#57 | |
| The Following User Says Thank You to celica73 For This Useful Post: | Shiv@Openflash (03-06-2014) |
#58 |
Drives: 2013 Argento FR-S
#59 |
Drives: 2013 FRS
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | Terrapin77 (03-06-2014) |
#60 |
Drives: Toyota 86
#62 |
Anyone else noticing that it updates every time you connect it to a computer now? I've had it download the same update 4 times today.
I also can't seem to pull a log file off the tablet without freezing open flash manager. It gets to 100% in the pop up dialog, but when that goes away the main window freezes and never comes back. It's a pretty big log (~25 minutes), but I imagine that shouldn't be an issue.
#63 |
Drives: 2013 FRS
Make sure you are running the new OpenFlash Manager (v1.07). It has to be updated along with the new firmware. It is available for download on our website.
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | skuts? (03-10-2014) |
#64 |
Drives: WRB BRZ Limited MT
@shiv@vishnu please give me a suggestion on retrieving data. Car is very happily running along with Stage 1 1.55
I first updated my Win7 Pro 32-bit laptop to OFM 1.07. I then connected OFT and it did FM 1.23 update. I updated template. I took OFT to car. Selection of parameters to log worked fine (excluding fat fingers and insensitive screen). I went thru all the procedure to run a short log and all appeared (on OFT) to work just fine. Both types of display work fine with selected parameters. I returned to laptop and connected. OFM will easily read all the info for upload/download of tune files. When I switch to 'data logging' all looks OK. I click on read; it briefly shows the usual dialog and says it is reading. At that point, Win7 shows that the program is not responding and I don't get anything else. I have to quit. What should I try next? |
#65 |
Any reason why i got a tracking # from March 5 saying Pre shipment, when will this actually shipped?
Been waiting for a week now ![]() 9407803699300006542762 |
#66 | |
Drives: 2013 FRS
#67 |
Drives: 2013 FRS
We have been out of stock for several days now. And the stock we were hoping to receive today due to weather-induced delays in shipment. As soon as they get here, all pending orders will be filled. I hate giving specific ETAs but they should be here any day now.
#68 |
Drives: ford fiesta st 150
@shiv@vishnu same issue for me with the data log.
i am on OFM 1.07 on win 8 64 bit. base ECU is A00G but it seems to use stage 1 A01G with the 1.55b after download log the OFM not answear. i have select the 12 first channel in the data log option on the OFT(they are check by default). thanks for help |
#69 | |
You gave me an idea to work with. I set the OFT to data log the original 12 parameters and it worked well. I also verified same performance with a second computer. I then set the OFT to data log 8 of the original 12 parameters (omitting VVT intake & exhaust and ST/LT Fuel trim. It failed to download/display. I then set the OFT to data log 8 of the originals (as above) plus ambient temp and coolant temp (todal of 10). Again it failed to download/display. I went back to data log the original 12 and all worked well. |
#70 |
^^ are you also having the tablet update everytime you connect it to a computer (with internet)? I'm having the same issue, and mine keeps updating (to the same version) every time I connect it to open flash manager.
I suspect maybe the update was partially unsuccessful on the tablet, and it isn't playing nice with OFM?
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| FS: Openflash tablet | nguyen_er | Engine, Exhaust, Bolt-Ons | 6 | 12-30-2013 01:31 PM |
| new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 10:05 AM |
| OpenFlash Tablet Firmware 1.19 Now Available: Stores up to 5 ROM on the OFT | Shiv@Openflash | Software Tuning | 33 | 12-20-2013 10:38 AM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 01:10 AM |
