| DIY (Do-It-Yourself) Guides For all DIYs. |
uosɹǝdʎɐl ʇɹǝdxǝ
Drives: Asphalt AVO FR-S w/a Slushbox! :P
DIY – OEM Heated Seats
(Disclaimer: Tampering with any part of car may void your manufacturer’s warranty. If you decide to perform the conversion you could damage your car or be hurt; you do so at your own risk, I am not responsible for damage or any harm you may suffer or any special or consequential damages)
This is my first attempt at a DYI so your grace is appreciated. I will update this with suggestions and corrections as time allows. I also won’t cover every step in detail as there are other posts which cover the removal of the center console and the seats themselves for example. Here are some bread crumbs for the noobies... Console Removal Seat Removal I also assume everybody knows how to solder and use heat shrink tubing (no 3rd degree burns kids!) This is expensive. The minimum cost of the upgrade being at least $1000 assuming you trying to retrofit BRZ seat cushions (the heaters are in the cushions themselves from what I understand) into FRS seats. A used set of seats could cost anything depending on their condition. New I believe their $2800 *EACH* as complete assemblies. Used BRZ limited seats do come up for sale on this forum and can be found at salvage yards. If you’re getting these used make every effort to get the plugs for the seats and their switches from the seller as these will be difficult to find on their own and prohibitively expensive to purchase as new parts as they come integrated into harness assemblies. I was fortunate enough not only to find a set of BRZ limited seats but a seller who was willing to sell me his center console and allow me to snip off the four plugs from the cabling harness I needed for the two switches and the two seat heaters. Because this will not always be possible I will do my best to give enough information to accomplish this without those harness connections. 1) First study the wiring diagram. ![]() The switches are at the “middle” of everything. Power flows into the switches and out to the seats. Both switches have grounds and so do the seat heaters. I decided I would ground the system to some bolts towards in the middle of the passenger compartment, near the yaw sensor, towards the “rear” of the center console. I used only RED WHITE and BLACK wires to make my harness. Using a piece of rope I measured out the distances and then started cutting. You will need to make a harness with four segments: A: From the switches to the fuse box B: From the Driver Switch to the Drivers Heating Elements C: From the Passenger Switch to the Passenger Heating Element G: The Ground return from the two switches and the two heaters to chassis I routed the segments for the drivers seat and the fuse box behind the parking brake handle and cables ![]() 2) Make and install the harness I used the following measurements to make the harness: I went out and got 16AWG wire (which was MUCH larger) then the 18-20AWG wire used by the factory. First I cut the wire to length… ![]() …and then fed it thru heat shrink tubing…. ![]() …to make the each harness segment. ![]() Solder the seat plugs to the (A) Drivers and (B) passenger side harness segments… ![]() ...and then solder the segments together, shrink the tubing and WA-LA!.. ![]() …You have a wiring harness! ![]() ![]() ![]() 3) Marvel at the product of your handy work! ![]() A note about the power connection. Originally I wanted to tap directly into an existing harness wire. My thinking was that because the fuse was installed, so were some of the electrical connections branching out from the ECM but no Dice! So, I had to resort to fuse taps.![]() So what if you don’t have the harness connections? I took pictures of the plugs in their jacks so you would know which wire corresponds to which connection (see my modified wiring diagram above). ![]() ![]() With some extra work and a trip or two to NAPA to find aftermarket four conductor male/female harness parts you can do this without cutting the connections from an existing harness. Enjoy... :happy0180:
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn Last edited by @Art_Mighty; 08-25-2013 at 03:14 PM. Reason: Detail added |
| The Following 4 Users Say Thank You to @Art_Mighty For This Useful Post: |
#2 |
uosɹǝdʎɐl ʇɹǝdxǝ
Reserved
Reserved
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn |
#3 |
Drives: 2013 Toyota 86/Scion FRS
Dude awesome DIY! so are both the back and bottom cushions heated or only the bottom portion?
| The Following User Says Thank You to iketiak For This Useful Post: | @Art_Mighty (08-27-2013) |
#4 |
uosɹǝdʎɐl ʇɹǝdxǝ
On high both the back and bottom, on low it's only one of them but its been too warm to test. I'll get back to you to confirm when it gets cooler
#5 | |
Drives:
Too work mate and thansks for any input! Last edited by ganjara; 03-03-2014 at 04:29 AM. |
#6 | |
uosɹǝdʎɐl ʇɹǝdxǝ
If your trying to do this without the harness cable ends it's possible. I tried to leave what I would want as bread crumbs if I had to attempt this without those ends. It would probably require some dremmeling of the switches to expose the wires enough to solder them and something similar for the connections under the seat. I REALLY wanted OEM heated seats so even if the harness cable ends weren't part of the deal I would have made them work.
#8 |
Drives:
Exactly... if it were plug and play I'd do it although in Sydney there's like 3 weeks of the year I'd even use them lol. Think I'll just use the seats as seats and the heaters can just go to waste. Bit of a shame though because I'd kinda like that extra plate in my centre console to have switches on it rather than empty space
#9 | |
Drives: Raven Fr-s
#10 |
Drives: White 2013 Scion FR-S
#11 |
Drives: Raven Fr-s
http://www.ft86club.com/forums/showthread.php?t=45423
Great vender too. I keep wanting to buy one just going back and fourth on which one I want.
#12 |
Drives: 2023 WRB BRZ (MT)
@@Art_Mighty what do you recommend if i can't get the connectors? or would you know the part numbers for them? I'm looking into this but since won't b able to source easily i need to improvise
#13 | |
uosɹǝdʎɐl ʇɹǝdxǝ
#14 | |
Drives: Vortech Supercharged FR-S
Do you have any suggestion if I only need to swap seat to base FRS but do not need the heating funciton? Iv heard that the BRZ limited seats are not direct fit. There will be sensor issue?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
| heated seats | debs0712 | Cosmetic Modification (Interior/Exterior/Lighting) | 47 | 04-08-2018 09:06 PM |
| brz limited heated seats | abutterman | Issues | Warranty | Recalls / TSB | 15 | 04-15-2013 11:18 AM |
| heated seats installation | abutterman | Electronics | Audio | NAV | Infotainment | 10 | 02-15-2013 04:19 PM |
| Heated seats: Switches backlit? | Augora | Issues | Warranty | Recalls / TSB | 3 | 01-15-2013 02:51 AM |
| Retrofit heated seats to Premium? | blalor | BRZ First-Gen (2012+) — General Topics | 4 | 05-31-2012 07:50 AM |
