Old 03-04-2014, 09:52 AM   #57
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Here's a good ole trick I've used in the past - get a hammer and screwdriver. Hammer the screwdriver through the side of the oil filter and then rotate it, acting as if the screwdriver is a lever.
PoorMansRacing is offline   Reply With Quote
Old 03-04-2014, 11:48 AM   #58
dpesce
Young Blood
dpesce's Avatar
Drives: 2013 Red BRZ 2.0 Premium
Originally Posted by edsbreezy View Post
Those are the ones I used to use in the shop. $4 or something from Harbor Freight. Works like a champ on these filters. Fit in better than the band/strap ones IMHO.
I tend to believe that Filters get over-tightened in the shop for a few basic reasons:
1) most oil change personnel are between the ages of 16-20, I was. Kids this old have probably not learned what a PITA over-tightening can be when your cramped under your car with no lift.
2) An overtightened filter is much better than a leaky one and a customer comeback -- could equal lost job. Now I know a properly tightened filter will not leak but I would presume fear of leaking is a reason enough.
3) THIS IS AN AWFUL ONE but a friend at Jiffy Lube said those fools used to tighten filters with wrenches/straps etc because their hands would get tired. No way to gauge tightness, possibility of ruining seal, filter housing etc... bad idea!
dpesce is offline   Reply With Quote
Old 03-04-2014, 08:31 PM   #59
cycleboy
Drives: 2013 Scion FR-S - Argento
Originally Posted by supramkivtt2jz View Post
just a guess, but im assuming you didnt punch a hole in it and let it drain first.
in these cars, i doubt itll be messy at all.
No, I did punch it through and drain it, but the filter was sitting above other parts, hence messiness!
cycleboy is offline   Reply With Quote
Old 03-05-2014, 11:38 AM   #60
racecat
racecat's Avatar
Drives: Hot Lava FR-S MT
I drained the oil pan first and didn't have any mess at all.
racecat is offline   Reply With Quote
Old 03-09-2014, 11:00 AM   #61
cycleboy
Yes, that's my normal process, drain the pan first.
But on my 2002 (and a lot of other cars I've dealt with) the filter was at an angle such that not all of the oil will ever drain out of it - unlike the 86 where it conveniently is in the perfect spot and oriented so it drains.
Old 03-09-2014, 11:38 AM   #62
racecat
racecat's Avatar
Oh yes, that makes sense. Still unfortunate!
Old 03-09-2014, 04:53 PM   #63
tzhu07
Originally Posted by retoocs View Post
I learned by lesson with my Legacy GT, let the dealer do the first oil change. The oil filter and the drain plugs were probably installed by gorillas.
I used one of these now to get filters loose.
I ended up buying this tool. Haven't actually tried it yet though.
tzhu07 is offline   Reply With Quote
Old 03-11-2014, 01:33 AM   #64
PMok
Codename: Stitch
PMok's Avatar
I had to do this for my first at-home oil change - but I let the power tools do the work for me. Pulled out the cordless drill, drilled a hole into side of the filter, and inserted screwdriver. Easy.
Old 03-11-2014, 09:10 AM   #65
troek
troek's Avatar
Drives: 2012 Toyota 86
all the "hand exercises" ive been doing since my teenage years are paying off as mine came right off with my hands.
troek is offline   Reply With Quote
The Following 2 Users Say Thank You to troek For This Useful Post:
racecat (03-11-2014), Squishy86 (03-11-2014)
Old 03-11-2014, 11:38 AM   #66
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I use one of these:
https://www.channellock.com/209-Oil-...PVC-Plier.aspx
I think I bought it at the Home Depot for less. I grab the filter from the top because I use a FilterMag that restricts access.
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 10:04 AM
PLS REMOVE Nezz Australia Classifieds 0 01-31-2013 05:59 AM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
