Old 03-07-2014, 11:31 AM   #141
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@Element Tuning the log that you posted with 'waves' - was the DI issue from failed seals or a different DI issue? Wondering what the latest on seals are as it's giving me some concern regarding tracking this summer.
1Cor10:23 is offline   Reply With Quote
Old 03-07-2014, 11:33 AM   #142
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by andrew20195 View Post
This describes the previous AVCS system. The AVCS on the chain motors does not have high pressure springs internal to the cam sprockets. It uses valve spring pressure. This is probably one of the reasons why they've been having issues setting cam codes, as many of them are set when the intake cam gets stuck advanced due to design flaws with the early sprockets.
Well that sucks, was there a part number or casting number change?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-07-2014, 11:38 AM   #143
andrew20195
Drives: 2013 Subaru BRZ
Not sure on that, but it's generally on cars manufactured before July 2012, when the countermeasure went into production.
andrew20195 is offline   Reply With Quote
Old 03-07-2014, 12:24 PM   #144
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
It was from a DI pump with the "crickets" sounds and I could here it struggling with the OEM tune at AVCS onset. I suspect this was the standard failure as the car still ran and would hold decent pressure at high RPM.
Sorry I don't know as the tech had told my customer that this was the third different revision or part number that he had to install.
Element Tuning is offline   Reply With Quote
Old 03-07-2014, 12:30 PM   #145
OrbitalEllipses
Drives: Attitude
If there's a superseded P/N any number of Subaru (or Toyota) techs we have kicking around on the forum would be able to provide that knowledge. So let's get a few into this thread?
Old 03-07-2014, 01:03 PM   #146
Element Tuning
I think you're misinterpreting the technical document as it does not use the "engine valve springs." They are talking about the spring in the "spool valve." There are actually a number of springs in the variable cam timing mechanism of the FA20.
What is unique to this over the EJ is the ability to "lock" the cam in place and as we've seen with tuning you have both advance and retard of the cam unlike the EJ which can only advance from the centerline.
Hope that helps.
Thanks,
Phil Grabow
Old 03-07-2014, 02:27 PM   #147
andrew20195
I'm quoting directly from the Subaru Technician Reference Booklet on the chain driven engines. Like I said, it's the only source I can find with this info, but seeing as how closely Subaru engineers are involved in technical training, I'd be surprised if they got it wrong.
From my earlier post:
The new system does not depend on a hydraulic rotor to function. Instead oil is moved from
one chamber to the other which reduces the volume of oil needed to operate the AVCS.
and
A spool valve pressed into the Camshaft rotor controls the oil flow into and out of the Advance
and Retard chambers. The force needed to rotate the Camshaft within the Camshaft sprocket
is delivered by the valve springs.
The oil in the sealed chambers holds the Camshaft rotor into a fixed position. If oil is transferred
from one chamber to the other, the Camshaft rotor and Camshaft rotate within the Camshaft
sprocket.
All the springs shown in the Toyota document appear to be check valves from what I can see.
Old 03-07-2014, 04:20 PM   #148
Element Tuning
You do see the FRS document picture I've attached with the "Advance Hydraulic Chamber" and the "Retard Hydraulic Chamber" right? I've attached another image showing the structure of the hydraulic chambers.
I'm not making this up and I happen to have both the intake and exhaust cams and actuators sitting on my desk It uses hydraulics but unlike the older AVCS is has separate chambers for Advance and Retard which is really sweet!
Those are the facts, let's move on
Old 03-07-2014, 07:07 PM   #149
regal
For those of us out in he skicks I don't think the localish Scion dealership will have a cue, just insist on new heads if something is wrong?
Mods:
Old 03-08-2014, 09:18 AM   #150
arghx7
Drives: car
I know the AVCS is not totally on topic, but just for clarification before we move on:
These systems are called "cam torque" activated, but they still use oil as a control mechanism (see attached paper). As the cam hits the bucket (in Ford's implementation) or the roller finger follower (Subaru), the force makes the oil slosh inside the chambers. The spool valve is there to coordinate that sloshing in a controlled way.
In a conventional AVCS system, the oil is basically forced by hydraulic pressure to phase the cam. The source of energy is ultimately the oil pump. With this system, the oil is a way of transferring the force of the cam by sloshing in the desired direction at the right time.
The intermediate locking position, which I didn't realize the FA20 was using, is a cold start emissions countermeasure, especially for meeting 2013 model year MSAT regulations of HC/NMOG at 20F/-7C testing. Aisin also uses that type of technology for Nissan applications. By dialing in overlap during cranking you get reburn of HC emissions that normally would have been thrown out the exhaust and unconverted.
The above image compares running no intake cam advace, versus hydraulically moving the cam at startup, versus having an intermediate lockpin with no delay.
The Following 4 Users Say Thank You to arghx7 For This Useful Post:
andrew20195 (03-08-2014), DAEMANO (03-08-2014), Ralph Spoilsport (03-08-2014), SkullWorks (03-11-2014)
Old 03-09-2014, 03:50 PM   #151
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
So in plain english, have we come to a consensus if the OFT/Perrin noise is detrimental to the life of the engine?
I've read the entire thread but got lost pretty quickly in the technical language!
calmtigers is offline   Reply With Quote
The Following User Says Thank You to calmtigers For This Useful Post:
topazsparrow (04-07-2014)
Old 03-09-2014, 08:46 PM   #152
wbradley
Sarcastic SOB
wbradley's Avatar
Very unlikely detrimental. But some possibility it will reveal a weakness in the fuel systems ability to maintain constant pressure at throttle tip-in. Nothing to worry about.
Old 03-09-2014, 10:30 PM   #153
wparsons
wparsons's Avatar
IMO, it sounds like the bad noise might be the sound of a DI pump wearing out, but is more likely to annoy you than actually accelerate pump failure.
flickr
Old 03-10-2014, 06:18 AM   #154
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Having logged a cumulative 65,000 test miles on Perrin tunage I can only say that there is no likelihood of damage from the VVT or tune settings
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
The Following 4 Users Say Thank You to kiichiro For This Useful Post:
86-tundra (03-10-2014), calmtigers (03-10-2014), housecat (08-12-2015), TofuJoe (09-24-2016)
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 07:21 PM
First tank OFT E85 tuning. Noise? Tromatic Software Tuning 2 02-20-2014 06:43 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 02:47 AM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 11:06 PM
Knock/valve slap/crick noise under accel yomny Issues | Warranty | Recalls / TSB 47 01-07-2013 09:53 PM
