Old 10-13-2013, 05:06 PM   #1
P@ul
Apostle
P@ul's Avatar
Drives: Fast Microwave
DIY: Used 2012 Toyota Display Audio with Entune
BACKGROUND
WHO:
- Me, aka cheapass
- 2013 Scion FR-S with the regular Scion stereo
WHAT:
- Used 2012 Corolla Nav / Entune off of eBay
- I had to buy a new entune wiring harness, OEM "C" scion stereo brackets, and a gps antenna.
WHY:
-Save some $$$!!! I got it WAY cheaper than buying a new Scion Display Audio unit, and extension box.
- No custom wiring harnesses because everything plugs in!
- Keep your factory microphone, usb connector, and auxiliary input.
- It’s also ready to add an OEM backup camera and XM radio.
Differences of Toyota Display Audio vs Scion Display Audio ?
Positives
- The startup screen is the Toyota logo for all you JDM types.
- I believe you can upload a different image via USB if you want to change it so that’s pretty moot. Here's a link: http://toyota-entune.com/forum/viewt...70dd1c23#p1818
Negatives
- No vehicle specific audio tuning (xA, xB, xC, xD, FR-S, etc)
- No SSP (feel, hear, etc.)
- No voice command button (picture); You get an eject button, and a pause/play button.
PARTS
2012 Toyota Corolla 6.1” Display Audio Stereo
Toyota Part: ? 86140-02110, CVH-3618ZT ?
Made by Pioneer, P10313
Software Version: 01700PU
2012 Entune Navigation Module
Toyota Part: PT296-47120 EA
Made by Harmann Automotive
Software Version: Main 1.8.4, Sub 1.6.18
Scion OEM “C” Display Audio Brackets
THIS REQUIRES REUSE OF THE ORIGINAL BRACKETS from your Scion OEM Stereo
Holds the Display Audio and Extension Box together
Toyota Part: PT591-00140
Entune Pass Through Harness
Connects the Entune Navigation Module to the Display Audio
Toyota Part: PT296-47120-AB
GPS Antenna
Toyota Part: ?
I bought aftermarket. http://www.ebay.com/itm/320819856679...84.m1439.l2649
REQUIRES MODIFYING THE PLUG, DO THIS BEFORE YOU PUT IT IN THE CAR! Trim the two tabs circled until it fits into the Entune module.
INSTALLATION
Tools
  • 10mm socket with extension
  • 8mm socket
  • plastic pry tools
  • stubby phillips screwdriver if you want to mount gps behind your gauge cluster
  • zip ties for tidying up excess gps antenna cable
Procedure
- remove side and stereo facia
- pops out by hand
- remove oem stereo
- 10 mm socket with extension
- remove mounting brackets and reinstall onto display audio
- 8mm socket.
- Scion OEM “C” brackets for Display Audio
- Scion OEM brackets from your original Stereo
- remove gauge cluster: OPTIONAL IF YOU WANT TO MOUNT GPS ANTENNA BEHIND THE CLUSTER
- remove screw from hood
- pop out shroud, use plastic pry tools
- remove hood, pulls strait out
- remove two screws from the gauge cluster, pull strait out and unplug
[ame="http://www.youtube.com/watch?v=3NU5ba3ChgM"]Remove the Gauge Cluster of FR-S, BRZ - YouTube[/ame]
- mount gps antenna
- my antenna was magnetized so i put it on a bracket behind the gauge cluster
- zip tie loose cables
-install the display audio
- make sure you plug your radio and gps cables into the ENTUNE module
- reinstall everything
-reset your entune module via service menu
- http://priuschat.com/threads/entune-...n-risk.126230/
- settings -> nav voice volume -> up down x3
- reset module and gps location
-drive the car
- The nav map wont update your location until you physically move in the car
- pair your bluetooth with your phone
- enjoy!
NOTES
TOYOTA DISPLAY AUDIO:
Positives:
- Bluetooth seems to work better for sending song information versus the original scion stereo. Pandora sends more information on my Samsung Galaxy S2.
- Phone capabilities are better; it’s much easier to use your phone book and history. Voice command on my Galaxy S2 sucks so I prefer to use Display Audio’s interface.
- The night lighting color matches the orange in the rest of the interior.
Negatives:
- The sound is pretty flat. The factory equalizer adjustment is a joke (low, mid high). I boosted some low end, and have used my phone’s built in equalizer to compensate. Not sure how much my brain is making up but I remember the original stereo sounding more full. I’d like to compare it to someone else’s OEM Scion setup.
- I would really like to reflash this thing to Scion’s programming. I’m sure there is some way to do it. If you have any info, please hit me up.
ENTUNE EXTENSION:
- Enables Navigation
- Enables texting capabilities for your phone. I haven’t tried it, seems pretty gimmicky.
- Entune Apps: Seems super gimmicky, only useful ones appear to be weather, traffic, Pandora and iHeartRadio
- Requires the creation of an online account to use the apps, which asks for a vehicle VIN. =(
- It has been recently made free. http://www.engadget.com/2013/09/12/t...s-entune-fees/
- Operates in conjunction with an Entune app for your phone. I hear the app sucks, go figure.
- Entune is an upgradeable system; requires the Entune app or dealer service. Priuschat has uploaded version 2.1.0. I hear it breaks bluetooth connectivity for some phones so I wouldn’t be in a rush to upgrade. I’ve also read that it forces the use of the Entune app, which is not compatible with all phones. I would avoid it for now.
