Old 03-03-2014, 01:02 PM   #99
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Originally Posted by cdrazic93 View Post
And if I was able to install it myself?
Given the few complaints stemming from what might appear to be self-install related issues, I would recommend against it.
Regards,
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following User Says Thank You to Drift-Office For This Useful Post:
Pete156 (03-03-2014)
Old 03-03-2014, 02:58 PM   #100
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Regards,
I must agree with this
I had my AVO kit professionally fitted and tuned in August last year, and have not experienced any of the problems or issues the "self install" people have had. In my opinion, it was all money VERY well spent
Pitman is offline   Reply With Quote
The Following 2 Users Say Thank You to Pitman For This Useful Post:
cdrazic93 (03-03-2014), Drift-Office (03-04-2014)
Old 03-03-2014, 08:31 PM   #101
ramiram1984
Drives: 2016 STi DGM
Originally Posted by Suko View Post
Just wondering if any one has driven or has their own AVO turbo car, and if it's worth the cash?
http://www.ft86club.com/forums/showthread.php?t=42482
may want to revisit that.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 03-10-2014, 01:47 AM   #102
Jesse1292
Jesse1292's Avatar
Drives: Black 2013 BRZ Limited M/T
Just like suko, im looking to get the AVO turbo. Would this turbo be a perfect choice for me? I daily drive my car and will probably rarely see any track time.
Jesse1292 is offline   Reply With Quote
Old 03-10-2014, 04:32 AM   #103
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Let's put it like this. I daily drive my car went turbo at 3,040 miles with the AVO kit. Have not had any issues with the car or kit. I'm currently at 13,545 in less than 6 months. Will be going E85 in two weeks. Every supporting mod is completely stock: injectors, fuel pump, radiator. I just recently replace my clutch as it began to slip. Currently running 10psi on shitty 91 oct making 280 whp and about 232 wtq. Will be planing to track the car in a few months after I get my tax returns for a cooling solution.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
The Following 2 Users Say Thank You to DesertFrs For This Useful Post:
Jesse1292 (03-10-2014), SkAsphalt (03-10-2014)
Old 03-10-2014, 02:11 PM   #104
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
mine is going on e85/flex fuel in a few weeks hopefully. everything is ordered. it will be tuned by ptuning, same place it was tuned at for the current 93 octane setup. setup will be
avo base kit
avo 8 psi wastegate actuator
plm 2.5" overpipe
non catted front pipe 2.5"
perrin non resonated cat back 2.5"
ecu controlled boost solenoid
flex fuel kit/zeitronix (input into the ecu will be through the rear o2 harness)
dw700 injectors (already installed)
dw65 fuel pump
im at 298/258 on 93 at 10psi. e85 should be fun. hopefully around 17psi
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 03-10-2014, 02:54 PM   #105
M1K3
M1K3's Avatar
Drives: vrooom...
I can't wait to see the dyno numbers on this!
M1K3 is offline   Reply With Quote
Old 11-11-2017, 07:13 AM   #106
rx3
I'm interested in this kit, because it appears to be the only kit that has the paperwork necessary to get it past inspection where I live.
I only want to use it for autocross purposes on E85 and because of it care really only about power above 4000 rpm. (Our autocrosses are relatively fast. We can reach speeds of up to 160 km/h. So maximizing power at higher rpms would be beneficial).
I would like to install this kit but switch to a larger turbocharger.
Is this possible (I read that there are space and maybe other constraints) and if yes what are the options?
For instance, I did read GT2817R, GTX3076R (Garrett) or T3 60 series (Turbonetics) or Precision Turbo 5858.
What turbochargers have actually been mounted/tested on this kit?
rx3 is offline   Reply With Quote
FI worth it? Gt86_nick Forced Induction 62 01-28-2014 12:55 AM
gt 86 worth 40k!!!??? 12345qwerty Scion FR-S / Toyota 86 GT86 General Forum 29 04-13-2013 10:56 PM
Is it worth it? Greaser Scion FR-S / Toyota 86 GT86 General Forum 45 08-10-2012 10:15 AM
is this worth doing denverizzles Engine, Exhaust, Transmission 7 08-03-2012 11:35 AM
What's this worth? Sport-Tech Other Vehicles & General Automotive Discussions 5 04-12-2012 10:21 AM
