03-05-2014, 05:04 AM | #29 | |
Drives: Toyota Gt86
if the throttle is less then 92.63 VD doesn't count it as WOT. Should we report it as a bug? |
03-05-2014, 05:18 AM | #30 |
Drives: '14 FRS White
Can't hurt. However, if you go to File -> Options turn off TPS auto trim. You'll be good, but you'll definitely want to make sure you shave all non-WOT info from the log.
03-05-2014, 05:25 AM | #31 | |
Drives: Toyota Gt86
Is it WHP or crank HP? |
03-05-2014, 05:52 AM | #32 |
WHP. click the sae button so you can make corrections to barometer (if known), temperature, and don't forget to edit the weight, tires (if necessary). The more accurate the info, the more accurate the graph. Also, you may want to change the smoothing on it as well.
03-05-2014, 05:57 AM | #33 | |
Drives: Toyota Gt86
03-05-2014, 07:30 AM | #34 |
Virtual dyno has a frontal area parameter to take care of that.
Light travels faster than sound, so people may appear to be bright until you hear them speak... flickr Last edited by wparsons; 03-05-2014 at 10:10 AM. |
The Following User Says Thank You to wparsons For This Useful Post: | bfrank1972 (03-05-2014) |
03-05-2014, 08:13 AM | #35 |
Drives: Toyota Gt86
what do you mean? if road is bumpy/not flat VD cant do much
03-05-2014, 08:25 AM | #36 |
Drives: 2013 FR-S Argento
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post: | Victor Draken (03-05-2014), wparsons (03-05-2014) |
03-05-2014, 08:40 AM | #37 |
Drives: Toyota Gt86
that makes sense.
03-05-2014, 10:10 AM | #38 |
Yep, that's what happened. Edited the post to quote the proper post
03-05-2014, 01:17 PM | #40 |
Here's another dyno of e85 after a few weeks of learning vs the same map shortly after flashing. Ignore the dip at the top, I hit a bump that triggered TC.
03-05-2014, 08:33 PM | #41 | |
Now to go get better logs of full pulls (instead of lifting at 6700rpm) and see how they look!
The Following User Says Thank You to wparsons For This Useful Post: | DriftHappens (03-05-2014) |
03-06-2014, 01:18 AM | #42 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
According to this my WHP is 34whp higher than stock BHP on e85 I'm not sure if it is 100% set correctly. I did select the BRZ right in the options and I verified things like the COD and weight from Subaru's literature.
Similar Threads | ||||
Data Logs! Post them here. | feldy | Software Tuning | 2151 | 07-26-2024 10:47 AM |
Anyone help interpreting data logs? | cuddefred | Engine, Exhaust, Transmission | 8 | 10-11-2013 06:30 PM |
Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
