Old 03-02-2014, 11:02 AM   #15
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Originally Posted by Thrustin View Post
I didn't ask if I needed Hoosiers in order to participate in motorsport activities. Thanks for playing though.
If the tires are old you may want to buy yourself some "traction v" or other traction compounds that basically put the oils/chemicals back into the tires that naturally leave heat cycling or sitting. I'm worried they be so hard it will be worse than a normal tire.
Element Tuning is offline   Reply With Quote
Old 03-02-2014, 12:28 PM   #16
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
I'll have to pick some of that stuff up. Thanks for the tip, I'd never heard of that stuff.
Thrustin is offline   Reply With Quote
Old 03-02-2014, 12:31 PM   #17
jonbonazza
They are heavy, so ultimately they will just slow you down. If you are asking if it is possible to run them, however, then the answer is yes.
jonbonazza is offline   Reply With Quote
Old 03-02-2014, 01:06 PM   #18
Element Tuning
They won't slow anything down unless he is way off on size. So while a 285/645-18 is probably slower than a 245/40-17 due to the gearing change with oem power I don't he's going that big.
Old 03-02-2014, 02:43 PM   #19
Thrustin
lol
The Following User Says Thank You to Thrustin For This Useful Post:
xwd (03-02-2014)
Old 03-02-2014, 02:50 PM   #20
mtsui
Drives: 135i
stock suspension is too soft for this much of grip, you will have alot of body roll, and you cant rotate the tail as good as street tires. for autocross, there is alot of tight turn and its better off to power over some of the turn.
but the simple answer is yes, but you just can't learn more and run a better time, thats all.
mtsui is offline   Reply With Quote
Old 03-02-2014, 03:23 PM   #21
xwd
Too bad there is no way to "downvote" posts on this forum. Just about every other post is just plain wrong.
The Following 3 Users Say Thank You to xwd For This Useful Post:
Element Tuning (03-03-2014), neurokinetik (03-03-2014), Sccabrz192 (03-02-2014)
Old 03-02-2014, 04:38 PM   #22
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by Sccabrz192 View Post
Those are getting up there in years, they've been discontinued for a while, but stored appropriately they may not be too bad... if they weren't stored well they'll just be large hockey pucks. Either way, no harm running on them.
+1
Give 'em the fingernail test: if you press firmly with your fingernails and the indentations (assuming there are any) are slow to disappear, then they're probably good to go. Hard to imagine that they will be, though, unless they've been in sealed plastic bags the whole time they've been stored. Do what you can to get them hot before you run.
If they're hard, it'll still be fun, as well as educational. Just for grins, I took a 435 RWHP M3 out to an Evo School on rock-hard 345 A6s and had a terrific time sliding around. It's certainly much more demanding car-control practice than when you're properly hooked-up at the rear.
dradernh is offline   Reply With Quote
Old 03-02-2014, 04:43 PM   #23
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Best you can do is rate the overall thread as a 1 star... As has been done. Sorry, OP, not your fault
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 03-02-2014, 10:45 PM   #24
Thrustin
Originally Posted by dradernh View Post
+1
I pressed my thumb nail into the tires. It took about 45 seconds or so for the indentation to go away. I'm not familiar with r-comps, but they do feel soft.
Old 03-03-2014, 12:20 PM   #25
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
they're tires, there will be no issues
grip is grip, and your old and cheap hoosiers will probably perform okay, so you're not gonna be setting any blazingly fast times.
the question is, what do YOU want to get out of the tires?
Old 03-03-2014, 12:53 PM   #26
Thrustin
I was hoping to get some nice highway pulls on them.
Seriously, I just wanted to make sure I wasn't going to flip the car, lol. I don't have any experience with Hoosiers, and wanted to make sure everything would be cool. I'm not even sure that I will be running them at all this year, as I'll be using a set ZIIs. For $150, I thought they were worth picking up and maybe slapping them on for a test and tune or an out of town event.
Old 03-03-2014, 01:00 PM   #27
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
they're an autocross tire, so i wouldn't use them for lapping (unless you take it easy, lol)
consider them as testers for what it feels like to drive a car on slicks
not that you'll find competition if you choose to go that route...
Old 03-03-2014, 02:16 PM   #28
blkwrxwag
Drives: DS FRS
Utter rubbish.
-Max H.
blkwrxwag is offline   Reply With Quote
The Following User Says Thank You to blkwrxwag For This Useful Post:
TrqlessWonder (03-04-2014)
200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) DeliciousTuning Software Tuning 156 07-01-2014 08:37 PM
Tire PSI for completely stock autocross? bladesamurai Tracking / Autocross / HPDE / Drifting 16 06-11-2013 10:07 AM
07 WRX wheels & 225/45 Dunlop ZII Stock autocross set up -max- Wheels and Tires 0 04-29-2013 04:26 AM
Completely stock BRZ / FR-S needed AMR Engine, Exhaust, Transmission 11 04-03-2013 10:01 AM
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
