Drives: 2013 Ultramarine Scion FR-S
CV joint problem?
Hi guys,
Quick question. My FR-S makes a clicking sound (exactly like hot metal cooling down after you shut off the car) . This sound only happens when I turn or change lanes. It also only happens once per turn/lane change. Is this a bad CV joint? |
#2 |
Drives: '13 FRS - STX
Could be a loose axle nut, you can take it to the dealer and have it greased and re-torqued, those with the click have reported that this can solve the click.
Edit: Should be a simple warranty operation, maybe half an hour of time if they're greedy enough to charge. |
#3 |
Drives: Scion FR-S
CV joint issues do exist on occasion based on the setup of the car and how it has been driven (Lowered, clutch drops with sticky tires, etc.)
#4 |
Is this an urgent problem? I have "my hands tied behind my back" at the moment and probably won't be able to bring it in for 2-3 weeks.
Sent from my Nexus 4 using Tapatalk |
#5 |
Also my car is bone stock and I also purchased Toyota Extra Care Platinum so I won't have to worry about them charging me
![]() Sent from my Nexus 4 using Tapatalk |
#6 | |
Re-reading your OP it sounds a bit weirder than I thought, it may be something bigger but I think you should be ok if you take it easy. Hell it could be the rear deck lid popping, completely unrelated to suspension/drivetrain. Those extra care packages may not cover everything, despite what the salesman tells you at the time. I'm not too interested in the details but I would read the package thoroughly before being sure.
#7 |
Drives: 16 CBS WRX Limited
Weird. I'm getting the same sound when my car is on regardless of it moving.
#8 | |
#9 | |
#10 |
Yeah, I'm pretty sure it isn't the joint, but it's just odd to me that my car is making that ticking noise while the car is on and it's getting more frequent.
#11 |
Drives: '24 GR86
CV joints can make a clicking noise while turning and while driving straight.
If it's happening when you're turning, the cv joint is obviously going out, but it can still last a bit before being replaced (although I wouldn't put it off). If it's clicking while driving straight, it's about to go... Doesn't sound like a cv joint issue though. Stock suspension and ride height with normal everyday driving isn't enough to cause the OEM cv joints to prematurely wear out like that.
#12 |
Drives: FR-S 6MT
#13 | |
Drives: frs
Mine is clicking when taking off from a stop, especially while turning ![]() Stock suspension and ride height with normal everyday driving (except for 4-5 autocross events in the past two years) |
#14 |
Racing Enthusiast
Drives: Bone stock 2019 BRZ manual
Did you ever get yours fixed? I'm having a similar problem...
“$20 per diddle? I can diddle myself for free and do a fine job”
| exlpoded cv joint | ben15r | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 51 | 09-01-2018 04:12 AM |
| Front ball joint dimensions | J-W | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-02-2013 05:31 PM |
| loose ball joint | Grip Ronin | Issues | Warranty | Recalls / TSB | 15 | 07-09-2013 01:16 PM |
| What if...Honda and Mazda joint together to come up something to compete with 86? | 86BRZ | FR-S / BRZ vs.... | 77 | 02-11-2013 05:51 PM |
| Toyota and GM Joint Venture | Dragonitti | Other Vehicles & General Automotive Discussions | 19 | 03-31-2011 03:34 PM |
