Old 02-28-2014, 10:10 PM   #15
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Uh.
ITS VVT
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 03-01-2014, 06:40 AM   #16
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Originally Posted by Dezoris View Post
This motor and countless tunes are quiet during the overlap phase.
The overlap at cold start on the factory tune is definitely not quiet.
Maybe you could post a datalog from your car (which doesn't make this noise, correct?) showing your vvt angles and we can compare with one that does.
- AdrianG
AdrianG is offline   Reply With Quote
Old 03-01-2014, 07:59 AM   #17
s2d4
s2d4's Avatar
I have heard this is multiple tunes, including the Perrin, Vish, and Visconti.
Your issue is placing visconti in the same light as the other 2 thinking there must be something wrong.
I am nearly 100% certain visconti did not play with the cam phasing until shiv posted it up so what you heard with visconti is not the same with the other two.
Old 03-01-2014, 09:19 AM   #18
Dezoris
Dezoris's Avatar
My car has valvetrain noise during overlap on perrin tune. Even more pronounced than Shivs.
This has nothing to do with cold starts. Its about the sound in the videos at specified times at normal operating temps.
Old 03-01-2014, 08:17 PM   #19
wparsons
wparsons's Avatar
What exactly are you claiming is "valvetrain noise"? Are you suggesting the timing chain is making noise, or the valves themselves are making noises? Just because a noise is appearing from a different cam angle doesn't mean it's a noise being made in the valvetrain. Adding overlap can increase intake noise quite a bit, maybe that's what you're hearing?
I've listened to the sound clips a few times and don't hear anything remotely alarming, so either you're being paranoid, or the clips really don't represent the noise well at all.
flickr
Old 03-02-2014, 04:59 PM   #20
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Runinng Shiv's tunes I can hear a change in the engine noise right around 3800 rpm or so. With e85, the noise is even louder. Comparing the exhaust valve advance on the logs with what I hear, they certainly lineup. The sound has all of the characteristic rasp of an exhaust that has imbalanced pulses.
Luckrider is offline   Reply With Quote
Old 03-02-2014, 05:37 PM   #21
mike the snake
Could it have something to do with the direct injection? My tuner mentioned something about the DI making some serious noise when figuring out how to tune my car.
Old 03-02-2014, 06:40 PM   #22
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
interesting. Always wondered what that noise was.
86-tundra is offline   Reply With Quote
Old 03-02-2014, 07:28 PM   #23
wparsons
wparsons's Avatar
I went out for a drive tonight with the windows down to listen for any new noises after flashing with an OFT. There's definitely a noise in the ~3200-4200rpm range, but it definitely doesn't sound mechanical in the valvetrain to me at all. It definitely sounds like rasp, and is more audible at part throttle than at WOT.
flickr
Old 03-02-2014, 08:41 PM   #24
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
It's like intake rasp in terms of what it sounds like. It's not noticeable at low speeds, but it is at freeway speeds. That's why I think it's an intake noise.
Either way, if it's normal, then that's cool.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 03-02-2014, 08:56 PM   #25
Tromatic
OP needs to a bit more direct in accusing Shiv of being a BS artist.
The Following User Says Thank You to Tromatic For This Useful Post:
86-tundra (03-02-2014)
Old 03-02-2014, 09:07 PM   #26
JerryMichaels7
Drives: Whiteout FRS
I know what you are talking about.. In both my tunes from fa20club and now e85 from Bill. Its like were the torque dip is in that range of the rpm's, on mine it sounds like my header or OP is rattling to shit. But i checked everything and found nothing, flashed to stock and noise is gone.
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 03-02-2014, 09:14 PM   #27
DJCarbine
Thupercharged
DJCarbine's Avatar
Sounds like an exhaust leak almost around 3500-4000RPM right? Like a metallic rattle..... Stock tune doesn't do it, its gotta be the exhaust note due to aggressive cam phasing. Could be why there is a torque dip in the first place, people would complain of the engine note and think something is wrong.
Just my theory of course
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 03-02-2014, 09:25 PM   #28
JerryMichaels7
basicly what I think it is also
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 06:21 PM
First tank OFT E85 tuning. Noise? Tromatic Software Tuning 2 02-20-2014 05:43 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 01:47 AM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 10:06 PM
Knock/valve slap/crick noise under accel yomny Issues | Warranty | Recalls / TSB 47 01-07-2013 08:53 PM
