Old 03-07-2014, 01:45 PM   #295
raven1231
Originally Posted by stevo_12v View Post
Just had this installed... driven for 2-3 hours since.
If your car is a keeper/or you are a track rat... This is one of those 'must have' mods.
How much did it run you total?
Old 03-07-2014, 02:41 PM   #296
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Around $700-ish for the Part, and a further $900 for the install(I had a whole bunch of other stuff done while the car was at the workshop(from build thread):
- STi Group-N Engine Mounts installed
- STi Group-N Transmission Mounts installed
- DEI Titanium Heatwrapped wrapped on the whole exhaust(I supplied heatwrap)
- Toyota 4.556:1 installed
- Whiteline KDT 925 Diff Insert bushings installed
- Changed out TRD pads(worn) back to stock(until my Project Mu HC+'s arrive)
stevo_12v is offline   Reply With Quote
The Following 2 Users Say Thank You to stevo_12v For This Useful Post:
DAN_BRZ (03-07-2014), RehabJeff86 (03-07-2014)
Old 03-07-2014, 06:29 PM   #297
jdubz13frs
jdubz13frs's Avatar
Drives: 2013 Scion FR-S 6MT
Just so you all know, modern subarus use the front abs sensors as the vehicle speed sensor. if one goes bad, cel and no speedo. So changing gearing and such will not affect your speedo. However, this is based on a known wheel/tire diameter (~24.6") so wheels/tires that are different overall dia. than stock WILL affect your speedo. just my .02 to this thread...
jdubz13frs is offline   Reply With Quote
The Following 2 Users Say Thank You to jdubz13frs For This Useful Post:
Kronos (03-07-2014), racecaresuaceb (05-14-2014)
Old 03-07-2014, 06:40 PM   #298
raven1231
Thinking about pairing this with my Phantom
Old 03-07-2014, 06:50 PM   #299
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
That would be one snappy 86 for the price
Kronos is offline   Reply With Quote
Old 03-07-2014, 06:54 PM   #300
raven1231
I know ha ha might just have to
Old 04-25-2014, 06:22 PM   #301
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
This is going to happen. I have a feeling this will be a bigger change by quite a bit than a tune on my AT.... Don't know how I'll come up with cash, but I need to do this so I can document it for the AT guys, and do some comparisons, stock AT vs modified and modified vs MT. I expect it should be close to the stock MT gearing now, maybe slightly shorter.
zohare is offline   Reply With Quote
The Following 2 Users Say Thank You to zohare For This Useful Post:
JonAvalon (04-25-2014), Lonewolf (04-26-2014)
Old 04-25-2014, 09:52 PM   #302
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Originally Posted by RENN Spec View Post
Picking up my Cusco 4.556 FD next week. Wonder if they are compatible with OS giken Super Lock LSD?
No one has answer to this??
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 04-25-2014, 09:59 PM   #303
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
If the LSD is for the GT86/FRS/BRZ then there should be no reason why it wouldn't work. I have around 5k miles on my 4.56 FD and love the added acceleration. It isn't as drastic of a modification as one might think. I had to drive next to a friend in his FRS to see what RPM he was at at any given speed and it never was excessively different. And for the worry warts who wonder about the change in MPG mine dropped not even 1/2 MPG.
Dustin is offline   Reply With Quote
The Following 2 Users Say Thank You to Dustin For This Useful Post:
RehabJeff86 (04-25-2014), trigger happy (04-25-2014)
Old 04-25-2014, 11:49 PM   #304
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Well..in that case... "five eleven"!!! ...errr, 4.88 I guess would be good enuf lol
fooddude is offline   Reply With Quote
Old 04-26-2014, 12:02 AM   #305
trigger happy
Bang Bang
trigger happy's Avatar
Drives: 2013 Raven FR-S
Somebody should post a video of the improved acceleration
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers
trigger happy is offline   Reply With Quote
Old 04-26-2014, 12:55 AM   #306
Dustin
Twin Screw You
Dustin's Avatar
4.88 with an automatic I think would be doable but not with a manual though. Not unless you intend to stay off the freeway or only cruise at like 50-55 mph.
Old 04-26-2014, 12:56 AM   #307
Dustin
Twin Screw You
Dustin's Avatar
It would be hard to notice the difference unless you had a side by side video of 2 tachometers and speedometer, one with the stock 4.10 and one with the 4.56.
Old 04-26-2014, 10:17 AM   #308
Gilwith1l
Gilwith1l's Avatar
Drives: stock brz. saving my money for ls1
Someone needs the post 1/4 mile times before and after
Gilwith1l is offline   Reply With Quote
The Following User Says Thank You to Gilwith1l For This Useful Post:
*KID* (04-26-2014)
cusco final drive
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 08:53 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 03:21 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 01:17 PM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 10:49 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 07:54 PM
