Old 02-27-2014, 11:11 PM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
REVIEW | Pivot Dual Gauge DXW-W/DXW-R
You can find more info about the gauge here:
http://pivotjp.com/product/dual-gauge/lineup-e.html
http://pivotjp.com/product/dual-gauge/dxw-e.html
http://pivotjp.com/product/dual-gauge/img/DXW-e.pdf
The difference between the two model numbers is simply the illumination color. W = white, R = red.
I've always wanted a water temp gauge for this car ever since I decided to take it to the track, however it was hard to find something that modified the car minimally. While I liked the P3 gauge in terms of overall functionality, I wasn't particularly fond of the "AEM wideband" design of it.
This gauge had all the things I wanted: water temp monitoring, oil temp monitoring, and some A/C vent functionality. Additionally, it provides a readout of intake temperature as well. All readings come from the OBD-II diagnostics port.
I ended up ordering it from Japan Parts, who added it to their site:
http://www.japanparts.com/db/partsli...EY=402-003-001
What's in the box:
I am not going to bore you with details, except to note that for a Japanese market only product, it comes with a surprisingly detailed English instruction that made installation super easy. In fact, it was so detailed it even marked how the tabs are oriented on the vent (that you have to remove), and is about as plug and play as you can get.
(my apologies for the blurry pictures, my tripod is missing)
I will get some impressions of the gauge at a later time, and I also hope to datalog some temperatures. One nice feature is that the digital readouts (oil temp and air temp) has a peak hold function, where you can play back the highest reading recorded since the gauge was last reset. A handy way of making sure your oil temperatures are in check.
While it is possible to get a cheaper gauge setup, for ~$250 + shipping this is about as good as a "factory" gauge can get. The hardest part was making an incision in the vent tube for the wire to pass through, but even that took less than 3 minutes.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Fly Guy (05-17-2014), swarb (12-19-2014)
Old 02-27-2014, 11:11 PM   #2
mav1178
mav1178's Avatar
Seems like side vent has a problem with the gauge reflecting off the driver's side window when dark outside. Most likely this is more prominent if your windows are tinted. Normally this isn't a problem, but the reflection sits directly where the side view mirror is, causing an annoyance/distraction...
The Pivot gauge allows you to dim the backlight, so the problem can be mitigated at night.
-alex
Old 02-27-2014, 11:13 PM   #3
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Nice, I have a defi oil pressure in that spot. Looks Oem!
FRSfan111 is offline   Reply With Quote
Old 03-03-2014, 08:10 AM   #4
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
-alex
Could you post a picture showing that ? From fitment picture I've seen on the web, I don't get how the angle of that gauge could cause reflection :O Thanks !
Sent from my SGH-I337M using Tapatalk
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 03-04-2014, 01:49 AM   #5
mav1178
mav1178's Avatar
The camera was placed in the approximate position of where my head would be while driving. I'm 5'9".
As you can see, there's a clear reflection of the gauge in the window. Best I can tell, it's a combination of the window glare + tint.
Top is on the "Low" setting, bottom is on "high" setting on the Pivot gauge.
-alex
Simon99 (03-04-2014)
Old 03-04-2014, 02:24 AM   #6
racecat
racecat's Avatar
Drives: Hot Lava FR-S MT
Thanks for sharing, this looks excellent. Just the kind of info I'd want in an additional gauge.
racecat is offline   Reply With Quote
Old 03-04-2014, 03:53 PM   #7
Simon99
Simon99's Avatar
-alex
Thank you very much for taking time to take pictures. I was set on that gauge, but after seeing that I might have to go back with P3 ! Hopefully you'll find a way to resolve that issue !
The Following 2 Users Say Thank You to Simon99 For This Useful Post:
Guillaume (08-28-2014), SirBrass (03-04-2014)
Old 03-04-2014, 04:22 PM   #8
mav1178
mav1178's Avatar
P3 gauge will have the same reflection since it's mounted in the exact same location.
As for how much light is reflected, this will depend on your tint (if any).
-alex
Old 03-04-2014, 05:21 PM   #9
Simon99
Simon99's Avatar
-alex
I though it was because of the angle of the Pivot Gauge ... And P3 is a much smaller gauge so I guess less lighting
Old 03-04-2014, 05:31 PM   #10
mav1178
mav1178's Avatar
Nah, the gauges all sit in the vent the same way, plus the window angle won't change.
P3 is a smaller gauge, yes, but it's still a digital readout. Plus they have a wideband sensor so it may actually have more lights to reflect.
-alex
Old 06-13-2014, 06:55 AM   #11
86Toyobaru
Drives: 86 & GRB
I spent 30 min to install it today. Its easy to DIY. The only thing I dont like is that you need to cut a small hole in the air vent. Other than that is a cool high quality meter. Btw, its not a cheap meter which cost me 230USD include shipping.
86Toyobaru is offline   Reply With Quote
Old 12-19-2014, 01:32 AM   #12
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@mav1178 what's the OD of this gauge? Will it fit into a 60mm gauge pod?
Fizz is offline   Reply With Quote
Old 12-19-2014, 01:56 AM   #13
Guillaume
Guillaume's Avatar
Drives: Exige S 240
A video I made of the start up sequence.
[ame="https://www.youtube.com/watch?v=52flLT0KLcA"]Pivot Dual Gauge DXW start-up - YouTube[/ame]
Almost 2 years later, I am completely satisfied with this gauge! OEM look, no fiddling around with wireless dongles and apps; as many other things on the twins, it should come this way from the factory!
Guillaume is offline   Reply With Quote
Old 12-19-2014, 02:08 AM   #14
mav1178
mav1178's Avatar
http://pivotjp.com/product/dual-gauge/specs-e.html
60mm.
Fizz (12-19-2014)
FS [BNE] - Pivot DXW-R air vent gauge, Cusco catch can and Team Voodoo gear knob Nardi330 Australia Classifieds 3 04-22-2016 09:24 AM
FS: Dual Gauge Pod antlers Interior Parts (Incl. Lighting) 10 09-03-2014 01:02 AM
Pivot dual gauge ANREX Cosmetic Modification (Interior/Exterior/Lighting) 39 03-01-2014 06:19 PM
ATI Gauge pod review FRSfan111 Cosmetic Modification (Interior/Exterior/Lighting) 4 10-24-2013 06:33 PM
Pivot 3-Drive-BLP Install + Review Argento_FR-S Engine, Exhaust, Transmission 14 09-05-2013 10:41 PM
