Old 03-10-2014, 04:35 PM   #85
yoruck
Drives: ford fiesta st 150
i have the log issue on win8 with ofm 1.07,the 12 first channel select with ZA1JA00G.
by the way to try on another pc i install ofm 1.07 on my portable win7 os.
the connection to the oft failed after the cktrl.dll what can i do to pass true that.
i have already try to install win8 patch and it s not better, thanks for help
yoruck is offline   Reply With Quote
Old 03-10-2014, 04:39 PM   #86
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Thanks for the info guys
Shiv@Openflash is offline   Reply With Quote
Old 03-10-2014, 04:42 PM   #87
carlitosway6891
Drives: white out project fr-s
same message i get on my OFT 1.07 when trying to view live data engine on or off, works when i go back to the main menu and try again
carlitosway6891 is offline   Reply With Quote
Old 03-10-2014, 04:43 PM   #88
steve99
Drives: FT86
Originally Posted by Drofnum View Post
Happens with engine running yes. Tried it with the key on and engine not running as well as engine running. I could never get it to start up. I didnt have a lot of time since i did this on my lunch hour so I will do a bit more troubleshooting after work.
Might be worth connecting OFT to PC/computer with latest 1.07 Open flash manager software and let it update over internet then apply the template 1.23 files as well
http://openflashtablet.com/products/...s-2/index.html
Old 03-10-2014, 05:55 PM   #89
Drofnum
Drives: CBS Subaru BRZ
This happens with engine running ??
Update the template on my OFT and that seemed to fix my issue. Not sure why but I'm not complaining.
Drofnum is offline   Reply With Quote
The Following User Says Thank You to Drofnum For This Useful Post:
elrod (03-10-2014)
Old 03-10-2014, 06:07 PM   #90
Shiv@Openflash
Drives: 2013 FRS
Good to hear. It is absolutely necessary to update the template file with the new Enhanced Data logging update. Without it, the OFT will give you an error if you try to log data.
Old 03-10-2014, 09:03 PM   #91
elrod
elrod's Avatar
Drives: WRB BRZ Limited MT
Many thanks to @Drofnum who gave me the idea of re-doing my template update file. I discarded the new template file that I had downloaded several days ago. I re-downloaded the new template file again. I reppplied the "Upgrade" to the OFT.
Now I am able to data log 8 original parameters plus Oil Temp, AFR Comanded, Coolant T, and Ambient Temp. It works fine now.
This brings to mind two things that would really be useful to the OFT user population. First and most important: we desperately need an MD5 checksum for EVERY download. Second, it would be much handier if our selection of the 12 parameters that WE want to data log was a 'sticky' selection and we didn't have to do it each time we wanted to data log.
elrod is offline   Reply With Quote
The Following User Says Thank You to elrod For This Useful Post:
Shiv@Openflash (03-12-2014)
Old 03-10-2014, 09:06 PM   #92
wparsons
wparsons's Avatar
It should be "sticky", but it resets after an update, at least that's what I've found.
I'm going to try re downloading and updating the template to see if that helps at all. I've re uploaded it to the tablet, but I haven't tried downloading a fresh copy off the site.
flickr
Old 03-11-2014, 05:30 AM   #93
troek
troek's Avatar
Drives: 2012 Toyota 86
my settings stay put, and i just had my oft plugged in this morning to add a different tune. it has reset once, but i cant say for sure what i did to cause it, as it was only once.
troek is offline   Reply With Quote
Old 03-11-2014, 09:14 AM   #94
wparsons
wparsons's Avatar
^^ When you plug it in do you see it do a full updated every time? Mine didn't used to do that, but now it does and every since then I haven't been able to pull logs off it.
There seems to be a couple common things happening to those with issues pulling logs, and one of them is it updating every time it's connected to OFM with internet.
flickr
Old 03-11-2014, 09:51 AM   #95
troek
troek's Avatar
it does update, however i dont know what it use to do, as i havnt paid attention until now. i havnt tried data logging yet either so i cant comment on that. ill try it tomorow or the next day.
Old 03-11-2014, 05:17 PM   #96
wparsons
wparsons's Avatar
@shiv@vishnu, not sure if you saw my earlier offer, but if you need someone to run OFM through a debugging environment while pulling logs to see what exactly is crapping out I can help with that.
flickr
Old 03-11-2014, 08:32 PM   #97
wparsons
wparsons's Avatar
Tried to pull some a new log off the tablet today, still no luck.
Updated OFM to a freshly downloaded 1.07 again, re-updated the template from a freshly downloaded copy again, took a log with the default 12 channels and it still crashes OFM when trying to download the log.
I'm also getting the IAM dropping quite a lot in daily driving (~0.5-0.7) running 1.56b stage 1, so I'd love to pull the logs to see why.
flickr
Old 03-11-2014, 11:05 PM   #98
steve99
Drives: FT86
Hi @wparsons,
I had same issue IAM dropping in daily non-spirited driving in 1500-3200 rpm range dropping IAM. Was fine during more spirited driving. (1.5 stage 1)
Logs showed FBCK in that RPM range quite often ranging from -0.67 to -2.3
As per "tip in knock on turbo" thread pulled 0.35 from a few rpm/load cells in "Ignition max A" and much improved FBCK and no FLCK (using Tactrix to log as well) much less often and less severity only -.03 or -0.67. Have not had my IAM drop since. Just looked over latest logs and IAM =1
I am sure the stock tune was worse but didn't have logging to check back then
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 01:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 10:05 AM
OpenFlash Tablet Firmware 1.19 Now Available: Stores up to 5 ROM on the OFT Shiv@Openflash Software Tuning 33 12-20-2013 10:38 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 01:10 AM
