Old 03-06-2014, 04:07 AM   #29
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Originally Posted by JPxM0Dz View Post
Yeah I like the GT86 much better than the Samsung Galaxy background myself
Sent from Note III on BoBCaTROM
Agree - galaxy sucks
Ondreiko is offline   Reply With Quote
Old 03-06-2014, 04:16 AM   #30
s2d4
s2d4's Avatar
Originally Posted by shiv@vishnu View Post
Also, I just posted a new Template on the site (http://openflashtablet.com/products/...s-2/index.html). Same as before. But the FRS background pic is back
Thanks!!
IAM works on the I series ROM.
Other than that, just metric units for non-US apart from fbkc and flkc unless kc is meant to be one of those two?
The Following User Says Thank You to s2d4 For This Useful Post:
Shiv@Openflash (03-06-2014)
Old 03-06-2014, 05:26 AM   #31
troek
troek's Avatar
Drives: 2012 Toyota 86
IAM is not working on A series roms. everything else rocks!
Edit: also good work shiv on listening to people about the background image lol, it only lasted a few hours
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
Old 03-06-2014, 06:09 AM   #32
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Ok. We should be able to add support for A series ROMs by Friday. We didn't have access to the is ROM until after we added the channel IDs to the data logging code. So we'll add it to the mix
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
troek (03-06-2014)
Old 03-06-2014, 06:15 AM   #33
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by s2d4 View Post
Thanks!!
FBKC (Feedback Knock Correction) is the same thing as Knock Correction in the OFT logging. We haven't added FLKC (Fine Learning Knock Correction) yet because it's a stored value based upon different load/rpm combinations so we need to work out a good display option for it.
s2d4 (03-06-2014)
Old 03-06-2014, 07:41 AM   #34
brn12345
brn12345's Avatar
If you can add a table view of FLKC on a separate page it would be great. Viewing FLKC in table view has helped me understand where exactly and knock is happening.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 03-06-2014, 08:06 AM   #35
wparsons
wparsons's Avatar
Man you work fast!
flickr
Old 03-06-2014, 10:52 AM   #36
wparsons
wparsons's Avatar
New bug I've found, the graphing view of sensor data isn't working anymore. I see the immediate values changing on the left, but there is no graph drawn. I'm assuming it's related to the channels I've selected, but don't remember which ones are on.
I'll get more useful information tonight when I get home, I realize how useless this is without knowing more details
flickr
Old 03-06-2014, 11:27 AM   #37
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by normancw View Post
I don't think so, but maybe we can use OFT dollars to buy more OFTs!
1 tablet is more convenient.
unlocking software to use 2 vehicle would be great though.
of course, paying more for unlocking these feature if available. just thought
Old 03-06-2014, 12:00 PM   #38
Shiv@Openflash
Drives: 2013 FRS
All the channels in the graphics viewer are de-selected by default. So you only see them update numerical values, not graph realtime. You need to manually select which ones you want to graph by touching them to enable
Old 03-06-2014, 12:02 PM   #39
Shiv@Openflash
Drives: 2013 FRS
It's would be a complicated affair to provide memory allocations for two original files, two compatible sets of maps and two simultaneously running protocols. Not saying that it would be impossible but it would certainly add a lot of work to the reasonably simple concept that we currently employ with respect to OFT/vehicle marrying.
zc06_kisstherain (03-06-2014)
Old 03-06-2014, 02:43 PM   #40
Ondreiko
RWD addicted
Ondreiko's Avatar
Hey Shiv!
So i logged mine today, there are so many channels so i am not sure which ones do i have to choose for viewing.
This is the log:
http://datazap.me/u/ondreiko/1st-ext...0&data=1-2-5-8
and it looks like you set the Adv. Multiplier to 1 by default in order to disable me asking stupid questions lol
But! there are some strange readings of the throttle angle - is it the same bug that lives in accel pedal gauge?
Old 03-06-2014, 02:44 PM   #41
wparsons
wparsons's Avatar
So what you're saying is... the bug is between the seat and the tablet?? D'Oh
flickr
Old 03-06-2014, 02:47 PM   #42
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Ondreiko View Post
Hey Shiv!
This is the log:
Great. Good to hear that Adv Mult is now logging for you. Your throttle readings look fine. I'm not sure what you are referring to.
Also, as of this morning the bug in the Accel Pedal channel has been fixed. So now it reads correctly 0-100%. Just connect OFT to laptop and let it update. No need to update Template again if you already did it.
Cheers
shiv
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 01:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 10:05 AM
OpenFlash Tablet Firmware 1.19 Now Available: Stores up to 5 ROM on the OFT Shiv@Openflash Software Tuning 33 12-20-2013 10:38 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 01:10 AM
