go_a_way1
Old 03-03-2014, 01:41 AM   #1499
nab335
nab335's Avatar
Drives: e92 335i, FRS, Lexus ls400
Originally Posted by lp87 View Post
somebody should do this:
http://www.ft86club.com/forums/showthread.php?t=59200
Think it would look good on a stanced car
hell no haha. well, to each his own but I personally don't understand that look. looks naked or something
IG: nabb335
nab335 is offline   Reply With Quote
Old 03-03-2014, 05:48 AM   #1500
blags
Drives: Toyota 86
blags is offline   Reply With Quote
The Following 12 Users Say Thank You to blags For This Useful Post:
boucher (03-03-2014), HATED1 (03-03-2014), humanshield (03-06-2014), Jeeper_x (03-03-2014), Michael (03-17-2014), mrxchris (02-21-2015), SkAsphalt (03-03-2014), SnapOv3st3r (03-06-2014), westbase (03-03-2014), whitefrs (03-03-2014), WhiteLightning (03-03-2014), zenki_levin (03-05-2014)
Old 03-03-2014, 06:23 PM   #1501
Crazy Drew
Drives: Smells like tires when I drive
For those of y'all with adjustable rear arms, other than price is there any reason for going with an adjustable lower rather than an adjustable upper rear control arm? Looking at a set of wheels that are on the verge of needing a pull in the rear and I think I can work it if I get an adjustable rear upper arm so I don't lose distance with camber.
I just hate the fact that I'll push the rear hubs out with an adjustable lower arm thus losing fender clearance and needing a bigger pull.
Crazy Drew is offline   Reply With Quote
Old 03-04-2014, 02:54 PM   #1502
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
@crazy_drew for fitment reasons, upper arms are the way to go IMO. Lower arms dont actually push the hub out like they would on mcpherson strut type suspension , extending lower arms will give you fender clearance, but requires a bit to get any good clearance. For instance, the upper arm will give you X amount of clearance at -5ish degrees of camber , while to get that same X amount of clearance with lower arms you will need say -10ish degrees of camber. (of course the camber numbers may be off but you get the point.) Also with lower arms, if you plan on dialing in any more than -5 degrees, you most likely will need adjustable toe links to correct the toe to zero.
I have both uppers and lowers, along with toelinks- if you have any more trouble shoot me a PM
SLICVIC is offline   Reply With Quote
The Following 2 Users Say Thank You to SLICVIC For This Useful Post:
Crazy Drew (03-04-2014), WolfsFang (03-04-2014)
Old 03-04-2014, 05:17 PM   #1503
Hachiroku14
Drives: 2014 BRZ World Rally Blue
Hachiroku14 is offline   Reply With Quote
Old 03-04-2014, 05:22 PM   #1504
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
learn something new everyday and im not even in class yet.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 03-04-2014, 05:24 PM   #1505
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by whitefrs View Post
Currently i got
18x9 et38 with 225/40
18x10 et38 with 245/35
I'm thinking about adding some spacers and camber out the front a lil bit and add some spacers to the back as well and add LCA to camber as well
what do you guys recommend??
Meanwhile no one cares about my question
Old 03-04-2014, 08:37 PM   #1506
nab335
nab335's Avatar
lol, i think what you are planning is perfect. LCAS with some spacers will give your wheels a nice fit
IG: nabb335
Old 03-04-2014, 08:39 PM   #1507
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
thanks FINALLY SOMEONE lmao
what spacers tho. I'm thinking 5 all around but idk lol
Old 03-04-2014, 08:41 PM   #1508
nab335
nab335's Avatar
with that offset i think you can run 10-15mm with 5 degrees of camber. You have 45 profile tires though so i'm not too sure. 10mm would probably be safe without a fender roll
IG: nabb335
Old 03-04-2014, 08:42 PM   #1509
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Im trying to fit 265s as well lol
Fenders are rolled
I love boost!!!!!!
Old 03-04-2014, 08:44 PM   #1510
nab335
nab335's Avatar
Fenders are rolled
I love boost!!!!!!
Lol I have no idea then man. I'm running 225s on a 10.5 but I'm not boosted or anything so I didn't have to worry about sacrifices
IG: nabb335
Old 03-04-2014, 08:55 PM   #1511
Crazy Drew
Thanks Vic. I figured it was something like that. The "pushing the hub" out may not have been entirely correct however you confirmed my theory with the difference in required adjustment for the same camber angle. I daily my car 60 miles each way so I'm not looking for more than a couple degrees to get things to clear.
The wheels I wanted anyways sold earlier today so no Leon Hardiritts for me... womp womp womp. Rotiform Nue's on the way.
Old 03-05-2014, 04:07 AM   #1512
nab335
nab335's Avatar
I miss the accuair style fitment
IG: nabb335
The Following 3 Users Say Thank You to nab335 For This Useful Post:
boucher (03-05-2014), mr. slim (03-05-2014), zenki_levin (03-05-2014)
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
