Old 03-03-2014, 11:07 AM   #911
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by Deadspool View Post
now squidley, lets not be shy and show a little dsm ingenuity as well
http://forums.evolutionm.net/evo-how...er-5-02-a.html
http://www.dsmtuners.com/forums/arti...ak-tester.html
My way is easier, quicker and cheaper ;P
Also I've been making these "kits" since before Evos made it to the US. Circa 1999 actually. Many revisions later, this is the best IMO.
Ironsquid is offline   Reply With Quote
Old 03-03-2014, 11:08 AM   #912
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by Ironsquid View Post
Boost leak test kit for under $10.
Go to the parts store and buy an appropriately sized oil filter wrench (you will be taking off your air filter/pipe and clamping this ONTO the turbo inlet). It looks like this:
Then buy a valve stem:
Pull the valve stem through the square 1/2 inch drive hole on the oil filter wrench so that the valve sticks out from where you will be clamping it. Make sure you pull it all the way through so it seals.
Then with an accurate pressure gauge, fill up your intake system with no more than 10 psi, this is enough to expose a leak.
Gurgling sounds are normal, hissing is not. Fix whatever hisses and re-install your intake.
This works as I have been doing it for years
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 03-03-2014, 11:18 AM   #913
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Never seen your method before. The unit ive made is almost old enough to drink, in canada.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-03-2014, 11:21 AM   #914
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Who lives in Canada now, eh?
Old 03-03-2014, 11:25 AM   #915
Deadspool
Much title. Wow.
Deadspool's Avatar
Bunch of idiots that wont move to warmer weather. Self included.
Old 03-03-2014, 11:29 AM   #916
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
We can trade I'll gladly give up 115F in the summer time.
Old 03-03-2014, 11:34 AM   #917
Deadspool
Much title. Wow.
Deadspool's Avatar
My woman said the same thing, she is from Austrailia. When she came to visit last year she got sick of our winter in less than 2 months. she stayed from september to january lol.
It is easier to get warmer than it is to get cooler, but there are some serious pro's and cons to both our weather.
Old 03-05-2014, 02:36 AM   #918
Sterz
Great White
Drives: 2013 Whiteout FRS
Anyone have any ideas as to why my car could only be boosting to 3.5 psi on the basemap? Boost pressure test was done...no leaks. Vacuum test was done...no leaks. Standard 7.5 psi spring in the wastegate. I just can't figure it out. Also came home tonight, after going in the house for a while I remembered I left my phone in the car, came out and there was a good puddle of oil on the ground. Seems to be coming from the oil cooler lines. Could have been leaking like that the whole night I was driving I checked the oil yesterday and it was at full level and now its not even registering on the dip-stick
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
Old 03-05-2014, 10:27 AM   #919
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Stock MAP sensor and tune using speed density?
Some kind of weird limiter or limp mode?
Old 03-05-2014, 10:34 AM   #920
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Before driving it
Check your oil lines and all.
Your ECU might be on limp mode
I love boost!!!!!!
Old 03-05-2014, 10:48 AM   #921
Deadspool
Much title. Wow.
Deadspool's Avatar
One step at a time. Find the oil leak, thats more deadly than low boost.
I also thought I had the 7.5 psi spring in my WG when I first installed the kit, but it was closer to 4psi. Do you have a method of boost control? if you try turning the fun knob up a little, and the gauge reads the same 3.5, you can for sure rule out the spring.
open dump or recirc? If you can hear the WG opening at 3.5psi, you can also for sure point fingers at the wastegate spring.
The Following User Says Thank You to Deadspool For This Useful Post:
Ironsquid (03-11-2014)
Old 03-05-2014, 12:18 PM   #922
Sterz
Great White
Wastegate is recirculating to its hard to pin point when it opens. Dropping the car off at Forman Performance today to see if we can figure it out and also get these lines checked out again.
Old 03-05-2014, 12:20 PM   #923
Sterz
Great White
On the basemap still. Wouldnt a limp mode not allow me to go past a certain RPM or 40 MPH or something like that?
Old 03-05-2014, 12:21 PM   #924
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Are the hoses under the intake manifold clamped?
FullBlown is offline   Reply With Quote
The Following User Says Thank You to FullBlown For This Useful Post:
jamesm (03-06-2014)
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
