prove your point much now does it?
What exactly makes one car a "tuner car" in your opinion?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-19-2012, 01:53 PM   #112
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
he had a 1000HP Supra and 600hp GTO in his signature.
2013 Scion Fr-S on the March Issue of MotorTrend KevinDuMa Scion FR-S / Toyota 86 GT86 General Forum 45 03-12-2012 06:25 AM
2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast Zgrinch Scion FR-S / Toyota 86 GT86 General Forum 124 02-21-2012 02:43 AM
2013 SCION FR-S Safety Audi Scion FR-S / Toyota 86 GT86 General Forum 14 01-17-2012 08:29 PM
2013 Scion FR-S: 10 Things You Don't Know (Maybe) - Insideline rmagic Scion FR-S / Toyota 86 GT86 General Forum 56 12-15-2011 05:36 PM
