| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#1597 |
cam bolts
Just have camber questions. My 18x8.75 +35 XXR 527 hyper silver wheels, Eibach Pro Kit, hub centrics, and lugs are in my living room cussing me out for not installing them yet. I ordered +/- 1.75 range cam bolts for the front, but they were backordered. I've been waiting to install everything at one time. Is my cam bolt range selection enough or should I get some with a wider range? Secondly, with the Eibach Pro Kit installed, will I need control arms on the rear to adjust camber? Tires only last me me about 12k miles anyway, because I drive my dd car like someone is chasing me. I dont want to go through extra tire wear because of unnecessary camber, since I'm not taking it on the track.
#1598 | |
#1599 |
cam bolts
Thanks! I appreciate the help. I guess I'll see what the camber is after lowering the inch to see whether control arms are necessary. I have hoped that maybe with such a small drop that the camber would still be pretty close to factory spec.
#1600 | |
Drives: Too heavy
![]() http://www.ft86club.com/forums/showp...postcount=1463 |
#1601 |
Drives: 2013 BRZ Premium
#1602 |
Drives: raven black frs
Looking for a set of xxr 530 if anyone has em please let me know. 18x8.25 or 8.75 +20 chromium black preferred preferred PM me if you have them for sale or no where i can buy them for under 600 shipped!
#1603 |
Time Traveller
#1605 |
Drives: Subaru BRZ Limited
Someone please help me! Looking to buy XXR 530 Chromium Black but I don't like the front poke you get with 18x8.75 +33.
Are there any pictures of someone with 18x7.5 +38 front and 18x8.75 +33 rear? I've gone through 40 pages of this thread so far and I still haven't seen anyone with a staggered setup.
#1606 | |
Drives: 2013 FR-S Argento
Sent from my QMV7A using Tapatalk |
| The Following User Says Thank You to bfrank1972 For This Useful Post: | ericmpena (03-11-2014) |
#1607 |
Drives: '13 FR-S
#1608 |
Seems Legit
Drives: Toyota
Figured I would try something a little different with the wheel caps
Chrome lugs Chrome center caps 55mm custom 86 center cap sticker ![]() ![]() ![]() ![]() ![]() Pardon the dirt. I just got my wheels out of storage.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#1609 | |
Is it okay to drive like that, or will I see uneven tire wear?
#1610 | |
Yeah camber is how much the wheel is tilted inward - stock our cars don't have any adjustability with this. You have it right though, you can get adjustable camber bolts (the bolts with cams on them) and adjust the camber (tilt) so the wheels tilt inside and the top of the tire sits flush with the top of the fender and give you a nice aggressive look. Assuming your car is aligned properly by a good shop after lowering and adjusting camber, running the camber you'll need (-1.3 to -2 degrees) won't make a big difference in tire wear. Toe changes from lowering are the biggest culprit to tire wear, and should be dealt with once you get your car aligned. A terrific benefit from a mild increase in camber is your front end will bite/feel better in turns. Anyway try adjustable camber bolts and see if you can get enough camber with them - if you need more than that you'll have to go with something else like camber plates.
| Tags |
| 17 wheels |
| Wheel Directory: ProDrive GC-012L 18x8.5 +48 | MarkMash | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 05-12-2013 03:55 PM |
| Is there a thread for 'people doing stupid things in their brand new car' thread? | Symbiont | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 02-18-2013 12:24 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
| Are there any RWYB Wheel to Wheel road races? | LexusFman | Other Vehicles & General Automotive Discussions | 1 | 11-05-2011 12:28 PM |
