Drives: WRB BRZ
Front pipe variations and exhaust volume
I've had a catless front pipe and Q300 catback for a while. This setup gave me a nice sound, but rather quiet.
Last weekend I installed my OFH and an Invidia overpipe. With the full setup I had great volume, and it sounded pretty good. However, I didn't like the catless smell. So last night I put the stock front pipe back on. Now the car is very quiet. I was rather enjoying actually hearing the exhaust note in the cabin with the catless pipe. The OEM front pipe took the level down to what it was before the header and overpipe. But it doesn't stink anymore. So my last resort would be to get an aftermarket catted front pipe. Can anyone comment on how the sound (particularly volume) will be effected? |
#2 |
A catted front pipe will definitely increase volume a bit. Not a ton, but there's definitely an increase. I had my 2.5" catted FP on for about two months with the stock cat back and you could hear the difference for sure.
#3 | |
Drives: WRB BRZ
I guess I need to know how the sound of catless FP compares to a high-flow FP. |
#4 |
Drives: 1997 Eagle Talon TSi AWD
The overpipes and cat/test pipes (front pipes) only change the sound minimally. The actual cat-back piping (design and diameter) and muffler setup affect the sound the most.
Over and front pipes will cause more in-car drone (unless they're resonated like the ARK or similar) rather than change the final exhaust note. A straight front pipe no cat will add a bit of volume. |
#5 |
A catless FP will be more raspy than a catted FP, but how raspy will depend on the whole exhaust (including header). It'll also be a bit louder, but not much.
#6 |
Drives: Attitude
It might seem obvious, but the physical location of the pipe you change will also dictate where the perceived sound occurs. The most distinct volume change outside of the car will occur from the axleback section while the rest of the pipes will alter tonal qualities, especially inside of the car in addition to outside of the car. Changing the OP/FP will alter the sound from outside of the car for sure, but remember that these two pipes are nearest to you and to the cabin as well.
Not even going to discuss headers as that's a whole story in itself. |
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Vmax911 (03-05-2014) |
#7 | |
Drives: WRB BRZ
Both setups I ran had no drone. Maybe this due to the Q300, which is considered quiet for an aftermarket system. From wparsons response, I would expect an aftermarket catted front pipe to increase the volume over the stock front pipe, but would it increase the volume as much as a catless front pipe? |
#8 | |
Drives: WRB BRZ
#9 |
Drives: Attitude
Comparing two pipes (let's make it easy - same manufacturer, same pipe ID, etc.) with and without cat will largely change the tone not the volume though volume may change slightly. Perhaps a better way to say it is that a cat changes the tone more than it changes the volume.
#10 | |
The only thing you get is a non-catted version can cause in-cabin resonance if there's no resonator (external or in line). |
| TRD exhaust + front pipe and overpipe? | FRSBRZGT86FAN | Engine, Exhaust, Transmission | 2 | 11-02-2020 07:48 AM |
| FS - (NoVA) OEM Exhaust Parts (Over Pipe, Front Pipe) | swift996 | Engine, Exhaust, Bolt-Ons | 5 | 05-05-2014 08:03 AM |
| FS: Stock Front Pipe and Exhaust | Firestorm_86 | Engine, Exhaust, Bolt-Ons | 0 | 02-20-2014 11:14 AM |
| Stock exhaust and front pipe. | shultz2 | Engine, Exhaust, Bolt-Ons | 0 | 12-23-2013 10:07 PM |
| FS: OEM Exhaust and Mid and front pipe | Bcarlos | Engine, Exhaust, Bolt-Ons | 3 | 07-24-2013 05:16 PM |
