Old 03-08-2014, 02:09 PM   #71
elrod
elrod's Avatar
Drives: WRB BRZ Limited MT
Originally Posted by wparsons View Post
^^ are you also having the tablet update everytime you connect it to a computer (with internet)? I'm having the same issue, and mine keeps updating (to the same version) every time I connect it to open flash manager.
I suspect maybe the update was partially unsuccessful on the tablet, and it isn't playing nice with OFM?
Yes, mine sez that it updates every time I connect it to the computer. From my memory, that has always been the case.
elrod is offline   Reply With Quote
Old 03-08-2014, 05:52 PM   #72
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
I've been having trouble downloading logs as well. OFM will stop responding after I have it "Read". Running Windows 7 OFM 1.06 with OFT 1.23.
If I remember right, I'm only logging the original channels from 1.22 plus road speed. Could that additional channel be causing problems?
amaciose is offline   Reply With Quote
Old 03-09-2014, 09:04 AM   #73
wparsons
wparsons's Avatar
^^ It's not road speed, because I'm having the same issue without logging road speed. Someone else seems to be having the same issue with the original 12 channels logged as well.
flickr
amaciose (03-09-2014)
Old 03-09-2014, 09:47 AM   #74
yoruck
Drives: ford fiesta st 150
yes i have the issue with the original 12 channel logged
yoruck is offline   Reply With Quote
Old 03-09-2014, 09:34 PM   #75
wparsons
wparsons's Avatar
Shiv, is there anything we can pull from OFM to help you with this?
If you're open to the idea and can send me the source code I can run OFM in a debugger and get more details on what exactly is failing? I'd have no issue signing an NDA or something to prevent the source from leaking out. I have no real interest in reading the code, just trying to help out where I can
flickr
Old 03-09-2014, 10:15 PM   #76
steve99
Drives: FT86
Its working ok for me on Win Xp, changed to a few different channels including road speed and ok I am on G rom though
Just noticed your on OFM 1.06 ?? current version is 1.07 might be worth upgrading
Old 03-10-2014, 10:40 AM   #77
wparsons
wparsons's Avatar
I'm having the issue with OFM 1.07, I downgraded to 1.06 just to try and had the same issue.
flickr
Old 03-10-2014, 11:21 AM   #78
amaciose
amaciose's Avatar
Upgraded to 1.07 and still having the issue.
Old 03-10-2014, 01:41 PM   #79
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Hi guys,
Could someone who is having this problem (reading datalog .csv file from OFT) give me the list of datalog channels they have configured. I'd like to reproduce this issue here if possible. So far I haven't run into any problem on any of the computers we have here. But perhaps there is one channel that is giving a problem and I don't have it in the list of logged channels.
Also please give me your software CAL ID too because different CAL IDs will request different logging channel IDs when it comes advance multiplier.
Shiv@Openflash is offline   Reply With Quote
Old 03-10-2014, 02:24 PM   #80
elrod
elrod's Avatar
@shiv@vishnu
I refer you to post #71 above. My cal ID is ZA1JA00C. When I data log the original 12, it works [engine speed, throttle, maf voltage, engine load, ignition advance, KC learned, AFR, ADV multiplier, VVT intake, VVT exhaust, STFT, LTFT.] When I omit two [VVT intake and VVT exhaust], OFM locks up on the laptop. The same thing results when I insert new parameters (in those open slots) such as ambient temp and coolant temp. Hope this helps.
Old 03-10-2014, 03:12 PM   #81
wparsons
wparsons's Avatar
I'm running a ZA1J700C, doesn't matter what channels I log it doesn't work. I've tried the original 12, plus a mix of others. I haven't had time to log just one channel, then keep adding one more until it breaks though.
flickr
Old 03-10-2014, 03:16 PM   #82
Drofnum
Drives: CBS Subaru BRZ
I just got my OFT, loaded a new flash up and all went well. Love the tune. But i am having a problem logging, any time i try to start it up i get an error. I've attached a picture showing the error.
Drofnum is offline   Reply With Quote
Old 03-10-2014, 03:21 PM   #83
steve99
Drives: FT86
This happens with engine running ??
Old 03-10-2014, 03:35 PM   #84
Drofnum
Happens with engine running yes. Tried it with the key on and engine not running as well as engine running. I could never get it to start up. I didnt have a lot of time since i did this on my lunch hour so I will do a bit more troubleshooting after work.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
OpenFlash Tablet Firmware 1.19 Now Available: Stores up to 5 ROM on the OFT Shiv@Openflash Software Tuning 33 12-20-2013 09:38 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