-I’m wondering if this can also be reflashed to become Bespoke with Aha. I’m not sure how much difference there is but both extension boxes are made by Harman and look similar, so I’m guessing the hardware is the exact same. If you have any info, please hit me up.
ENTUNE Update - V 5.2.0
Official Entune Update directly from Toyota!
https://securedp.toyota.com/download-app/toyota
P@ul is offline   Reply With Quote
Old 10-31-2013, 03:10 AM   #2
D1cker
Drives: B9 S4/ND2
TL;DR
D1cker is offline   Reply With Quote
Old 10-31-2013, 11:36 AM   #3
userjack6880
userjack6880's Avatar
Drives: Raven FR-S MT
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT
1978 Triumph Spitfire 1500
userjack6880 is offline   Reply With Quote
Old 03-07-2014, 12:17 AM   #4
P@ul
Apostle
P@ul's Avatar
ENTUNE Update - 3.2.0
ENTUNE Update - V 3.2.0
Hurray! Thanks to our sister forum Toyota Nation (TY Glramos!), We now have an update to Entune 3.2.0!
Check it out here: http://www.toyotanation.com/forum/32...load-link.html
I just updated from an ancient 1.8.4 to 3.2! And I'm happy to report that it fixed my Pandora issue (wouldn't play high quality audio).
Just like the instructions say, download the files and copy the iso + txt to a flash drive titled 14A. Start your engine and plug it in, follow the directions on screen and wait!
Old 03-07-2014, 01:18 AM   #5
DragonDriver5
DragonDriver5's Avatar
Drives: 2014 FRS, 77 Celica, 88 Supra Turbo
Awesome mods.. I'll be looking into this sometime for the GPS!
Thank you
SPOTOC - Spokane Toyota Owners Club
Toyota - Lexus - Scion
https://www.facebook.com/spotoc
DragonDriver5 is offline   Reply With Quote
Old 03-07-2014, 09:06 AM   #6
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
I'm assuming you have to have EnTune already and not AHA?
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 03-07-2014, 01:29 PM   #7
P@ul
Apostle
P@ul's Avatar
You could try but it probably won't work. I'm pretty sure the hardware is identical but the update probably checks if it's the correct system. The update identified my Entune version prior to installation.
I now have iHeartRadio, MovieTickets.com , and OpenTable. From what I can tell, Aha has more functionality than Bespoke. *shrughs* I've never used it.
Old 03-07-2014, 02:24 PM   #8
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
What about sub out for subwoofers?
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 03-10-2014, 02:07 AM   #9
P@ul
Apostle
P@ul's Avatar
I don't see anything in the manual about subwoofers.
http://www.scion.com/manuals/nav_audio/
Old 03-10-2014, 02:08 AM   #10
P@ul
Apostle
P@ul's Avatar
Sorry, I misread your post. No, I do not have the Scion Aha extension box. I have an Entune extension box out of a Toyota.
Old 03-10-2014, 02:23 AM   #11
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Has anyone changed the start up screen for the 14 unit using this method?
Old 03-13-2014, 12:22 PM   #12
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
Is this effectively the same as the '14 Bespoke unit? Based on the user manuals, it appears to be the case.
Shame that the FR-Ss are essentially still using the original Toyota Entune units. I have the latest Entune unit on my '14 Rav4 and it is quite the upgrade (higher res screen, little more user friendly, more user friendly nav, better and more capable voice commands). I much prefer it to the 7" HDD Entune unit that is in my '12 Prius v Five (advanced tech package).
Quentin is offline   Reply With Quote
Old 03-13-2014, 02:44 PM   #13
P@ul
Apostle
P@ul's Avatar
My Toyota unit? It's a 2012 corolla entune unit, it might be the same as your Prius V. I think it's the same, I know it's the same one as the Prius C.
Is your Rav4 unit one of the systems with a custom dash integration? Or is it a standard DIN style one? All the scions use the double DIN style head unit, so until the Toyota corporate double din gets upgraded then no dice. I'll keep a look out though, this screen is ancient tech.
Old 03-13-2014, 03:46 PM   #14
Quentin
My v has the 7" unit. HDD based instead of flash like yours and all the new ones. It was sort of a relic that had Entune adapted to it.
Rav is integrated, but I'm more talking about the software rather than the physical unit itself. Looking through the Scion manuals, the screens look almost identical to the '12 Camry Display Audio and Display Audio with Entune units. Basically, if you've messed with a '14 FR-S bespoke, how similar is it to the '12 corolla Entune you have?
I guess we'll see if the soon to be released '15 models get a new radio.
FS: 2013/2014 Toyota Display Audio defylogik Audio/Visual, Electronics, Infotainment, NAV 28 09-11-2013 04:32 PM
FS: Scion Display Audio HU ($350 shipped) SpeedLab Audio/Visual, Electronics, Infotainment, NAV 0 09-06-2013 12:13 PM
Scion Display Audio: New Base Unit DieselxIndustry Electronics | Audio | NAV | Infotainment 21 08-14-2013 03:21 PM
2014 Display Audio SleePi Electronics | Audio | NAV | Infotainment 1 08-13-2013 10:21 AM
WA Next meet Sun 30th June - Sprintex Test Drive AND A One Audio display plus special invisage Australian Meets & Events 2 07-22-2013 03:20 AM
