Old 03-05-2014, 07:00 PM   #43
JayDee
Drives: 2013 White BRZ / 2014 White GT86
Originally Posted by Assunta View Post
4. Unless you have an inside deal, I don't recommend buying these wheels from a Subaru dealer in Canada unless you don't mind giving away your money. If you're going for RB it sounds like your pockets are lined with gold anyway so be my guest.
Sorry, I meant my Dealer who deals with all my aftermarket parts, not a Subaru dealership haha
Got the set for about $1800.
JayDee is offline
Old 03-05-2014, 07:10 PM   #44
JayDee
Originally Posted by xDJ DUBx View Post
To get the concave R face, the smallest size you can get them in is 18x10 +22 in 5x114.3 so you'd need at minimum a 15mm adapter that would put you at +7 which would not fit a stock body. If you plan on going RB, just wait until you do to buy the wheels or buy them now and sit them aside for the time being. Either way, start researching wheel sizes and how offset works or else you'll end up with some ill fitting setup that won't look good. And don't take the dealer's word for fitment questions lol
Thanks for the advice! Thats exactly what my parts guy told me, I still don't understand the +7 part and why it won't fit, can't I just have the rim sticking out for the time being? Sorry if this sounded stupid, ya I'm a really new to all the "fitting and camber". Going to take ur advice and do some research.
JayDee is offline
Old 03-05-2014, 07:14 PM   #45
xDJ DUBx
Lurker
xDJ DUBx's Avatar
Drives: '14 Rocket Bunny Monogram FRS
Send a message via AIM to xDJ DUBx Send a message via Yahoo to xDJ DUBx
If you're on stock height, you might be able to but under heavy suspension compression the tires will hit the body of the car which will mangle them and could also cause extensive body damage. If you're lowered already, I promise you that WILL happen. Basically the lower the number the further it sticks out. Why can't you just not run the wheels until you go widebody? lol. I promise you it'll look way worse than stock wheels so run those in the meantime.
xDJ DUBx is offline
The Following User Says Thank You to xDJ DUBx For This Useful Post:
JayDee (03-09-2014)
Old 03-06-2014, 12:15 AM   #46
Assunta
Assunta's Avatar
Drives: 2013 SWP BRZ
The 15mm adaptor is required to change your PCD from 5x100 to 5x114.3
This reduces your offset by 15mm... 22-15 = +7 offset.
Plus, what xDJ DUBx said about mangling your tires and fender
Edit: but seriously, this discussion belongs in a different thread.
Assunta is offline
The Following User Says Thank You to Assunta For This Useful Post:
JayDee (03-09-2014)
Old 03-11-2014, 11:00 PM   #47
einrejosh
einrejosh's Avatar
Drives: 2014 Scion FR-S
Enkei RS055RR Square set-up opinions?
I'm planning on getting RS05RR from work for about 420$ each.
18x9.5 +42 all around.
I was wondering why I can't run this stock, just curious. Sorry if its a dumb question.
And yes, I'll be lowering my car before I put this on. I'll be using FA500.
And I'm wondering what tires to get. Michelin Pilot Super Sport, Federal RS-R, or Dunlop Star Specs. I will be using the car as a DD, mostly commute and some occasional backroad runs.
einrejosh is offline
Old 03-11-2014, 11:58 PM   #48
Mild2Wild
Drives: Firestorm FR-S
Inboard clearance. I'd imagine you will hit struts or springs with that high of an offset. I think they're +43 btw
Mild2Wild is offline
Old 03-12-2014, 01:11 AM   #49
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
With stock springs, you'll rub on the spring perch. With Coilovers, I THINK you'll be okay. You might need a 3mm spacer but I'm not sure. People are running 18x9.5 +40 on Coilovers with no issues for reference.
TylerLieberman is offline
Old 03-12-2014, 03:37 AM   #50
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
I want a set!!! Hook it up!!
When in doubt, throttle out!
FRS Johnny is offline
Old 03-12-2014, 04:49 PM   #51
einrejosh
einrejosh's Avatar
LOL, i work at America's Tire in the SF area. They told me it would be like an 80-100 day wait for the wheels to ship from japan. I was thinking of just ordering and reselling wheels, but I'd get fire haha, I'm only 18 homeboy.
The Following User Says Thank You to einrejosh For This Useful Post:
FRS Johnny (03-12-2014)
Old 03-12-2014, 04:52 PM   #52
einrejosh
einrejosh's Avatar
How do you guy's feel about a Square set up of 18x9.5 all around?
I was talking to the SpeedElement people, and they told me its just user preference.
I also decided not to go staggered because 8.5 was back ordered, and 8.5 had a flat face also.
But yeah, whats your opinion on a squared set up of 18x9.5 5x100 +42
Old 03-12-2014, 04:56 PM   #53
CSG David
CSG David's Avatar
There are 18x9.5 and 18x10.5 in stock right now. Nobody has asked for them on our end...LOL.
CSG David is offline
Old 03-12-2014, 05:05 PM   #54
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
They come in 18x10.5 with a 5x100 bolt pattern?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline
Old 03-12-2014, 05:18 PM   #55
CSG David
CSG David's Avatar
Damn it. I thought they did. Just checked supplies and they don't. I was looking up info for my clients with 350Zs and 370Zs.
I can tell you right now that 18x9.5 +43 is in stock.
Old 03-12-2014, 05:28 PM   #56
Tansey86
Tansey86's Avatar
You got my so hyped for a second.
Tansey86 is offline
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 11:30 AM
Wheel Directory: Enkei RS05RR 18x8.5 +42 dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 206 03-02-2018 06:23 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 04:50 PM
Gauging interest Enkei RS05RR 18x9+40/18x8.5+50/18x8.5+42 THMotorsports.com Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-19-2013 05:33 PM
