| FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum All photos, videos and other media related to the Scion FR-S and Toyota 86 |
#1527 |
__(X)__
Drives: '11 Legacy, '89 190E, '78 GS1000
![]() so much rubbing in the front. couldnt turn my wheels at all with the 18x9.5s up there so i put my stocks on, and still rubbing in the back of the liner (right under the tip of the fender vent) anyone have suggestions? are you all running liners still or are they removed? also, after a quick drive around the block im noticing some knocking in the rear. does anyone have any ideas? Im going to make sure everything is tight again... but idk. a friend mentioned it could be the preload? i dropped it as low as possible without being able to move the spring up and down... could that still be my issue? im on BC extreme lows btw...
IG: @dustin_faulkner
| The Following User Says Thank You to Kuzuri For This Useful Post: | John.Hong (03-06-2014) |
#1528 |
Drives: e92 335i, FRS, Lexus ls400
IG: nabb335 |
| The Following User Says Thank You to nab335 For This Useful Post: | Kuzuri (03-06-2014) |
#1529 |
Drives: Argento FRS
not much has changed. had a tire debead last week, then remounted it, and ordered some new rear tires..
ig: @potatoglasses // @toastedbiscuits |
#1530 |
Drives: 2013 Ultramarine Frs
#1531 | |
Drives: Argento FRS
#1532 |
Drives: Smells like tires when I drive
Would shorter end links fix the problem? Just curious because I have wheels and coilovers on the way. I could order up some rod ends to make my own end links to prevent them from hitting. I'd rather not remove my rear sway though, it'll make the car push hard and I still drive somewhat spirited.
#1533 |
#1534 | |
Drives: 400whp Scion tC
Ever just thought about lowering the car to a respectable ride height? |
| The Following User Says Thank You to SnapOv3st3r For This Useful Post: | SkAsphalt (03-08-2014) |
#1535 | |
__(X)__
I added a little more camber up front but I can move the allen screw over one more space and max it out if i need to. I put the stocks on just so I could get it on the road and drive it around the block. tires are meaty, right now. im running 245/40s from when i was only on s techs. I will be getting 225/40s soon and running spacers in the rear. (i have no rubbing issues in the rear right now btw. but thank you! i appreciate the help! and sorry for all the questions
#1536 |
Leaux Down Krewe
Drives: 2014 SSM Limited
This is the only car with respectable ride height lol
The build thread: http://www.ft86club.com/forums/showthread.php?t=31514 Follow me on IG: @rougarou86 |
#1537 |
KCCO
Drives: 2013 Raven Scion FR-S, AT
19x10 +50 rear and 19x8.5 +45 front Vossen CVT. Not aggressively lowered by any means, it is my DD. Eibach sportline springs installed yesterday. So far no rubbing issues.
Before springs After springs Sent from my SAMSUNG-SGH-I527 using Tapatalk
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/ |
#1538 | |
#1539 |
Leaux Down Krewe
Fancy, you shouldn't need to remove your fender liners. I'm running 18x9.5+30 with 215/35s and have no problems with clearance. Swapping to the 225s will help you tons.
#1540 |
__(X)__
Im on the stocks right now and my fender liner is sitting on my tire and also hitting in the back... i cant imagine that 18x9.5s with 225s on them will clear if the stocks dont?
| Tags |
| dontlike?dontlookmoveon |
| Post the Wheels You want On your FRS/BRZ!! | Zaku | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1738 | 10-11-2017 04:29 PM |
| RPF1 and PF01 aggressive fitment size requests | Crossover Auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 10-22-2012 02:30 PM |
| post VIN with any problem thread? | fistpoint | Issues | Warranty | Recalls / TSB | 0 | 10-04-2012 10:11 PM |
| Do aggressive offsets cause more debris to kick up into the paint? | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 09-26-2012 10:03 PM |
| Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 538 | 06-15-2011 02:20 AM |
