Old 03-04-2014, 10:21 PM   #15
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
No problem, the problem never come back for me after months... Don't worry.
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 03-04-2014, 10:50 PM   #16
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
What cracking noise are you referring too? I never heard of this before
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 03-04-2014, 10:51 PM   #17
Young_makaveli
Drives: 2013 frs
Originally Posted by AznKirby View Post
Toi, tu dois etre Quebecois
Nice to see another member from montreal
Old 03-05-2014, 12:00 AM   #18
Mikepage
Mikepage's Avatar
From Québec!
o= FR-S =o
Old 03-05-2014, 01:01 AM   #19
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Yup! From the Nextmod MTL team. So if you guys need any parts, holla!
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 03-15-2014, 02:47 PM   #20
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
So wait, are you guys saying that you need to actually crack the spot welds? As in separate the panels so they aren't welded together anymore? Because that's what it reads like.
akiranakayama is offline   Reply With Quote
The Following User Says Thank You to akiranakayama For This Useful Post:
Mikepage (03-15-2014)
Old 03-15-2014, 02:50 PM   #21
Mikepage
Mikepage's Avatar
Noooo you just need to crack it but a little bit and take care to do not broke it. Slowly, you will not broke anything, don't worry and thrust me.
o= FR-S =o
Old 03-15-2014, 03:40 PM   #22
Young_makaveli
Drives: 2013 frs
Just pry it enough so you can spray some lube inside
I believe that's what he meant
Old 03-15-2014, 04:07 PM   #23
kodyo
Drives: Scion FR-S
You'll know why he says "crack" once you actually do it. The welds will literally make a loud "pop" noise. I used a small screw driver and about the weight of my hand to pry between the panels at the welds I could see. Be sure not to pry hard enough to yield any material or cause any permanent deformation. You can do it all from inside the trunk without removing any panels.
Read the other thread, the one you already posted in, completely. I suspect you are just reading the first page or something, because it's pretty well spelled out on what to do.
kodyo is offline   Reply With Quote
The Following User Says Thank You to kodyo For This Useful Post:
Old 03-15-2014, 05:24 PM   #24
Mikepage
Mikepage's Avatar
I will add a special note concerning cracking in the first post
o= FR-S =o
Old 03-15-2014, 05:36 PM   #25
Mikepage
Mikepage's Avatar
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise.
Thanks for your comment, I have modified the first post to be really clear.
Does it better now? See the important note I have added.
o= FR-S =o
Old 03-16-2014, 01:16 AM   #26
akiranakayama
OK, thanks for the point in the right direction. I appreciate it!
Old 03-16-2014, 11:30 AM   #27
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
For safe measure I cracked every spot weld in the rear area and lubed the hell out of it. No more pops and squeaks! I sprayed lube in the latch receiver on the rear seat to kill those noises. My car has never been this quiet
supramkivtt2jz is offline   Reply With Quote
The Following User Says Thank You to supramkivtt2jz For This Useful Post:
Mikepage (03-16-2014)
Old 03-16-2014, 01:10 PM   #28
kodyo
Drives: Scion FR-S
Originally Posted by Monogram View Post
What about using a caulk gun and silicone for a permanent fix? Silicone itself is a good dampener.
No reason to. A light oil such as WD40 and cracking the welds gets rid of the sound permanently. No reason to use sealants and potentially make a huge mess.
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
Subaru TSB 12-140-12 for Rear Deck Popping sparks Issues | Warranty | Recalls / TSB 31 07-17-2013 11:11 AM
GTS rear left popping/clicking sound and fix. sigmaoctantis AUSTRALIA 11 05-19-2013 06:58 AM
Ticking/Clicking Noise front - passenger side PoRco Scion FR-S / Toyota 86 GT86 General Forum 9 05-06-2013 05:55 PM
Rear deck popping/clicking DriftEightSix AUSTRALIA 6 02-01-2013 01:59 AM
